Hello everybody, I have uploaded an excel file to be used in plasma physics here. I hope somebody uses it:
Useful formula and excel tables for plasma physics V10
Useful Plasma physics excel sheet
- Javier Lopez
- Real name: Javier L
Re: Useful Plasma physics excel sheet
Any reason you don't use your full name?
- Javier Lopez
No, it is my old avatar, my name is Javier Lopez, if it is possible, I could change it
I see you have been a member for a long time, before full name was required.
Yes, you can change your username. Your history will be preserved under the new name but you will need to use the new name to login after changing
--- How To ---
login
click pulldown in top header for your username and select "User Control Panel"
select Profile tab
select "Edit Account Settings"
edit your username field to your name
enter your current password in the bottom field
click "Submit" at the bottom
as mentioned new username is now your login, password the same unless you change it.
--- How To ---
login
select Profile tab
- Javier Lopez
Done, I am under the law now
thank you
thank you
Javier
Excellent with the change
i did it too from Johnf to my full real name just to keep everyone happy.
Because of the change we get very little trolling unlike the past
Happy new year
Happy new year
Thank you - glad to know who you are! And Rex, thanks for those instructions.
