Fusor from India.
Udayshankar R
Real name: Udayshankar Ravikumar
Fusor from India.
Post by Udayshankar R »
Hello everyone,
I'm starting my journey in fusor construction. I have been going through this forum for the past year, and now I have some confidence of where to start. I hope this is the correct thread to post this. I have not yet decided if I should build a proto-fusor or a demo fusor. For now I'm just collecting the instruments/materials and I'll decide later, depending on what all I get.
I'll also put in the price of all the materials and instruments here, for reference for future Indian fusioneers. Exchange rate: 1 USD = 75.05 Indian Rupee (INR).
My first acquisition is a BEL 60mA 100kV 50Hz x-ray transformer from an old x-ray (courtesy of my dentist dad) at $200.
Sitting pretty in my future lab🤞🏽
If this fails, I plan for an FBT with an old monitor-turned TV donated by my grandfather.
Real name: Dennis Brown
Re: Fusor from India.
Post by Dennis P Brown »
That dental x-ray transformer (x-former) has a huge power output (6000 watts) and, of course, when operational will pose an extreme danger of x-rays from the fusor (proper shielding will be critically important). Cabling, ballasting, and a power supply controller for the x-former will be a challenge. As for the TV supply, should be ok for a demo-fusor but could be a challenge to exact from the TV circuit board.
Building a proto-fusor using the TV power supply would be a good learning experience and a great deal safer than that 100 kV, 60 ma x-former. Getting experience using high voltage system without an extreme radiation hazard or the issues of handling such extreme voltages would also be a good idea.
That 60 ma is a peak rating. While old school (non- switching) I would image 30 ma continuous of the average multi-minute fusor run would be the normal maximum expectation. Assuming variac control, as so many of these older systems were, I would imagine 9-20 ma would be a normal fusor current if a successful build could reach 30kvto 40kv. Nice transformer. Make sure it is negative hot, of course or you must flip the diodes around.
Udayshankar R
Dennis P Brown wrote: Sun Nov 28, 2021 2:48 pm That dental x-ray transformer (x-former) has a huge power output (6000 watts) and, of course, when operational will pose an extreme danger of x-rays from the fusor (proper shielding will be critically important). Cabling, ballasting, and a power supply controller for the x-former will be a challenge. As for the TV supply, should be ok for a demo-fusor but could be a challenge to exact from the TV circuit board.
Thank you! I am planning to do proper shielding and will incorporate all safety in the setup.
Udayshankar R
Richard Hull wrote: Sun Nov 28, 2021 3:03 pm That 60 ma is a peak rating. While old school (non- switching) I would image 30 ma continuous of the average multi-minute fusor run would be the normal maximum expectation. Assuming variac control, as so many of these older systems were, I would imagine 9-20 ma would be a normal fusor current if a successful build could reach 30kvto 40kv. Nice transformer. Make sure it is negative hot, of course or you must flip the diodes around.
Thank you! I'll do that.
Udayshankar R
Hello All!
Continuing the post with the materials I have collected. Due to the pandemic, it has been slow.
Got a nice refurbished Leybold tryvac D10E for $240.
Variac for $107
Wire-wound resistors for $26 total
Electrical grounding (my design, made from copper plate and strips), for $133
Udayshankar R
My chamber should be ready in a few days (hopefully). But I'm not getting the electrical feedthrough here. I have identified feedthroughs available online in the US.
SST (Solid Sealing Technology) $220 - https://www.solidsealing.com/products/1 ... in-a-KF40/
MPF $222 - https://mpfpi.com/shop/power-feedthroug ... 0235-6-qf/
My dad is travelling to New York next month. He said he'll try to get this. I'm also putting in the "Items Wanted" topics so that if anyone has it, I can buy it.
That is a very good feed through insulator. I am glad to see you are still working towards your fusor project.
Udayshankar R
Udayshankar R wrote: Sun Nov 28, 2021 12:05 pm Hello everyone,
Reposting the pictures
BEL 60mA 100kV 50Hz x-ray transformer:
FBT with an old monitor-turned TV:
Good progress. Relative to the transformer, I assume the high voltage access is behind one of those removable metal plates?
Udayshankar R
Dennis P Brown wrote: Sun Mar 13, 2022 3:22 pm Good progress. Relative to the transformer, I assume the high voltage access is behind one of those removable metal plates?
Yes, that's what I was told. This is from a working X-Ray machine that was decommissioned when they bought a new one. I haven't opened this as I wanted to collect all the materials first, then work on it. Also, the oil might make it messy.
No need to block quote; its a waste of system resources.
You might want to look into the high voltage (HV) connections to determine both what they supply and how you will access them/it with a cable.
At some point, determining the input voltage and the required varaic needed would be a good idea.
Joe Gayo
Real name: Joe Gayo
Post by Joe Gayo »
What's your plan for neutron detection?
Post by Rich Feldman »
Welcome and good luck!
The pictures indicate that oil-tanked "XRT" is a whole x-ray generator, including Coolidge tube.
First hint is trunnion-like projection on the side, suggesting that unit can easily be tilted.
The case has no penetration for high voltage, it has a window for x-ray beam with 1.4-mm-thick aluminum filter.
I guess the tank is absolutely full of oil, with no air inside. Round convex cap protects a rubber diaphragm or bladder that allows for thermal expansion without large change in pressure.
Udayshankar R
Thank you Mr. Brown for the correction. I plan to do that after I get all the materials.
Mr. Gayo, I have read about BF3 and bubble neutron detectors. I plan to get one of these depending on availability here. Once I have some experience running a demo fusor, I plan to get a mass-flow meter, deuterium lines and the detectors for the "giant leap".
Thank you Mr. Feldman. Once I get all the materials I am planning on opening it up to get to the leads and also maybe transfer it to a larger container to fit the wire-wound resistors int the oil. I am also aware that I should be careful about removing any bubbles to prevent arcing.
I also got 1.5mm Tantalum wire, 1m @ $26.7 for the grid
I have used both Tantalum and Hafnium as grid materials in the past. They are quite suitable and did well. Once I got hold of flexible Tungsten wire I figured why not go with the highest melting point wire. I have used Tungsten since 2007. All three of these work harden and suffer hydrogen embrittlement to a great degree once run for many hours in a fusor. This is not bad at all as long as you handle your grid gently in removing it for repairs of rework within the system.
I like your plan - it is well thought out. Good luck and keep posting on your progress and results.
Udayshankar R
Now I have few more components ready.
Finally, the chamber is ready. SS304L with a viewport, 4 KF25 ports and one KF40 port for the feedthrough. Total cost: $426
The bellows hose, flanges and wing nuts. About: $80
The J-B Weld and Loctite from Amazon, which my dad bought from the US for $19
You can also see the resistors for the voltage divider, from Mouser.com
MOX-4N-131006FE 5W 40KV NI 100MEG @ $26
MOX-4N-131007JE 5W 40KV NI 1G $28
Got the feedthrough from Ebay for $210, as advised in the forum here. I also got a free MKS 901p from Ms. Amanda Ison. So a special thanks to her.
I'm trying to figure out how to use the pressure transducer and will post the results soon.
Matt_Gibson
Real name: Matt Gibson
Post by Matt_Gibson »
That’s an easy to use pressure transducer. All you need is power and two wires connected to a volt meter (I prefer digital). It’ll go down to 0.01 microns which is plenty low enough…
-Matt
Udayshankar R
I've been trying to figure this out these few days. As per advice of Mr. Finn Hammer, I tried communicating with RS232 and MAX3232 adapter. I also tried the PL2303 adapter but the communication is not happening.
The analog output is working though, but the multimeter is not very accurate.
I did try arduino with a voltage divider, with code from Mr. Pablo Llaguno (thank you), and I am getting 8.87V.
The variation is probably due to my shabby connections. I'll fix that later.
This is the code in working with the LCD.
Pressure during suck-test.
Andrew Seltzman
Real name: Andrew Seltzman
Post by Andrew Seltzman »
The mks901p can use rs232 levels without an adapter.
Make sure the baud rate on the computer matches the gauge.
Andrew Seltzman
www.rtftechnologies.org
vivekanandan c
Real name: vivekanandan c
Post by vivekanandan c »
hi udayshankar , r u from india im from india too, have u completed ur fusor is it working
