Tubbs Beam-on-Target Effort [Neuts/Pics/Tips]
RobertTubbs
Re: Tubbs Beam-on-Target Effort [Neuts/Pics/Tips]
Post by RobertTubbs » Mon May 08, 2017 7:13 pm
Gave a thin film titanium coated copper target a beating last night. It puked a meganeut or so at 50kV after effectively instantly loading. Wasn't a lot left of it when I pulled it out for a look at the damage. Good stuff!
Also attaching a video, a few photos, and a cool .gif of the focal spot adjusting at lower power. First one's the gif.
https://youtu.be/jLvlHaeXsss
Bruce Meagher
Real name: Bruce Meagher
Post by Bruce Meagher » Fri May 12, 2017 9:30 pm
Robert,
Excellent as always! How thick was your Titanium coating, and are you currently cooling your target?
Bruce
Andrew Seltzman
Real name: Andrew Seltzman
Post by Andrew Seltzman » Sat May 13, 2017 5:08 am
You can really see the secondary electrons hitting the viewport, a magnet might work to deflect them.
What's the x-ray dose rate at the viewport?
Andrew Seltzman
www.rtftechnologies.org
Werner Engel
Real name: Werner Engel
Post by Werner Engel » Mon May 22, 2017 5:38 pm
I just finised work on my new SSPA with 1kW to drive my plasma heating.
Attached you see the numbers (going up to 850W) and a nice picture of the device.
The short video shows the very first test without adjusting the tuner - so you see almost the same power reflected as going out. The sound gives you an idea of the powersupply needed for this!! Unfortunatly the file was not uploaded due to a mp4-restriction.
@Robert: I did not see any RF-discharges in the tuner - as you did. What power levels did you reach when these issues occured?
BR,
Werner
Amp Test for plasma heating.pdf
(340.44 KiB) Downloaded 138 times
Post by John Futter » Mon May 22, 2017 7:12 pm
Werner
Nice to see you using the W6PQL kits for the SSPA.
You can see my build on https://www.qrz.com/db/ZL2TUD
Werner Engel
Post by Werner Engel » Tue May 23, 2017 4:49 pm
The first prototype of the RF-coil
@John: You are right! But I did not use the controlling boards. The reason for choosing the BLF188XR was its robustness versus Price. The right device for a plasma generator! Are you also going to use it for this purpose - or just for ham?
I just read that you are very good in designing RF devices: I still do not know how to design the antenna for the plasma. My first idea was just trying to use a copper pipe with 14 turns and give it a try - using the tuner. I also thought about calculating a kind of resonance frequency resulting out of the geometry – but did not succeed. Next try was to use a spectrum analyzer with a VSWR bridge to measure the resonance frequency - did not work. What do you think will be the right way to focus on – from your experience?
BR,
Werner
Post by John Futter » Tue May 23, 2017 7:10 pm
Werner
we should transfer this to a new post so as to not dilute the good work of Robert Tubbs
I'll start a new post under ion sources to answer this
Roberto Ferrari
Real name: Roberto Ferrari
Post by Roberto Ferrari » Wed Jul 18, 2018 8:38 pm
Hi Robert,
Please, comment about the RF power on your Ion Source Inductively Coupled as well as the Proton/Deuteron current.
Could you provide some diagram of your source? I am curious about the three extractors electrodes.
Thanks!
Roberto
