A theory of a possible method of fusion
frostyk72
Real name: Steven Whittam
Post by frostyk72 » Fri Oct 14, 2016 1:09 pm
Fusion idea 15th October 2016
Plasma appears to spin around magnets on field lines
In theory this array of magnetic fields might have plasma spinning
opposing direction to next magnet And Might over lap plasma lines
and maybe increase chance of fusion.
\/ shaped sphere of magnets.
North Pole of magnet +
South Pole of magnet -
magnet \ and /
Same field of magnet facing next one.
Welded in place by a small rod between in centre
in a curve to make a sphere
Re: A theory of a possible method of fusion
Post by John Futter » Fri Oct 14, 2016 6:24 pm
How about reading the forum rules
real full name
I know you joined a few years ago but the rules have changed
please ammend
not following these simple rules puts you in troll territory
frostyk72
Post by frostyk72 » Mon Oct 17, 2016 10:08 am
updated my profile and put my real name in.
is Steven Whittam
steventw
Post by steventw » Mon Oct 17, 2016 10:17 am
sorry had been awhile since logged in, logged in with old account.
anyway relised had account with my name in it and recovered password.
steventw
Post by steventw » Mon Oct 17, 2016 11:34 am
made a small picture in paint with a possible tokamak configuration,
Charles Snyder
Real name: Charles Snyder
Post by Charles Snyder » Tue Oct 18, 2016 12:26 pm
Is this experiment similar to your idea?
https://www-internal.psfc.mit.edu/ldx/
KalebWagar
Real name: Kaleb Wagar
Post by KalebWagar » Tue Oct 18, 2016 11:56 pm
Steven -
I like your configuration, but I don't think you've modeled the fields correctly. If you were to use the electromagnet configuration that you posted, you'll get behavior more akin to what I've posted in the attachment. (Go Paint!)
Because the magnets are layered in opposites, you've essentially created layers of plasma that interfere with each others' flow and cause collisions. This COULD lead to more fusion, but if the collisions aren't high enough in energy, not enough will fuse to make it worth the energy.
Note in my rough sketch that I also pointed out some low energy plasma points. The distance from the magnets and the interference from the wall serves to 'slow down' the plasma. The inner tube, inside the coils, is basically just a mess of opposite, linear, homogeneous magnetic fields that trap and squeeze the little plasma that enters into messy, low energy knots.
steventw
Post by steventw » Fri Oct 21, 2016 6:56 pm
Charles Snyder wrote:Is this experiment similar to your idea?
Had a brief look
Doesn't appear to be from what I read
steventw
Post by steventw » Fri Oct 21, 2016 10:29 pm
second attempt at paint shopping idea.
a possible fusor type configuration for testing idea.
would just take some fancy grid work to make it work.
steventw
Post by steventw » Sat Dec 10, 2016 10:36 am
made a more simpler idea so easier to understand.
