My first plasma
Re: My first plasma
Post by Dennis P Brown » Wed Sep 12, 2018 8:59 pm
The best course to take is throw away that glass chamber, buy a low cost Stainless Steel (SS) four way cross (50 mm dia.) and make that your chamber. Installing a decent window (1 cm thick glass) and a high voltage feed thru is very easy - that leaves a place to add a vacuum exhaust and gas feed line. This SS 4-way will not just make a vastly safer way to do fusion but relax's the voltage/current required to do detectable fusion, too!
See fairly recent examples of people using 20 - 25 kV and around 10 ma or so in a 50 mm 4-way and getting strong fusion neutron counts. Aside: I assume you have deuterium gas, a proper power supply, and neutron detection system since you indicated your next step is fusion.)
Re: My first plasma
Post by Richard Hull » Wed Sep 12, 2018 9:25 pm
I have given instruction on how to avoid direct hot beam contact with a viewport window in an all stainless chamber.
In short, mount you grid so that the north or south pole is viewed "dead on in the window. You may lose the pretty core image but the rays and beams will be seen well. There is zero chance a beam with emit from the juncture of the north/south wire bundle in the grid. Note: Your window will still slowly be occluded with deposition, but not be burned or stressed.
Fusor IV image attached in faux colors due to deposition on the window over long operational periods. This is normal and the reason a color camera is of no real value on a fusor that is, or has been, operated unopened or serviced, internally, over many months or years of use.
Looking directly at the pole of the grid
Eduardo_Machado
Real name: Eduardo Machado
Re: My first plasma
Post by Eduardo_Machado » Fri Sep 14, 2018 12:28 am
Hello,
Thank you all for advise and suggestions. We don't have a new chamber yet, but we are looking for a stainless steel one. For sure I will share my progress with you.
Regards,
Eduardo
