Hi everyone,
I have a chance to buy a machined ring cathode made of either SS or titanium. I have tried to look up whether or not titanium has any benefits, but only found some thought that it out-gasses…
Is there a definitive yay or nay to using titanium ring cathodes in a fusor? Or, should I go with SS?
-Matt
Titanium Cathode
- Real name: Matt Gibson
Re: Titanium Cathode
Matt,
With 189 posts and a fusor, you need never post in the new user chat area ever again. Unless you like it here.
This kind of question belong in the Construction forum.
Titanium will absorb hydrogen/deuterium and can outgas in a fusor operation, but that is OK as we want a deuterium atmosphere. If it ougases deuterium during operation adjusting the D2 flow rate down should rebalance the pressure. It is all part of operating the system.
I would always go with the higher melting point item as long as the vapor pressure at red orange heat is lower than the 4-20 micron pressure of deuterium running pressure. All elements have a vapor pressure as their temperature goes up towards the melting point.
I will attempt to check this out.
I figured I’d post it here since I didn’t know how much is already known about the effects that deuterium had on titanium
I’ll startup a topic in the Construction area after I have done a little more experimenting.
-Matt
-Matt
We just made a new cathode using a titanium surgical rod from ebay, a titanium headset spacer for a bicycle, and some tig welding nozzles. We still haven't attained fusion, but it sure looks pretty. The most difficult aspect of ti is machining it. It will work-harden easily and is quite hard.
