I recently acquired a Seiko Seiko 300 series turbo pump and controller. It is a full magnetic levitation bearing pump and therefore requires two 12 volt batteries for backup power. It is also rated for 100 VAC, so I tested with a variac. Last date on the battery tray was 1990 and I knew the previous owner so I am pretty sure it has been setting on the shelf for 30 years. Here are some pictures of what it looks like as received.
The connecting cable is quite populated. I was told that all three components, controller, pump and cable are tuned and matched at the factory and the serial numbers need to match. Yes they do. If they do not, there is a field tuning procedure.
I ordered a ISO100 to KF50 adapter for some testing. Here is a simple setup on the bench for a test run. I have been told that needs to be securely mounted for a bump while running will kill it.
First run was stressful. It worked ok for a while but started making bong noises. Apparently this is the sound of the magnetic levitation system releasing and letting the rotor contact the mechanical "touchdown" bearing. I increased the input voltage from 100 to 108. AKA 90% of line voltage on the variac.
It has made a half dozen test runs. The rotor takes 9 minutes to reach full speed. After a number of pump downs, it will get into the mid "6s" a couple minutes after reaching full speed. It has to coast down and the manual recommends a vent to 5 torr to slow it down. Therefore another slow vent valve is required; yet another project to make.
It works well, pumps well, but I'm still scared to use it much. One false move, like an air breach and it toast. I will probably use the Pfeiffer for a while before setting this one up.
I hope you enjoy to tour.
chuck
I opened it to see if there are any internal ways to change the power voltage. Nothing obvious and quite an OMG moment. You can see the empty battery tray. I installed two 12V 7AH batteries.Testing Seiko Seiki 300 turbo pump
- Real name: Chuck Sherwood
Re: Testing Seiko Seiki 300 turbo pump
I, like you, would be afraid to run this thing in real life. In its first life, (when new at $10,000 plus), it must have been mounted in a steel frame set in concrete. Thanks for the tour.
Nice pump, a lot of these seikos were used on SEMs and FIB because of the maglev. You can run them off 120v no problem. The battery is there to keep the rotor levitated in the case of a power loss. The touchdown beating is only rated to take a couple high speed landings, I think 5.
They are interesting beasts. That first time you hear the rotor drop is quite a surprise. Otherwise you can treat them like any other turbo, you dont need to slow them down, you can just let them spin down naturally, they do have an internal dynamic braking system. Without it they take about 8 hours to stop at high vacuum.
I have an Osaka maglev pump on my big chamber. Its a 2000l/s one with a 200mm ISO flange.
Oh, and when they are on SEMs they just hang from a ISO-100 flex connection with rubber vibration isolators. There is not a whole lot to worry about on a pump this size. The BIG ones you need to worry about. They will rip the bolts right out of the conflat or ISO flange.
This pump has provided me membership in elusive "Club 7". After running for several hours today using this setup. I achieved pressure of 8E-7 Torr. I've been playing with diffusion pumps for years and could never get below about 3E-6
cs
cs
