Hi everyone!
Hopefully a quick question: I was wondering if anyone had any resources on arcing between cathodes and anodes at high voltages and how that changes with respect to vacuum pressure. Our goal is to achieve 75 kV which almost guarantees arcing but I was hoping I could find a resource that relates arcing, vacuum pressure, and voltage.
Thanks!
Question On Arcing in Chamber
- Real name: Logan Holler
Re: Question On Arcing in Chamber
Logan
it is time you actually read all the FAq's found at the top of each sub forum. We are not spoon feeders!!!
Richard has already pointed you to the FAQ's in his introduction reply
look up "Paschen Curve"
