I achieved plasma today, after quite a few weeks of work.
This run was at 5e-3 mbar, at approx. 1.5kV. I left it running for about a minute or so and captured this photo in it.
My grid is 0.4mm Titanium wire attacked via a terminal block inside part to my 30kV feedthrough.
This is my fusor trolley in situ. I tried operating it in daytime but saw nothing so waited till after dark and it worked!
Here’s another photo of the setup, more close up and shows vacuum system better.
I’ve designed it so that there is no hole smaller than 0.75” diameter to the chamber for maximum pumping speed. The tiny flex tube attached to the diff pump was merely to save buying a stopper.
Any questions, feel free to ask. Sorry it’s a bit short, I’m quite excited about it and don’t know what else to add.
Edit: Photos, not photons!
Although, it’s not exactly wrong
Plasma, and photons of my built demo fusor
- Real name: Luca Aldridge
Luca Aldridge
Re: Plasma, and photons of my built demo fusor
Luca, I have admitted you to the plasma club. Nice work!
- Emma Black
- Real name: Emma Black
Nice one! it's great to see this coming together. I like the trolly with the slotted angle, that stuff is very handy.
Thanks Richard, I appreciate it.
Emma, thank you too! Yes, I wanted slottted angle to maximise “modularness” of the trolley looking forward.
Luca Aldridge
I have used that right angle, commonly available, steel rail with the holes in it. It is still in place supporting my fusor table and the fusor platform against the gray backdrop. It is very ugly to look at, but very inexpensive, quick of assembly and very functional for those with a lot of bolts and no power drill or who don't like drilling holes in metal with a power hand drill.
I attach and Images of the current table framework taken back in 2004.
I agree. for a nonpermanent setup it's ideal and is why I used it. Sometimes holes don't line up so you have to drill holes anyway in the metal.
Personally I'm not too bothered about looks, and it means that they whole thing is already grounded.
Luca Aldridge
