TCP040 smoking at end of spin up?
RobertMendelsohn
Real name: Robert Mendelsohn
Post by RobertMendelsohn »
Hello,
My TCP040 turbo pump controller is starting to emit smoke after it finishes spinning up. Has anyone else encountered this? Or have any ideas about how to fix it?
I think it might be time to get a new one. I don't think it's an over-current due to higher gas load than expected, because it only happens as soon as the pump comes up to max speed.
The smoking component is a metal box, and it's not obvious that that can be easily replaced. All ideas welcome.
Sincerely,
Robert
Re: TCP040 smoking at end of spin up?
Where there is smoke there is charring of electronic components or physically ruptured Integrated circuits. Why not look and see what among these are not looking pretty any more. This will lead one with a good schematic to the area of difficulty. However without electronic knowledge and trouble shooting skills you are probably dead in the water. You are most fortunate that you had a fire. Such horrid nastiness in death serves as an indicator to a good engineer or technician.
My TCP 040 controller died due to high power arcing within the fusor! My controller merely died quietly without explosion or fire while working perfectly. I took the shotgun approach around what I thought might be vulnerable areas of the circuit and replaced 5 IC's of perfect appearance at removal, and luckily got it going again. Not much use of my engineering degree was brought to bear, just lots of experience in the real world of electronic component frailties.
Good luck.
RobertMendelsohn
Thanks for your help Richard, I found and replaced the offending components.
Matt_Gibson
Real name: Matt Gibson
Post by Matt_Gibson »
So what can we do to prevent arc overs from damaging our sensitive electronics such as these pump controllers? I’ve had many arc overs (external and internal) lately yet no failures. Could this be from me mounting everything on an aluminum frame that is grounded to earth?
-Matt
Chris Giles
Real name: Chris Giles
Post by Chris Giles »
RobertMendelsohn wrote: Thu Dec 30, 2021 1:13 pm The smoking component is a metal box...
What was it exactly that failed?
Protection could be provided with diodes, MOVs, chokes and X/Y rated capacitors, depending where the problem is.
I guess there is a transient in one or more of:
* AC line power to the controller
* controller<>motor cable
* control cables if you have any
MOVs are easy and cheap to put in place, could do that as a precaution
RobertMendelsohn
Some electrolytic capacitors, which I presume were simply old and dried up. They were (ostensibly) part of the circuit that kicks on when the turbopump is at speed. I should mention that this was not triggered by any arcing, I really suspect age.
