I am struggling to operate the 901P 42030 and I am using this code from another part of the forum:
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
String sensorValue;
String pressureUnit;
String unitBuffer;
String unit;
const byte ledPin = 13;
const byte interruptPin3 = 3;
const byte interruptPin2 = 2;
void setup() {
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
Serial.begin(9600);
pinMode(ledPin, OUTPUT);
pinMode(interruptPin3, INPUT_PULLUP);
pinMode(interruptPin2, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(interruptPin3), pascalISP, FALLING);
attachInterrupt(digitalPinToInterrupt(interruptPin2), fuspeakISP, FALLING);
void loop() {
if (unit == "Pascal") {
pascal();
else if (unit == "Fuspeak") {
fuspeak();
display.display();
void pascalISP() {
unit = "Pascal";
Serial.print ("@253U!PASCAL;FF");
void fuspeakISP() {
unit = "Fuspeak";
Serial.print ("@253U!TORR;FF");
void pascal () {
Serial.print ("@254PR3?;FF");
sensorValue = Serial.readString();
sensorValue.remove(0, 7);
sensorValue.remove(7);
pressureUnit = "Pascal";
display.clearDisplay();
display.setTextColor(WHITE);
display.setTextSize(1);
display.setCursor(0, 0);
display.print("Foreline Pressure");
display.setTextSize(2);
display.setCursor(0, 9);
display.print(sensorValue);
display.setCursor(85, 25);
display.print(pressureUnit);
void fuspeak () {
unitBuffer = sensorValue;
unitBuffer.remove (0, 5);
if (unitBuffer == "+2") {
pressureUnit = "torr";
else if (unitBuffer == "+1") {
else if (unitBuffer == "+0") {
else if (unitBuffer == "-1") {
pressureUnit = "micron";
sensorValue.remove (1, 1);
sensorValue.remove (3);
else if (unitBuffer == "-2") {
sensorValue.remove (2);
else if (unitBuffer == "-3") {
sensorValue.remove (1);
else if (unitBuffer == "-4") {
pressureUnit = "millitorr";
else if (unitBuffer == "-5") {
else if (unitBuffer == "-6") {
else pressureUnit = "endelse";
The code runs fine but I'm getting a logic error. How do I get the pressure to be displayed?
901P 42030 Transducer Issues
- Real name: Matthew Nikolaenko
- Real name: Joe Ballantyne
Re: 901P 42030 Transducer Issues
The 2 as the second digit in the model number of your device indicates that it is an RS485 bus not an RS232 bus device. Are you sure you have the proper RS485 interface for connecting to that device from your control board? Transmit and receive are shared on the same wire for 485 unlike 232 where you have separate Rx and Tx lines.
The correct way to connect to an RS485 bus is to use a proper tranceiver chip for driving the differential twisted pair electrical signals. I suspect you may not be using one right now. Unless you know for a fact that you can wire the Rx and Tx input and output wires directly together on your control board, don't do that. Get the correct RS485 driver chip and use that.
