Base Level Source - Rules for posting
Links to primary sources of hardware and other materials for the amateur scientist for assembly and operation of a fusion system. General useful supplies for the experimenter are also allowed. Make title specific to the URL supplied with any needed information.
We have to keep this post group clean and lean. This forum, right after the FAQs, is now one of the most valuable and important for the newbie. "Where to go to get stuff"
I deliberately loaded this area up with posts back in February 2021 hoping to cover all the bases related to fusor needs in hardware and supplies. However I can't cover every topic. Here are the rules!
Do not post to this form at the top!!!!!! See rule #1
1. Figure out what already extant base level source posting below is related to your new source covers click on that source posting. Enter a reply post there with your new found source that is spot on to that need. No general reply comments allowed! Period! You must post your new source as a reply in that topic's already extant original posting below.
2. If you find no place already in the listing to place your new URL, you will have to create a new titled post. The title must be ("base level source - xxxxxxx") the xxxxx is what new base level source you are supplying information on. It is hard to believe that you can't find another already extant post thread beyond those listed for your submission, but I can't foresee all things.
Note: Again No general commentary reply posts. All such commentary will be immediately erased.
Should you find that a supplier in any thread that is out of business or operating in such a way that is unfair or dishonest, post you commentary anyway in the related thread, referring to the post related to this supplier. I will then update the original posting with your commentary as a warning to others and then erase you commentary post.
We need to keep the area clean, neat, and without confusion.
Re: Base Level Source - Rules for posting
Pushed to the top of listing 12/10/21
Real name: Frank Sanns
Post by Frank Sanns »
This thread will now permanently stay at the top. I will delete this and your post Richard once you see it.
Thanks Frank. This is good to keep it up so folks know how to add new sources. All subsequent reply posts can be erased here.
Return to “Primary Sources for Fusor Related Items”
