Post still under construction
This is a mishmash post of various things I've been working on over the last little while as I prepare to assemble a new cube fusor. Maybe you'll find some things interesting. I sure didn't know how the inside of a cold cathode gauge or gate valve looked.
RGA Repair
My old (1980s) Spectra Vacscan Plus RGA system began to die early this year. It had always suffered from reduced sensitivity but it was plenty good enough to tell me that hydrocarbons were contaminating my chamber. Then, the signal disappeared. No peaks or total pressure measurement. The slow fading over time was consistent with oxide buildup on the ionizer assembly, confirmed by a rep of MKS. Examining the ionizer assembly indeed revealed a significant buildup of oxides and thin films.
I attempted to mechanically remove the worst offenders with scotchbrite and fine sandpaper, and a test under vacuum appeared to be successful... until a minute later the signal died. Skipping the many hours spent on diagnosing the mechanical and electrical systems, I found that there were two issues. The oxides did indeed reduce the sensitivity, causing the steady reduction over time, but it somewhat hid the dying transimpedance amplifier. It's an obsolete part, but thankfully Ebay exists.
I used 35% hydrochloric acid to completely remove the oxides and films from the ionizer assembly. While I was at it, I completely disassembled the RGA to clean it and look for further issues. None were found and the analyzer works again, matching my vacuum gauge within ~10%.
Cold Cathode Gauge Cleaning
These gauges need cleaning every now and then, and mine was years overdue. It's a Pfeiffer PKR 261.
The internals are remarkably simple and two gauges (cold cathode and pirani) are operated with only two wires! The 261 is metal sealed, so I had to add a thin washer to the single-use spring C-seal compression assembly to get a seal again. I used fine sandpaper to bring the housing and anode to a bright finish and cleaned everything as detailed in a recent post before reassembly. It works well down to <5e-9 torr.
Gate Valve Cleaning and Repair
My old primary/throttle valve was a butterfly valve, and just about every single one in existence leaks through the shaft seal (unless it's a UHV bellows type), especially when it's actuated. That was unacceptable for UHV, so I purchased a quite used and dirty MDC UHV manual gate valve. As it arrived, it was difficult to actuate and would get stuck unless held in a specific orientation. It was also quite dirty and somewhat rusty. I opened it up, only to find that it uses a non-standard copper crush seal. Following extensive sandpapering, cleaning, a custom laser-cut copper gasket from OshCut, and a new gate o-ring, I was able to get everything working smoothly again. The leak rate through the gate (with one side at ATM) is ~1e-6 torr l/s, likely from a small radial scratch in the recessed o-ring groove. The custom gasket, once cleaned, polished, and very thoroughly crushed, holds to UHV.
O-Ring Troubles
This is a minor thing, but the viton o-rings I recently ordered from LDS Vacuum arrived in a state completely unsuitable for vacuum. They were covered in powder, grease, and who knows what else. They did not use to be like this and used to arrive in almost vacuum-ready conditions.
NIM Bin Repair
The bin arrived functional but died within a few hours. The culprit turned out to be a shorted high-temperature aluminum electrolytic capacitor.
The rack contains two HV supplies, one preamp+amp unit, and one amplifier. One system is for gamma spec and the other for neutron detectors.
<some error with wrong file uploading>
Misc
Various Repairs, Progress, Eye-Candy
- Liam David
- Real name: Liam David
Re: Various Repairs, Progress, Eye-Candy
It is always nice to take a working system and go through it several times over the years and clean and neaten things up a bit to improved serviceability and ease of use. Often, this allows for easy update in future. It can take a good bit of time and effort, but it always pays dividends in the end. Great photo essay on your system. Clean and clear images. well done.
It is always nice to see the guts of a great vacuum system.
Excellent post packed with good information and photo's.
