Polyethylene naphthalate as scintillator
Polyethylene napthalate (PEN) has been cited as a natural scintillator material, needing no fluorescent additives. I've been wanting to try it out, but so far have not been able to locate a source of the virgin resin or a fabricated rod of virgin material. One supplier has rod stock, but it's horribly expensive and black, to boot. One Chinese supplier has virgin granules, but a minimum buy quantity of 3,000 pounds - that's so not happening...
Re: Polyethylene naphthalate as scintillator
I wonder how gamma efficient is it, say, compared to NaI? Still, it would be cool to have some to try out. Pitch black is another non-starter.
It's probably similar to other plastic scintillators re gamma discrimination, so I wouldn't get my hopes up.
Here's a presentation on PEN used as scintillator, also mentions PET, which might need a wavelength converter to mesh with the usual PMT.
https://agenda.linearcollider.org/event ... llator.pdf
A thought - I work for a company that deals in ICs, so we have a bunch of plastic rails around for carrying the parts - one of the rails at my desk shows what appears to be bulk fluorescence when exposed to daylight - could it be molded from PEN?
Possible, but fluorescent chemicals are often added to plastics to stop them being degraded by UV.
I'm beginning to think that the fluorescent bit may be thee anti-static coating on the plastic, as one end has been degraded by exposure to light and there doesn't seem to be fluorescence of any sort on that end. Sigh...
