Hello,
First of all I would like to say that I am aware of the strong dislike of glass chambers instead of steel chambers, having read some of the FAQs. The problem is, I have little experience in the field of vacuum, and am unable to commit to constructing a steel vacuum chamber with so little knowledge.
Therefore I am building a demo fusor of a similar level to the one presented in the make magazine, albeit with some modifications.
This will lead me to a bell jar design, but I have also read reports of the chamber imploding in a possibly dangerous (or even lethal) way. Therefore I'd like to ask - what would be an adequate material for the chamber? Will a standard Pyrex food container bowl be sufficient?
Safety when operating with glass chamber
- Jim Kovalchick
Re: Safety when operating with glass chamber
My son made a neutron producing fusor with a steel bell jar instead of glass. All his chamber feedthroughs were out his bottom plate except his view port. His steel bell jar was cheaper and safer than a glass one, because his bell was the mixing bowl from a kitchenaid stand mixer. They can be had as a replacement part much cheaper than a good glass bell jar. The kitchenaid bowls have a good size dimple in the base that can be cut out for the view port leaving a smooth surface for a rubber gasket and a square of glass that vacuum holds in place. The bowl even has tabs you can use to attach your ground. Use viton rubber for the base gasket as well.
There, your cost and safety issue is solved.
- 2012120295155538.jpg (15.96 KiB) Viewed 1289 times
- Real name: rich normand
Elegant design... Love it.
Ingenious - really a good approch.
Now I feel quite inadequate for not having thought of that sooner.
Thanks for the idea.
First I've seen and certainly would not have thought of either. That is why this forum is so useful.
- Jim Kovalchick
My son built the steel bell jar fusor about 10 years ago. The plasma pictures were always pretty because of symmetry.
