Help ID'ing RF Connector
- Real name: Robert Mendelsohn
Hello,
I am having trouble identifying an RF connector. Neither BNC nor MHV will mate with it. They are attached to a 4.5"CF flange, which the seller identified as BNC. Any ideas? It seems almost exactly like BNC or MHV except insulation sleeve length.
Any help most appreciated.
Sincerely,
Robert
Sincerely,
Robert
Re: Help ID'ing RF Connector
These are external special HV connectors with no real locking lugs as found on BNC connectors. Being push-on only unless they lock internally, out of sight. Figure on these being of no real value related to the flange without having the mating connectors on hand. We wonder what sort of arrangement is on the other side. (internal to the vacuum)
Have I mentioned that I hate, with a passion, rare, custom connectors and fittings?
Thank you Richard - do you think I can kludge together something by dremeling back the insulator? Any ideas/tips?
- Real name: Matt Gibson
What are you hoping to use that for?
-Matt
-Matt
Naturally, the mate is a female connector I would assume you need a piece of conductive tubing that is a tight fit to mate with the pin. the plug body would be either a metal shell just oversized to go over the male barrel with a very thick internal ceramic or teflon insulating sleeve to go over the male plug's insulator.. or...a smaller metal shell to fit within the male shell and a thinner ceramic or teflon insulating sleeve to do the same over the male plug insulator. The real trick is insulating the body of your made up female from the internal pin to the metal plug body.
All of the above would be OK and would be how I would do it, if I was so driven to conquer the issue. Some such things, on rare occasions, stare at me as if a gauntlet is thrown down before me. Seeing this situation would have me pass even though I know just how to attack it. I assume you are not pumping in RF but only DC? If so, you are in for much, much more headache.
Do you think 50V RF will be a problem through a DIY connector?
50 volts is a snap even with a lousy plug. RF?? What frequency? You have to now worry about RF shielding issues if the frequency is high and the RF current is also high. You seem to not give any real details about what you are planning to blast through these connectors. Don't make us have to pull teeth to get it out of you. Full details please.
This is an RF feed-through for a helicon plasma source. The frequency range is 3-15MHz. I am only putting 1-5W power into it. I have a lot of matching equipment and everything is completely contained in a very thick steel vacuum chamber (no concerns about emissions outside the chamber, it's a Faraday cage).
I would think you could fabricate a suitable connector at those frequencies and energy handling capacity. I know I could with great ease. Would not be pretty but would be very serviceable.
- Alexi Hammond
- Real name: Alexi Hammond
This is a flange from a UTI mass spectrometer. The mating part is a bunch of MHV connectors held together with a brace. The brace attaches to the flange using two screws. The UTI mass spec electronics applies up 3kv dc to the detector and up to 300 V peak rf at about 1mHz to the poles.
So, 50V rf should be no problem.
I was going to say this looked like an old RGA flange.
