Hitachi hv supply
Thomas Sheeleigh
Real name: Thomas Sheeleigh
Hitachi hv supply
Post by Thomas Sheeleigh » Tue May 22, 2018 6:31 pm
Hi, I just recently got a retired x-ray transformer but I'm having trouble finding literature on it. I was wondering if someone could help me identify the connection ports. Also there seems to be something that resembles a filter sticking up (I realise it's not). Also I haven't gotten a chance to look inside yet. If the unit is rusted would that impact performance? Let me know if more pictures would help. Thanks
Re: Hitachi hv supply
Post by John Futter » Tue May 22, 2018 6:58 pm
Caliban or who ever
if you followed the forum rules you might get more response
first post should be the introduce yourself forum
you must use your full real name in both fields no handles ie Caliban to be used
Post by Richard Hull » Wed May 23, 2018 4:31 am
This is no toy, It is real the deal and can be the ultimate fusor supply that will not be killed very easily. the connection are labeled a bit arcane, but need to be metered and that might not tell the tale. One might make a guess based on the terminal designations.
Assuming it is on the norm for such systems. It is probably a 220 or 240 vac input the two terminals might mean it is floating but center case secondary grounded. Metering will assist here.
