Base level source: Fused Quartz & Alumina Ceramic tubing, rod, etc.
Links to primary sources of hardware and other materials for the amateur scientist for assembly and operation of a fusion system. General useful supplies for the experimenter are also allowed. Make title specific to the URL supplied with any needed information.
Post by Richard Hull » Sat Feb 27, 2021 5:38 am
QUARTZ:
https://technicalglass.com/product_page ... tz_tubing/
These folks are good source for high temperature quartz tubing, rod and a lot of custom quartz shaped tubing, including ball joint fittings in quartz.
ALUMINA:
https://www.advaluetech.com/products/al ... bore-tubes
For all manner of alumina products, tubes, rods, plates forms, etc.
Return to “Primary Sources for Fusor Related Items”
