Two PDF papers are attached with advanced fusor operational conditioning data. The newbie might be a bit lost as these are written for someone who has at least cut their teeth on a demo system where they are forced to learn about vacuum and high voltage in a low pressure gas environment.
To get full value, you might read them in order as the first one leads to the second...
FAQ - Conditioning info on operation - rather technical
- Advanced technical discussion.pdf
- (174.34 KiB) Downloaded 540 times
- Conditioning a leaky fusor.pdf
- (286.55 KiB) Downloaded 429 times
