Ripple voltage
Nicolas_Malo
Real name: Nicolas Malo
Ripple voltage
Post by Nicolas_Malo »
Quick question: I am building a high voltage power supply and wondered if a 200V ripple on 30kV was going to be noticeable on the plasma? Thank you
Liam David
Real name: Liam David
Re: Ripple voltage
Post by Liam David »
Nope, not in the slightest, especially above a few 100 Hz.
Bob Reite
Real name: Bob Reite
Re: Ripple voltage
Post by Bob Reite »
Those of us who use old 60 Hz X ray transformers just use the raw unfiltered output of a full wave rectifier and it works just fine for a fusor.
