Sources for Fusor Related Items
Use this forum to offer items for sale.
Real name: Frank Sanns
Post by Frank Sanns » Sun Apr 02, 2017 6:05 pm
Most people look to eBay and other sources to scrounge for their fusor items. I thought it may be helpful to create a sticky here in the trading post for the new people so they know where to find some of the more common items.
Feel free to add to the list and I will incorporate ones that I think are most appropriate. This is not so much for manufacturers but rather distributors of things useful for a fusor.
I will start by adding LDS as they have served many of us here on fusor.net very well over the years.
Vacuum fittings, flanges, adapters, pumps etc.:
LDS Vacuum Shopper http://www.ldsvacuumshopper.com
https://www.duniway.com
https://accuvac.com
Ceramic stalks, HDPE moderator, teflon, etc.:
https://www.mcmaster.com
Chambers, everything UHV:
http://www.lesker.com
Re: Sources for Fusor Related Items
Post by Rex Allers » Sun Apr 02, 2017 8:15 pm
Good idea, Frank. I 2nd LDS Vacuum, who I have used a few times.
Another vendor for new, mainly CF, Flanges and adaptors is:
AccuVac
Benicia, California
Description from their store:
Your one stop source for all your Conflat, ISO, ASA, and KF style flanges.
They list on eBay as -- turntek1
and have an ebay store -- High-Vacuum-Flange-Mart
I have found their eBay presence an easy and conveinient way to order.
I have bought CF 10" to 3.38" reducer flanges and some other stuff.
No complaints so far and fast service.
Not cheap, but, I think, good pricing for new stuff and a large selection.
More contact info:
(707) 745-0450 In California
(877) 888-0881 toll free
(707) 745-9542 fax
and webpage -- accuvac.com
Sarvesh Sadana
Real name: Sarvesh Sadana
Post by Sarvesh Sadana » Sun Apr 02, 2017 10:27 pm
Duniway stockroom is another good place for vacuum products. They offer several types of (rebuilt) pumps and other vacuum hardware.
They also have excellent customer service.
https://www.duniway.com/
http://www.ebay.com/usr/duniway?_trksid ... 2749.l2754
Post by Frank Sanns » Mon Apr 03, 2017 1:27 am
Thanks. Added.
Post by ian_krase » Mon Apr 03, 2017 9:24 am
LDS is particularly notable for their compression ports, which are very expensive from other sources.
Notably, Duniway has nicer KF clamps than most vendors.
https://accuglassproducts.com/home.php has a variety of feedthroughs including some highly specialized ones, ones with loads and loads of pins, etc. As well as other metal-glass sealed stuff.
Amazon has some basic KF fittings, Swagelok knockoffs, and a few other things. Not much, and rarely cheap, but sometimes worth attention and you can get fast shipping cheaply. Also, the cheapest way to buy small amounts of Macor ceramic is Amazon. Most of my KF clamps and centering rings are from Amazon
McMaster is very useful for O-rings, gaskets, and large-diameter short-length Pyrex tubes for demo fusor chambers. They also sell conflat gaskets in single quantities. Unfortunately they are quite expensive for many things -- but often cheaper compared to umpteen different shipping charges.
Ideal vacuum products (http://www.idealvac.com/) has a VERY broad selection of vacuum stuff including mech pump rebuild kits. They seem to be cheaper for some items and have a better selection of brass KF fittings. Have to say I'm intrigued by their Ideal Vacuum Cube module chamber but they are dear.
Ted Pella (http://www.tedpella.com/vacuum_html/) is mostly a biological microscopy store, but they sell a bunch of vacuum stuff related to electron microscopy and sample prep. I have never ordered from them.
You can buy inexpensive mech pump oil from the auto parts store. I don't know how it compares, but I get to 8 microns just fine with my blanked-off pump.
David Kunkle
Real name: David Kunkle
Post by David Kunkle » Mon Apr 03, 2017 2:44 pm
http://www.theoringstore.com/
They have every size and material imaginable. Good for weird sizes, custom apps, and rebuilding ancient mystery equipment like my 1/2 century old Edwards leak valve. Minimum quantities are usually 1 to 6 of each, but at pennies a piece, I usually buy the next sizes above and below the size I think I need and use the one that fits best. Shipping is usually 5 to 7 dollars. My orders are usually about $10 to get everything that I need.
Ernest Rutherford
Jim Stead
Real name: Jim Stead
Post by Jim Stead » Mon Apr 03, 2017 4:21 pm
BMI Surplus carries vacuum parts, feedthroughs, etc. http://www.bmisurplus.com/
Because they are surplus, availability and pricing changes. But, I've found some good deals there.
Tom McCarthy
Real name: Tom McCarthy
Post by Tom McCarthy » Mon Apr 03, 2017 6:53 pm
Robin Whyte from the forum, goes by the username fizz runs recalvac.co.uk - UK based supplier for all sorts of parts, gauges, fittings. His email is recalvac at aol dot com
Post by Richard Hull » Mon Apr 03, 2017 6:55 pm
I have used Ted Pella a bit for their fabulous line of graphite applications. ian supplied their URL above. The one below leads to their conductive coatings.
http://www.tedpella.com/SEMmisc_html/SE ... htm#_16058
They have graphite pastes and thick liquid applications using a brush as well as thin, watery applications using a brush, but more importantly, spray cans (aerodaq - G) for graphite application.
These coatings are often termed a form of acquedaq. (conductive coating used for shielding or electrostatically conductive surfaces.)
I use it for manufacture of conductive shield coating of thin diaphrams for ion cambers and mica windowed GM detectors as well as outer shell GM countings on glass.
Graphite coatings are fine for use as light weight capacitive surfaces of electrostatic motors and other experiments in this area, etc.
Note: the graphite coatings have effectively zero resistance to electrostatic voltages, but for current carrying apps the very expensive thick silver coatings are to be preferred.
Jeremy Sims
Real name: Jeremy Sims
Post by Jeremy Sims » Tue May 09, 2017 2:41 am
If you are having trouble finding deuterium easily:
Global Rare Gases
contact: James J. Avolt
Email: jimavolt@globalraregases.com
Ohio Office: 6964 McNerney Drive, Northwood, OH 43619
50L lecture bottle @ $260
Expect about $100 shipping for hazmat to a business address.
