Hello everyone,
As I narrow in on the equipment I need to build a fusor, I'm realizing the cost is higher than I originally thought.
Withat being said, I've found a decently priced Edwards Diffstak 63 diffusion pump that looks to be in good cosmetic condition (https://www.ebay.com/itm/325501312444). It's currently on sale, and priced at $675, is that a good price? And it's local to me, so I'll swing by to check it out in person, but I've never worked with a diffusion pump so what should I inspect?
Also, for the roughing pump I've found a decent deal on FaceBook Marketplace that comes with a vacuum oven (https://www.facebook.com/marketplace/it ... 780184820/). The vacuum pump is an Across International EasyVac7, single phase, 7 CFM, 150 microns. Would this serve as a good roughing pump for the Edwards Diffstak 63 diffusion pump?
And do you guys bake out your vacuum parts before pulling a vacuum? Or is that not necessary for fusors?
A preemptive thanks for the responses!
- Arya
Edwards Diffstak 63 diffusion pump; Across International EasyVac7
- Real name: Arya Afshari
Re: Edwards Diffstak 63 diffusion pump; Across International EasyVac7
150 microns is totally unacceptable bottoming pressure on any mechanical vacuum pump!! Read the FAQS!!!!
These talk specifically to mechanical pumps and another FAQ on diff pumps. Self-directed learning and study is expected here.
Thank you Richard for pointing me in the right direction.
- Arya
- Arya
Every new person has to also be warned not to use block quotes!
We are really smart enough to have read all preceding posts and never use block quotes of what is immediately above in a thread.
here is how you should have answered you post above.........
"Thank you Richard for pointing me in the right direction."
Arya
A simple reply is all that is needed. Please do not use block quotes in future. No one reads them here. Why?.... They have already read them in the original post. Thanks
Arya
Well Richard, thanks again for correcting me. The above egregious error has been rectified.
Perhaps there is a "Rules of the Road" for this forum that I am missing.
- Arya
- Arya
Other that using you real name when first signing up and not using block quotes in responses that is about it. Oh using the FAQs in each related forum you will usually find all of your questions answered as they have been asked and answered by a steady stream of FAQs since 1999 here.
example What voltage do I need to do fusion. a quick check of the FAQs in the High voltage forum will yield this FAQ
viewtopic.php?t=9929
I tis really quite simple if you just search the FAQs
