Chia-Yu Yuan's fusor progress
Chia-Yu Yuan
Real name: Chia-Yu Yuan
Post by Chia-Yu Yuan »
Hello everybody, I am Chia-Yu Yuan, a college student.
My teammate and I are working on a proto-fusor which is made of two CF35 flange tees and a KF16 4-way cross as vacuum chamber with a 10KV 30mA NST(HB-11010)
This is our HV circuit, D1-4 are microwave diodes(Cl01-12) consist of bridge rectifier
This is inner grid with three nickel rings. The gird's diameter is 2 cm, and the wire is 1mm thick
Because the voltage across fusor is a pulsating DC voltage, it requires a good way to determine the effective voltage to identify different voltage conditions. Thus, we apply 𝑉𝑟𝑚𝑠 to be the effective voltage, but we are not sure whether it is a good way.
In last few week, we have successfully lighten up our fusor, and these are picture of plasma in different conditions
35.3mTorr, 1310Vrms, 0.8mA. It looks like star-mode, but due to the voltage and current is too low, we think it is not like typical star-mode
103mTorr, 496Vrms, 2.36mA. We think it is halo-mode
1.03Torr, 302Vrms, 2.7mA. We think it is normal glow
Re: Chia-Yu Yuan's fusor progress
Great effort on the demo fusor system with images and data. I have placed you into the plasma club due to your complete data and images submitted.
Return to “Images du Jour”
