Achieved - Reflex ion gun Pics
3l
Post by 3l » Sat Jun 19, 2004 7:58 pm
Hi Folks:
The gun is almost done... the controls are easy but time consuming none the less. It is set for a modest 10 kv to start with but an insulator that can support up to 35 kv for a top end of 70 kv collisional. The glass tube is the insulative tube to my metal fusor. (capped)
View from the gun side
the ion gun is in the foreground
Happy Fusoring!
Larry Leins
Fusor Tech
3l
Re: Reflex ion gun Pics
Post by 3l » Sat Jun 19, 2004 8:01 pm
The vacuum side
Tc Gauge
BA tube ( the very top of the picture on the rt)
Pneumatic valve at the right
Real name: Mark Rowley
Post by Mark Rowley » Sun Jun 20, 2004 4:30 am
Quite impressive Larry. Cant wait to see it fired up.
DaveC
Post by DaveC » Sun Jun 20, 2004 6:06 am
Looks good - Larry. I can't quite tell, but it looks like you have the center ring -like electrode connected to the HV insulator.
I still have yet to do the 30 kV runs, but the real data may get there first.
Very nice job.
3l
Post by 3l » Sun Jun 20, 2004 7:04 pm
Hi Guys:
Thanks Guys.
The reflex gun looks simple but it has taken all of three months to get it to center up with the design layout.
Conflat design is not really compatable with it.
I can see why you would want to mock up a prototype in pyrex.
You can see what you are doing!
I wanted a higher power version so I went to all conflat.
I had to build special hangers to get the enzel electrodes to their proper places with destroying electrical or physical placement.
I have yet to finish up the feed thrus.
I did a test welding on an extra conflat nipple,it was a vacuum nightmare so I silver soldered it
Now comes the real deal.
I hope to get it running before August.
Fingers Crossed. :^)
Happy Fusoring!
Larry Leins
Fusor Tech
Post by Richard Hull » Mon Jun 21, 2004 7:26 pm
Nice rig. Can't wait for test data.
I know what you mean about the pyrex mockup. That is/was/is what Tim Raney and I had/have in mind. Regardless of looking in glass or chancing it in SS, all setups are a bear! Slow to snail paced.
raneyt
FROM RANEY: Reflex ion gun
Post by raneyt » Fri Jun 25, 2004 1:17 pm
Larry & All,
Per Richard's comments, I've made two Pyrex ion gun versions, but they are on the "back burner." I'm finishing up another electric "engine" for a customer, so that has taken priority.
Good luck with your experiments and I look forward to hearing about your ion gun's testing.
Warm Regards,
TIM
3l
Re: FROM RANEY: Reflex ion gun
Post by 3l » Fri Jun 25, 2004 3:52 pm
Hi Tim:
Thank you for your kind words.
I wanted to do it in pyrex but the power requirements and xray potentials of inelasic collisions was too great.
My electrodes are slid in on ceramic rods.
All alignment is done outside the tube.
Then glued in place.
The glue is ceramic cement... that can be fired in an electric oven to set.
I'm trying key chains as the connection at the low voltage caps.
They just touch the top of the enzel lenses.
The high voltage is an extender screwed into the center electrode.
Happy Fusoring!
Larry Leins
Fusor Tech
3l
Post by 3l » Tue Aug 31, 2004 10:45 pm
Hi Folks:
This particular form of reflex device is flawed.
It only delivers a small N/s due to the small 1/2" dees.
To make this device work really well will take a much larger device. So higher potentials can be used.
Happy Fusoring!
Larry Leins
Fusor Tech
