Homemade Cathode Ray Tube
Jacob Shin
Real name: Jacob Shin
Post by Jacob Shin »
Hello everyone. This isn't a fusor or accelerator, but the cathode ray tube (CRT) was a precursor to the atom smasher, so I thought this might fit on this forum. A CRT is basically an electron beam accelerator/electron gun, so I thought it would fit under ion guns. This project is way cheaper than a fusor or a linac, and a little bit more interesting than a demo fusor. So I made this as my final project for school based on http://www.sparkbangbuzz.com/crt/crt6.htm. I used a cheap ebay single stage vacuum pump for pumping and a flyback transformer to power the CRT. Unfortunately, the CRT didn't work quite as well as I would have hoped and I currently have no way of measuring the voltage or vacuum level for the system.
Here's my setup:
A video of magnetic deflection: https://youtu.be/T7H3Pw8X9eo
The CRT sort of works. The electron beam makes the phosphor glow and magnetic deflection confirms that there are charged particles in the beam. However, I was never able to get a clear dot on the phosphor; instead, I always got a blob as you can see in the pictures above. This would have been the ideal result it worked: https://youtu.be/5gGddyFz3aQ. Unfortunately, since my setup never produced a distinct 'dot', I could never form any kind of images like the other guy in the video did. Is there any obvious reason why my phosphor has a 'blob' and not as focused? Could it be the vacuum level or the voltage? Would it be more beneficial for me to get a better vacuum pump, a thermocouple gauge of similar, or a high voltage metering system? Or are all these equally important? Thanks in advance for any input.
Re: Homemade Cathode Ray Tube
Post by Rich Feldman »
Nice work there, Jacob. I like the Helmholtz coils and compass on the bench.
About 10 years ago I played with the same sort of cold-cathode CRT. Like you, following Nyle Steiner and sparkbangbuzz.
It wouldn't hurt for you to set up instruments to measure the voltage, current, and vacuum pressure.
You might be able to sharpen up your beam with quicker, easier steps.
1. Make sure the DC current doesn't have a huge amount of ripple current. The HV side of your flyback power supply needs a HV diode, and, for this application, probably a HV capacitor. The doorknob style is popular; a Leyden jar or old CRT could also serve. With capacitor comes the risk of _much_ stronger electric shocks, even after you've turned off the power and pulled the plug.
2. Does the glow discharge go out if you pump long enough? If not, give some attention to vacuum leak abatement. What happens if you put a few drops of vacuum oil on the outside of the rubber stopper three contact surfaces? Or valve off the pump and observe the discharge for signs of pressure creeping back toward atmosphere. A shorter hose might help some. When you can achieve a pressure too low to glow, then you can _intentionally_ back off on the pumping.
3. Then play with the electrode geometry and distance to fluorescent deposit. IIRC, my anode was a strip of Al foil, with a pinhole, folded over the end of narrow glass tube inside the flask.
Post by John Futter »
Jacob
Well done
I woulod not expect a dot at that distance without a focusing element
the simplest of which is the einzel lens a triplet of elements after your elecron source
beam blowup at low accelerating voltages is what you are suffering from the electrons are repelling each other so the beam blows up in size.
as accelerating potential rises the electrons go faster so they have less time to move aprt (blowup) so the beam tends to stay focussed longer
hence the 30kv odd used in colour crts to maintain focus over quite a distance so that each colour pixel retained true in colour whether delta dot or trinitron
Real name: Mark Rowley
Post by Mark Rowley »
Hi John,
I made this one about 12 years ago. It was fairly easy to make a dot as long as the aperture was about the diameter of a pin hole. Focusing elements were not necessary but would've been nice and surely resulted in a much more tiny dot.
https://www.youtube.com/watch?v=nMOjiZR7R6U&t=
Mark
Nice job
but by focus I mean less than 0.1mm in diameter at the distance your tube was working --this compared to a colour CRT colour purity
or if we go further a SEM with an electron scan dot size of 20nm diameter or less
Albert Mery
Real name: Albert Mery
Post by Albert Mery »
Hi Jacob, nice setup.
I have also built a similar (less cool looking) Cold-Cathode CRT with a Flyback Transformer.
I was never able to find any proper specs for homemade Helmholtz coils, though.
Would it be possible to know, roughly, what magnetic field strength is seen as reasonable for such a use?
Thanks,
Albert
Jacob Shin
The Helmholtz Coil produced about 12 gauss and I just scaled up https://www.thingiverse.com/thing:3330563
