Electron gun- what's wrong here?
Re: Electron gun- what's wrong here?
Post by Steven Sesselmann » Tue Aug 23, 2016 12:56 am
David,
That's correct, whatever power supply you use to heat the filament needs to float, so you need an isolation transformer.
In a fusor situation it is unlikely that you will need 10's of kV isolation because (as you discovered) you only need a few hundred volts to 1000V on the filament to make it emit electrons, those electrons will ionise some gas and keep your fusor lit at low pressures.
David Kunkle
Real name: David Kunkle
Post by David Kunkle » Wed Aug 24, 2016 11:59 pm
Is there any problem with using a battery for the filament PS? I had a 12V lead/acid motorcycle battery in mind. The whole battery would be floated to whatever HV potential is used on the filament.
Ernest Rutherford
Post by Steven Sesselmann » Thu Aug 25, 2016 12:15 am
David,
No problem at all, I do the same on my rig, floating two 18V cordless drill batteries to power an MFC a USB hud and a DAQ.
Check the current draw and work out how long the battery will power it.
David Kunkle
Post by David Kunkle » Thu Aug 25, 2016 4:35 pm
Thanks. Just wanted to make sure. It sounded OK in my head, but on the other hand, I could do without a battery exploding. I'll just make sure it's electrically insulated well enough from everything else.
My filament will use 6W @ 12V. So it should last many, many times longer than I need before I'd have to recharge if I go with the motorcycle battery.
Ernest Rutherford
Post by Rich Feldman » Sat Aug 27, 2016 7:09 am
You can also electrically float a cordless drill with _no_ batteries, and use its motor as a generator.
As shown on fusor.net in 2010: viewtopic.php?f=11&t=4771&p=27609
The old image thumbnails have not been treated nicely.
