Plasma!
- Anze A Ursic
- Real name: Anze A Ursic
Plasma!
I think this was around 4.75kV, the old HV feedthrough was failing around there and we kept blowing up the power supply. This was last year, around October. It's a cylindrical fusor and I hope it'll work good for the fusion run we're planning soon!
- Rich Feldman
- Real name: Rich Feldman
Re: Plasma!
Nice light. Congratulations.
If the glow covers the surface of cathode wires, as in a Nixie tube,
then the pressure is too high for fusion by orders of magnitude.
I'd guess the voltage is much lower than 4.75 kV, unless it's measured on the supply side of a ballast resistor.
Re: Plasma!
As Rich has pointed out, you are in the torr range and can't do fusion at all - you'll need to reach high vacuum levels to begin before adding deuterium. Do you have a method to measure vacuum?
And why can't your pump get lower then this vacuum level you are showing? Your fore pump should be able to get below 20-30 microns at least for most decent two stage oil based pumps. Is it a bad pump or do you have massive leaks? These are issues you really have to address before you can even think about trying to do fusion. Maybe show a picture of your entire system so we can get an idea on why your vacuum is so poor - have you measured the vacuum at the pump head (no load)?
- Anze A Ursic
Re: Plasma!
The second picture was in the 15-20mTorr range if I'm correct. We have a Balzers transcuder and gauge that we use. Although now I'm curious how accurate it is. Although we probably have something better I could check out. I should say, the chamber is quite large...
I know it's too high for fusion. But with the turbo, I can go down to 0.1-0.5mTorr range which is hopefully a low enough starting point for fusion.
- Anze A Ursic
Re: Plasma!
Also, please don't mind the mess in that picture haha! I've been tweaking this system for the past week, once we do any testing it's very tidy and clean.
Re: Plasma!
Nice set up and certainly my system gets messy all the time. You have some big ports on that chamber.
As for reaching 0.1 - 0.5 micron being enough for a fusor, well yes and maybe - that is, if leaking is occurring that is preventing the system from doing better then that with the turbo running - i.e. outside air is being drawn into the fusor - then the air will dilute the deuterium gas and reduce your ability to do fusion. I'd think your turbo would do far better - like 10^-5 torr (or 0.01/0.05 or so mtorr.) Otherwise, either heavy out gassing, or a possible leak. But accurate vacuum measurements are essential to better clarify the issue.
A well sealed chamber (those are a lot of bolts to tighten properly!) like that and if fairly clean, your fore pump should get it well below 20 microns. That doesn't appear to be the case.
As Rich pointed out, the first picture looks more like the torr range rather than milli-torr* (microns.) The second still does not look to me to be in the 20 micron range. Just saying.
We tend to use microns there - mtorr is a micron but it is just common usage.
- Anze A Ursic
Re: Plasma!
The lowest pressure I've ever gotten with this thing is 19 micron. The greatest outgassing factor here is the top flange. It is a non-standard size and so we cannot find the proper copper ring and it is also the part of the chamber that is always being opened / closed when my fusor is placed in there so we just use that home made rubber seal as you can see in the picture.
With that thing we've never gotten past 19-20 micron. But it is what it is, with the turbo, we can go way lower.
Re: Plasma!
Have you tried leak detection? Just getting to 19 microns may or may not be out gassing (through, that should change with a few over nights/days sealed but pumped. How long does it hold vacuum - like in an hour does it go from 20 microns to 100 microns (arb. values here.) You should tell us the rise rate/time after you close off the fore pump and what the vacuum gauge reads as time passes. The best way to determine a leak is to do a simple test. While pumping, use a spray bottle of near pure alcohol and spray each seal area when at your lowest vacuum, one at a time. When you do this, if the vacuum gauge rises at all, then you have a bad seal.
- Anze A Ursic
Re: Plasma!
I'm back in lab right now. Yesterday I ran just the mechanical pump for roughly 2 hours and I got to 78 microns (it was fluctuating a lot, it would probably go lower had I left it for a longer period of time). I just came back and after almost exactly 14 hours the pressure in the chamber was 1.1 Torr. It's not fantastic but also not too bad I don't think. Again, that top flange is probably the biggest issue.
I've never heard about the spraying alcohol test, I will have to try it, thanks!
Re: Plasma!
Only 71 microns in two hours is not good with a good two stage vacuum pump (is that pump ok? Maybe test that at some point, too.); even out gassing shouldn't cause that slow a pump down. Climbing to a torr over night isn't good but certainly isn't terrible. Definitely, test the main seal and then move to other seals. Alcohol works very well at these higher pressures.
- Anze A Ursic
Re: Plasma!
Well hahah that's the other issue... the pump sounds like a dying pig, it is definitely on its last legs. This project isn't sponsored or anything so we're making due with what we have. We may actually have another 220V pump that would be way better but we'd have to test it. But I was never worried about the mechanical pump since I just end up using it as a backing pump for the turbo. I figured as long as the turbo is good, it doesn't matter that the mechanical pump is kind of shotty. I am probably wrong though.
Re: Plasma!
Well, likely that turbo is ok with that back pressure; however, you barely get into 10^-4 torr (0.1 - 0.5 microns) and that is a concern. Do test for leaks but maybe your turbo is having trouble with that back pressure. This is where leak testing is useful.
- Anze A Ursic
Re: Plasma!
Well actually the 0.1-0.5 micron range was when I had a massive leak (too many extensions / adapters from chamber to mechanical pump and from turbo to mechanical). At that point I was able to get only 110 micron with the mechanical. Then I turned on the turbo and went to that 0.1-0.5 micron range. I have since removed all those adapters and just used a single flexible tube from the chamber to the mechanical pump and now is when I get 70 microns. I assume now that I'm getting lower pressures with just the mechanical pump, the turbo will take me quite a bit lower too.
However, I found some old data from July 2021 where I took down this chamber to 29 micron with just the mechanical pump, closed off the chamber and waited 30 minutes. It was exactly at 58 microns after 30 minutes, so a change of 29 microns in 30 minutes.
Today I ran down to 77 microns and capped the chamber, waited 30 minutes and got to ~108 microns, so the same exact pressure change over the same time!
This data was useful because July 2021 was before I had ever taken any flange or other thing off the system. Since then I've installed a gas feedthrough, replaced the old 5kV feedthrough with a blank, installed a massive 4 input 50kV feedthrough etc... Over all of these "newer" changes, I also did the alcohol pressure change test you recommended and the pressure did not change when it was sprayed.
I would also like to add that the system, when I open up the valve to the mechanical pump, goes down to 45 microns for a few minutes and then starts slowly rising. It goes to 110 microns and then started slowly decreasing in pressure. I fear the chamber is dirty and it outgassing all the junk inside because when I came back after 5 hours today it was jumping between that 60 and 70 micron range quite rapidly. I suppose had I left it on overnight I could have gone down to about 40 microns but I don't like leaving that pump along for such extended periods of time.
Anze
Anze
Re: Plasma!
Looks like your system has no significant leaks - out gassing is easy to deal with. One just gets the system to where one wants it (configuration, wise), seals it up, leaves it under vacuum (repump it down every day) and it cleans up nice in no time. Not an issue if you open rarely, keep the open times short, and don't open on really humid (rainy) days. Sounds like your good to go.
- Anze A Ursic
Re: Plasma!
Great!
I've also tested the gas inlet system today - no leaks! Bubble neutron detectors are also ordered on expedited shipping... Next two weeks should interesting! Thanks for the help, Dennis and sorry for straying away from the "Images du Jour" topic but this was all excellent info!
Anze
Anze
- Rich Feldman
Re: Plasma!
Are you paying attention to the ballast valve on the rotary vacuum pump?
https://www.vacuumscienceworld.com/blog ... as-ballast
https://www.vovacengineers.com/uncatego ... uum-pumps/
You could also try changing the pump oil and see what happens.
When pump starts cold, it takes a while for oil to get up to its steady state temperature.
- Anze A Ursic
Re: Plasma!
Thanks for the heads up, but I just double checked and we have no gas ballast on that pump. We have these on some of the other pumps but not this one. This is just an old Edwards mechanical pump.
Re: Plasma!
No problem - but do be safe - don't know the voltage you intend to use but getting above 35 kV, and that chamber you have might start to get transparent to x-rays. Do keep an eye on that danger (depending on your voltage.)
- Anze A Ursic
Re: Plasma!
It's all remote controlled from another room, so we are certainly doing our due diligence! We also just got 280 kilograms of lead shielding delivered from the safety folks, so we will be separated by around 5m of air, 1/4" of steel from the chamber, several inches of lead and 6" of reinforced concrete!
Re: Plasma!
Keep forgetting the overkill you have to deal with - just the distance you have is enough even if you were using 70 kV. So, good luck on the testing.
- Anze A Ursic
Re: Plasma!
Haha, yup! But, I don't mind the overkill as long as they just allow us to do it really. We're scheduled for next week on friday so I really hope it all works then... I wish I could test everything before hand but they won't allow me to go past 10kV without radiation officers present lol.
- Anze A Ursic
Re: Plasma!
Very quick update, after running my turbo pump today for roughly 2 hours, I achieved a pressure of 0.17 micron (1.7E-4). Still not ideal, but better than before. I will try to get to the E-5 range, but that top rubber gasket must be placed with extreme precision and tightened in a precise manner too otherwise the pressure is too high. Would a base pressure of 5-9 E-5 Torr be good for a semi-decent fusor run? I know people say to aim for 1E-5 or lower, but again, I doubt I'll come close to that with a home-made rubber gasket.
Anze
Anze
Re: Plasma!
1.7e10-4 torr is just fine to start to admit deuterium and do fusion I did this at this base pressure for 16 years with fusor IV. I never hit 10e-5 torr as a base pressure. I can do it now with my Turbo Which I have only had 4 years now. The old leybold diff pump did just fine for those 16 years with a rather leaky fusor and still dragged the fusor down into the 10e-4 torr range.
You are good to go, I would think.
This assumes you develop a good operational technique which should come quickly and naturally once you do detectable fusion.
- Anze A Ursic
Re: Plasma!
Geez, talk about ougassing... I reached 1.7E-4 Torr the other day after 2hrs and 10 minutes, and today I got to the same pressure in just over a third of the time (46min). i plotted my measurements in an Excel sheet (see below). My fusor isn't in the chamber yet, we're still doing some pressure tests, but I'll make sure to clean the hell out of the chamber once I re-open it. Currently running the test but based on my calculations, I should reach below 0.1 micron in roughly 1.5 hours, so hopefully with more outgassing procedures like this we'll be in the proper range for fusion!
Anze
Anze
- Liam David
- Real name: Liam David
Re: Plasma!
What type of rubber is your large seal? I would highly suggest you use viton, or at least buna-n. Silicone and especially natural rubbers can outgas terribly.
