#2 FAQ - Mechanical Pump - Diffusion pump?
Tom McCarthy
Real name: Tom McCarthy
Re: FAQ - Mechanical Pump - Diffusion pump?
Post by Tom McCarthy » Fri Jun 14, 2013 7:03 pm
Thanks very much Richard! Wasn't aware that some of these pieces were even needed!
Tom
Post by Richard Hull » Fri Jun 14, 2013 9:11 pm
Remember, many of those pieces are not needed! (indicated in lower case between asterisked lines.
Tom McCarthy
Post by Tom McCarthy » Fri Jun 14, 2013 11:57 pm
Yes, I got that. I hadn't even heard of a ball valve, I didn't understand the placement of the valves between the pumps and thought it was just a "foreline trap" that you would use, not a micro maze or oil trap.
But after your post there that's a great help and the two hours spent looking up the parts tonight...
Maybe there could be some more mention of those parts in the new schematic for the fusor for the newbies? (Im not far of being a newbie myself).
Tom
Post by Richard Hull » Mon Jun 17, 2013 2:44 pm
The ball valve is mounted in a "T" fitting in the foreline and not inline within the foreline, such that when opened it will act as an "up to air valve", This valve and "T" are cheap and can be found at any good hardware store. This valve is forever left closed. The only time it is ever opened is to release all vacuum from the foreline and forepump body. All this assumes that all other valves are locked closed before doing this.
In short, it is the last thing you do after shutting all valves following a fusor run and done the instant you turn off the foreline pump. Once opened it will return the foreline and roughing pump to atmosphere. The valve is immediately closed after opening it for a second or two and left shut until the next time you have run and shut down the system.
I, personally do not have such a valve in my system. Instead, I have an easy to reach KF fitting on the pump inlet and the instant I shut off the mechanical foreling pump, I loosen the KF clamp pull it off and tilt the fitting to let in outside air, then immediately reconnect the fitting and clamp to seal the line again.
Needless to say, as the foreline and pump body are at air pressure, when starting up again turn on the foreline pump and let it run a few seconds to drag the foreline down to it lowest pressure and only then open the bellows valve to the foreline trap.
Good vacuum running and operational technique can keep a system clean and in need of little maintenance.
Few fusioneers use a foreline trap or a diffusion pump oil trap. They are just not needed for fusor work provided you use a silicone or pentavac diff pump oil. These "extras" are used more often by a vacuum purest or someone using the system for projects requiring much deeper vacuums than the fusor would ever demand.
Troy Peterson
Real name: Troy Peterson
Post by Troy Peterson » Tue Jun 18, 2013 8:15 am
For venting the foreline on my system I use an "Up to Air vent valve" from Lesker.. It's rather expensive for what it does, but it works well. Previously I was using a common hardware store ball valve for the purpose but I always suspected that it was the cause of one of my phantom leaks.
http://www.lesker.com/newweb/valves/gas ... cfm?pgid=0
Cheers,
Troy.
Post by Chris Bradley » Tue Jun 18, 2013 4:56 pm
For venting the foreline, you can also drill a small hole in a blanking disc, located at some convenient joint, and stick a bit of sticky tape over it. You can even do likewise on the neck of a KF flange joint, works equally well.
1 inch of sticky tape usually weighs in at a slightly cheaper cost than a valve. ;)
---> viewtopic.php?f=25&t=3952&p=25258#p25258
[Link added..]
Last edited by Chris Bradley on Tue Jun 18, 2013 5:22 pm, edited 2 times in total.
Post by Richard Hull » Tue Jun 18, 2013 4:59 pm
When I used a ball valve on Fusor III I repacked it with vacuum grease and it sealed fine. I had a brass type valve and chrome steel ball. Thus, it could be repacked fairly easily.
Pascal Mueller
Real name: Pascal Mueller
Re: #2 FAQ - Mechanical Pump - Diffusion pump?
Post by Pascal Mueller » Sun Dec 23, 2018 3:17 pm
You wrote that "You will need to get at least a 2-4 CFM, (cubic foot per minute)". I did read about several kidn of pumps and while checking ebay I did check out quit a few manuals.
What I noticed is, that e.g. for a Turbovac 50 and similar the recommended forepump is a Trivac D2.5E, the CFM really differs. How is that exactly possible? From what I've seen, the CFM from the turbo pump in the given example is way higher than the one from the forepump. I currently sturggle a bit seeing the connection between the CFM of the forepump and the CFM of the trubo/diffusion pump.
Also: Is that 2-4 CFM related to the pump which is directly connected to the vacuum chamber, right? So e.g. if I have a demo fusor with just one pump it should have 2-4 CFM but if I have a diffusion pump with a forepump, the 2-4CFM would be for the diffusion pump, right?
Post by Richard Hull » Sun Dec 23, 2018 6:24 pm
A demo fusor only needs a mechanical fore line pump. A real, working fusor would normally need both a fore line pump and a diff pump. Diff pumps will not operate properly with pressures greater than a 50 micron vacuum at the inlet. The mechanical pump is needed to allow the diff pump to operate.
Pascal Mueller
Post by Pascal Mueller » Sun Dec 23, 2018 7:58 pm
EDIT: In the original post I misread a unit, thus being off by 10e3. Added an example for clarification of my question.
Of course I already do know that. :) That's something you can easily read in these FAQs and on Wikipedia. I try to gather as much information on my own as possible but I think I might be confused here also I might have asked badly. My goal is to make real fusion at some point, the demo fusor was just an example. So maybe I ask a bit more concrete: If I have, let's say, a spherical chamber with a diameter of 8"-10" (20-25cm) I am wondering how many liters/s (or CFM) my high vacuum pump (i.e. turbo or diffusion) should be capable of. I make an example at the end.
I really though I did read some information about this in these FAQs but I was just looking through them for an hour or even longer and couldn't find it. In another thread you stated "The pumping capacity for any fusor mechanical pump needs to be at least 2 CFM for a demo fusor, but for real fusion in a really normal chamber of 6" or more, you will want something of at least 5 CFM Capacity." So 5 CFM is about 2.36 liters/second.
Example: For a 8" chamber I need at least 5 CFM according to that above.
Let's say we have a Turbo Pump which has about 50-65 l/s i.e. 105-140 CFM (depending on the gas). The recommended forepump has 3.4 m^3/h i.e 2 CFM.
Now, if you say I need 5 CFM I am more than fine since my pump has 105-140, right? I am very unsure because that example was from a pump which sees to be on the lower end when it comes to pump speed.
Thanks for any input!
Last edited by Pascal Mueller on Sun Dec 23, 2018 8:32 pm, edited 2 times in total.
