Couple of questions
steventw
Real name: Steven Whittam
Re: Couple of questions
Post by steventw » Tue Jul 10, 2018 9:11 am
This video pritty interesting too
https://youtu.be/uPU9cEK5YsM
Guess nere end he doing something similar to what I am
Trying 2 magnets with like poles facing I recon
Similar to what I’m doing
Problem with that is the bolt used to hold them probly mangantised
Post by Dennis P Brown » Mon Jul 16, 2018 5:25 pm
Spell check is your friend; best to avoid posting via cell phones.
steventw
Post by steventw » Thu Jul 19, 2018 11:54 pm
Tend to use phone these days more than pc
My pc I’m sure is compromised cause when I boot windows and logg in it brings up a command prompt instead of desktop
Good thing I know to type “explorer” to boot desktop 🤨
steventw
Post by steventw » Fri Jul 20, 2018 3:58 am
Here’s design I did today with measurements
Dad hopefully going to build housing when has some spair time at work
Post by Dennis P Brown » Fri Jul 20, 2018 7:24 am
OK; virus protection software can be your friend. Also, in the control panel, the System and Security menu has a sub-menu that has tools that are very useful for checking for errors and other problems with the computer (of course, do update to the latest version of "Explorer" and download all required MS system updates should be second nature.)
If you have backup your computer a "Mirror Image" of your system & files before it was compromised, then rebuild with that; if not unlikely you can save your data.
Then if your system has a really bad viruses that these anti-virus software programs can't remove, then your most likely recourse is do a restore to "Factory Settings" and then rebuild your system and re-install all updates - of course, this means the complete loss of all data files but that is the price one pays if they get a nasty virus and do not keep a "Mirror Image" of their computer system & data on hand.
steventw
Post by steventw » Sat Aug 11, 2018 4:42 am
Built housing for magnets and almost done
Hopen to test this arvo
steventw
Post by steventw » Sat Aug 11, 2018 5:48 am
Here’s the proof of concept
Just have to finish wireing for copper coils to create plasma
Prob be a few weeks till have time to finish
steventw
Post by steventw » Mon Aug 13, 2018 7:02 am
Ok gave it a go
But no plasma was being created and wasn’t drawing any amps
Theory’s anyone
MatthewL
Real name: Matthew Lallinger
Post by MatthewL » Tue Aug 14, 2018 1:53 am
What was your pressure?
steventw
Post by steventw » Tue Aug 14, 2018 5:52 am
-20psi
Tho thinking 30V 10A not enough from reading I’ve done today on forums
Also read need to ground positive side not negative
Maybe need to adjust how I’m trying to create the plasma
Only copper wire can get around here has the enamel coating.
Only need to create a small stream of plasma at base if magnets to see how it reacts with the magnets
At moment got a positive ring and negative ring at base of each magnets where is attached to frame
Is there maybe an easier way to create the plasma
