FAQ - More on those devilish Russian Corona tubes
Another helpful post on the tubes along with in and out of moderator tests that will tell when you are biased correctly. Note Photos lost in xfer to Go Daddy, but all the you tube videos are where it really is in the quest to use these tubes.
viewtopic.php?f=13&t=12474
The classic Bob Higgins paper can be downloaded as a PDF at
https://drive.google.com/drive/folders/ ... VpNc2NhOWM
