Ludlum 12-4-7 Dose Conversion
Joe Gayo
Real name: Joe Gayo
Post by Joe Gayo » Sun May 19, 2019 3:38 am
A have a calibrated Model 12-4-7 placed equidistant (and equal angle to my cylindrical systems) between to fusors to compare NPR. This arrangement is allowing me to compare performance of various modifications.
I would like a second check of my method for converting the dose read out to NPR. The detector is 82 cm from the centers of my fusors (and 15 degrees off-axis, the two devices and detect form a triangle). If the indicated dose is 32 uSv/h (3.2 mRem/h ?), then the NPR is 2.1E+6 n/sec. I used the gammaspectacular.com calculator and set # to 32, #/mRem to 10, cm to 82, and s to 3600.
Thanks.
Joe Gayo
Real name: Joe Gayo
Re: Ludlum 12-4-7 Dose Conversion
Post by Joe Gayo » Sun May 19, 2019 10:28 pm
