Hey! I was wondering, what's the best way to make a spherical vacuum chamber, or where can I buy one? I am planning on making a fusor build and was wondering what the best way to go about this was. In terms of power supply, I am planning on using a neon transformer (and rectifier), and a voltage multiplier to step it up to a voltage high enough to fuse deuterium.
^^ I found this older post about the same topic, but the links are no longer valid: viewtopic.php?t=11526
I don't have good enough experience in metal work to fabricate my own.
Any help appreciated, thank you!
Fusor Chamber
- Rich Feldman
- Real name: Rich Feldman
Re: Fusor Chamber
Welcome to the forum.
You can find answers by reading FAQs and searching the forum for a few hours.
Your question belongs in the New User Chat Area.
Also it's my turn to say: please change your username unless your real first name is Max and your real last name is Dogg. As required if you read the forum registration page.
Good luck.
Good luck.
Re: Fusor Chamber
Ok, thank you for the reply, I will change my username now!
- Paul_Schatzkin
Re: Fusor Chamber
Thank you for playing, but still wrong.
The registration requirement is "user ID must be full first and last name."
Kindly try again.
--P
