Hey! I was wondering, what's the best way to make a spherical vacuum chamber, or where can I buy one? I am planning on making a fusor build and was wondering what the best way to go about this was. In terms of power supply, I am planning on using a neon transformer (and rectifier), and a voltage multiplier to step it up to a voltage high enough to fuse deuterium.
^^ I found this older post about the same topic, but the links are no longer valid: viewtopic.php?t=11526
I don't have good enough experience in metal work to fabricate my own but I am able to weld 2 hemispheres together if necessary.
Any help appreciated, thank you!
Fusor Vacuum Chamber
Re: Fusor Vacuum Chamber
Why not checkout one of our major forums. We kind of expect folks to read at least all the forum titles to see if there is anything there for them.
viewforum.php?f=75
viewforum.php?f=75
Yea, sorry about that. I am planning on welding two 6" SS Hemispheres to two 8" CF flanges, and welding some other CF "ports" to the hemispheres (pretty standard build, I think). Thank you!
