Hi all,
I'm looking for some documentation on cleaning a large beryllium window on an Ortec detector. Do they provide any guidance beyond indirectly applied acetone, or another solvent that's compatible with their window epoxy? Can you swab a window beyond a certain size under internal vacuum? New to the beryllium windowed detector world and I'd like to avoid a mistake. Common tips and tricks are very appreciated.
Thanks,
Eric
Cleaning large beryllium windows?
Re: Cleaning large beryllium windows?
Does it really need cleaning? Ever heard of letting the sleeping dog lie?
Unfortunately this 'sleeping dog' has fleas, or at least a very thin white residue under the plastic window cap. Coming from the usual surplus channels, I couldn't say what it is.
Eric
Eric
- Real name: Frank Sanns
A thin white film on Be is most likely oxidation from being stored in a high moisture or corrosive environment.
It is transparent to X-rays just like elemental beryllium and is best left undisturbed. Organic solvents are not going to remove it and mechanical means can make it airborne which is not advisable for the severe health risks.
The window is thin and fragile. The oxidation has already compromised some of the base metal. Removing more is probably not the best direction.
Frank,
That makes a lot of sense, thanks. Leave it alone it is.
Eric
Eric
