Presenting rules and new users
Some time back I created a message to post to a new user who had not abided by the "Firstname - Lastname" rule as a username on the forum.
In writing that post message I used some BBCode tags to add formatting like Bold or Bullet Lists. I think this makes reading and digesting the content much easier than an attempt with just simple text. Richard recently noticed one of these posts I had made, approved, and suggested it might be good if others used my message when appropriate.
I had no problem with this and have shared a text version with the BBCode formatting in the past. However, if someone just copies the contents one of these messages I have posted to use themselves, the formatting in my message is lost and it is harder to read.
I was working on a good and easy way to share my message with formatting so others could copy and use it. I think I had a good way in mind but in checking some things on our forum board I realized my message begins with a lie so I no longer plan to share it or nag new users.
---- fusor.net we have a problem ----
At the beginning of my message I say:
"When you registered you clicked to accepted the terms that were given on the 1st registration page: "
This is true, and I then go on to explain the rule they missed about using their real "Firstname - Lastname" when they select their new username. To fix their situation I later explain how to change it.
*** But ***
Currently on our board that first page they see and agree to is just a boiler plate message that is a default part of the phpBB software. They never see anything related to our actual fusor.net rules.
So my 'change_username' message is based on a lie.
-- Some History --
I am pretty sure it was in 2017 when I realized that new users, when they register and "Agree" were never seeing anything specific to fusor.net.
I knew how to change the text that is presented, but unfortunately it requires an edit to one of the php files that comprise the software of the phpBB board we use.
To change the user agreement one must find the proper php software file (and it is possible there are more than one), use an editor to find a specific tag in the file that marks the text string and replace the default string, then save the file.
In 2017 I exchanged a series of emails with Frank, who agreed it would be a good idea. I supplied instructions, and the new formatted text, and eventually we got an agreement page specific to the actual rules of fusor.net.
The updated agreement page message was the same as Paul's "The Rules" from the admin section of the board except with a bit of formatting like Bold to make the key points more obvious.
In 2019 the site move or some other update caused the edited php file to be replaced by the phpBB default software version. I contacted Frank and he had lost all info on how to make this edit. Eventually we swapped enough messages to again edit and present a fusor.net-specific agreement to new registrants.
Currently (Aug 2022) I have just noticed that the registration agreement is back to the phpBB default.
--- Tweaking an accessible "The Rules" ---
In the "Announcements and Site Administration Topics" of the board there is a sticky message at the top of the Topics:
" Fusor.Net Policies and Procedures"
Post by Paul_Schatzkin » Mon Dec 14, 2015 5:47 pm
viewtopic.php?p=69690#p69690
Near the top of that message is the section titled:
"The Rules"
with four numbered rules.
This section was the basis for what I suggested should be presented to users at the beginning of the registration process. (What I just described about making it fusor-specific above.) The Rules are the same except that I added a bit formatting like Bold to make key points more obvious.
Somewhere in that 2017-2019 range I created a BBCoded version of the The Rules section that someone with full editing privilages could edit into Paul's Admin sticky message to give it more visual oompf.
I think this editing was done at one point but the current message is back to its 2015 original formatting.
One other small point...
the first line of The Rules section in the sticky message is:
"The Rules: (updated 151214) (From http://fusor.net/board/ucp.php?mode=register"
That link points to the agreement page a new user sees in registration; it currently is the default boilerplate from phpBB, nothing to do with fusor.net rules. The reference should be deleted.
---- My Summary ----
- I think the file edit should be made again to show a new registrant a page with our actual fusor.net rules for them to agree to.
- I think it would be nice to have the Rules section of the sticky admin message edited with the formatting (Bold, etc.) that I provided in the past.
- In the mean time, I don't plan to share my 'change_username' message and I intend to stop nagging new users who didn't register with "First-Last".
I have here saved copies of the formatted text of the fusor registration page. I also have a formatted version of the "The Rules" section in the Admin message that could be edited in (and more readable IMO).
I'm not real excited about going through another email chain on how to accomplish this. If I had the necessary access permissions I could do the changes myself in a few minutes. I volunteered to help in the past but it became apparent my help was not needed or desired.
*** But ***
-- Some History --
"The Rules"
Re: Presenting rules and new users
Use code tags:Rex Allers wrote: ↑Fri Aug 05, 2022 7:55 pm I was working on a good and easy way to share my message with formatting so others could copy and use it.
Code: Select all
[list]
[*]Default line 1
[*]Default line 2
[/list]
[list=1]
[*]Numbered line 1
[*]Numbered line 2
[/list]
[list=a]
[*]Lowercase line 1
[*]Lowercase line 2
[/list]
[list=A]
[*]Uppercase line 1
[*]Uppercase line 2
[/list]
[list=A]
[*]Parent uppercase line 1
[list=a]
[*]Nested lowercase line 1
[/list]
[*]Parent Uppercase line 2
[list=a]
[*]Nested Uppercase line 2
[/list]
[/list]
Produces.
- Default line 1
- Default line 2
- Numbered line 1
- Numbered line 2
- Lowercase line 1
- Lowercase line 2
- Uppercase line 1
- Uppercase line 2
- Parent uppercase line 1
- Nested lowercase line 1
- Parent Uppercase line 2
- Nested Uppercase line 2
There is an extension for this:Currently on our board that first page they see and agree to is just a boiler plate message that is a default part of the phpBB software. They never see anything related to our actual fusor.net rules.
https://www.phpbb.com/customise/db/exte ... agreement/
Coalman, good to see you still posting here.
Yes, I am familiar with BBCode. For sharing it, I had decided CODE boxes in a message post was probably the best option. I'll do that later in this message.
I like the extension for changing the user registration page. I was looking for a solution like that, I guess, just before that extension was authored. All I could find was descriptions of editing ucp.php, which is what we did here on the forum a couple of times. Obviously that edit is lost if the phpBB software is updated, replacing ucp.php.
The extension is safer and uses BBCode formating. Editing ucp.php needed html tags for formatting.
As you were writing your message I was in the process of installing WAMP here and then phpBB under that. After a simple install I read your message and then got the "customregistrationagreement" extension and installed it. (Took several tries to figure out what part of the unzipped to copy into 'ext/'.) So, it gives the admin an edit window just like a new message and it can process BBCode tags.
Here's the BBCode version of "The Rules" that I created and pasted into the extension's input.
And here's a capture of what a new registrant sees.
I think it would be nice if someone with admin privileges would do the same on fusor.net.
I also suggest that Paul's sticky message in the Admin section might be edited replacing the simple text section of "The Rules" with my BBCode version.
Code: Select all
[b][size=150]The Rules:[/size][/b]
(updated 151214)
[b][size=120]By registering for membership in this site, you agree to adhere to the following terms and conditions:[/size][/b]
[list=1]
[*]The first rule of membership in these forums is:
[b]You must create your account using your [size=120]real, full, [u]first AND last names[/u][/size] as the LogIn/UserID for your account[/b].
If your name is John Smith, your UserID (i.e. login handle) must be John Smith, or John_Smith. This is the name that will appear in the forum listings. “JSmith” or “JohnS” or “JS997” or “handles” like “MrFusion” or “ProtonBoy” are [b]NOT permitted[/b].
New accounts that do not adhere to this simple rule will be summarily deleted without any further consideration. Any questions? OK, rolling right along…
[i][/i]
[*]New members are required to introduce themselves with a [size=120][b]first post[/b][/size] in the [size=120][b]"Please Introduce Yourself" forum[/b][/size] prior to posting elsewhere on the site.
[i][/i]
[*]The following types of content, and any links to such content, are prohibited and subject to immediate deletion: obscene, vulgar, or sexually-oriented material; ad-hominem attacks; legal threats; displays or endorsements of unlawful activity; commercial advertising of any kind; solicitation of funding for individual projects or initiatives of any sort.
[i][/i]
[*]All content posted must be one’s own, or attributed to the creator and used with permission.
[/list]
If you have any issues with these protocols (particular #1), you are welcome to contact the site admins: admin@fusor.net
Great effort and work, Rex.
Much needed. I think Frank or Paul will agree and help out.
- Site Admin
- Real name: Frank Sanns
There is SO much about this site that is frustrating. YEs, I was aware of the registration problem. Thanks for working it out again REX. It is a simple procedure that I can do in literally a couple of minutes.
My problem is that I can no longer access the site from my Mac. The Windows computer that I purchased is finicky and has locked me out of the ftp login procedure AGAIN. I need to go through the new software and reestablish the secure connection so I can gain access with my ftp client.
There are other minor things that I need to do on the site too but like I said, it is a PITA over the year. Trivial things become monstrously complex because of softwares and formats. It will get done in the near future and will be the first thing once I am back into the site.
You have been "adopted". There was a lot of effort put into trying to fix what I could and if I'm more than happy to help going down the road.
Frank, I just tested the sftp connection and it works fine. Keep in mind that WinSCP will remember the last directory you were in, If the last one was the files directory it can take a while to load. If the screen says "Loading directory" that is the issue.
You can prevent this by being in another directory when closing WinSCP. You can also go into the advanced options and uncheck remember last directory.
- Paul_Schatzkin
- Site Admin
Thanks, guys, for catching this.
My recollection of how phpBB works is that the page a new user gets when he creates a user ID is buried somewhere in the .php files. What I am reading here seems to confirm that.
And I surmise that what happened is that when The Coalman set up our newest installation, that default file was baked into the set up.
So that file has to be replaced and could probably stand some fresh editing and I think Rex is right that it needs to be marked up so that the essential elements (i.e. "First and Last Names Only") are clear to the reader.
I wonder if we have that old .php file lying around in a backup somewhere. If not I can start fresh from the post that Rex highlighted from the Admin 'rules'
Marking it up sounds a bit more complicated. but I can get into it tomorrow or else over the weekend.
Does that sound like a reasonable course?
--P
--P
Yes, by all means use Rex file. It looks good.
Paul,
Good to see that you support changing the registration agreement page a new user sees and also editing a prettier version of "The Rules" into your admin post.
But it seems you missed some details that have developed in this thread.
Editing the file ucp.php is the method I found 7+ yrs ago for changing the registration page. It works and is the method we have used in the past.
In one of the posts above, thecoalman pointed out that there is now (since about 5 yrs ago) a phpBB extension that makes it easier and safer to change the content of that page.
Repeating that here...
" ...customise/db/extension/customregistrationagreement/"
When I saw that, I had just installed a small test phpBB board on my windows PC here. I downloaded the zip of that extension and installed it. It gives the admin an edit box for the registration page that looks just like a user's new message edit box. I pasted my BBCode version of The Rules into that box and saved it. Worked fine. I shared the results here as a screen capture a couple posts up. You probably need to click on the thumbnail of that capture in my message to see a readable bigger version.
If that looks ok to you, you can copy my BBCode from the 'CODE:' box in my message above. Click on 'SELECT ALL' and copy the selected text. Paste it into a local text file for future use. If there is anything in my capture image of the rules that you would like to change, I can do that.
With full editing permissions to your admin message, my BBCode can be pasted into your message to replace the simple-formatted text that is there now.
I've left out some details in these descriptions. I'll send an email to the address I have for you. We can discuss more via email if you would like.
Rex Allers wrote: ↑Wed Aug 10, 2022 7:31 pm Editing the file ucp.php is the method I found 7+ yrs ago for changing the registration page. It works and is the method we have used in the past.
Actually it's /language/en/ucp.php, The agreement is right at the top. you need to be careful with some characters, specifically apostrophes because they will be interpreted as php code instead of text string. You can use HTML entities instead.
https://www.w3schools.com/html/html_entities.asp
The extension is much easier however extensions can have issue with new phpBB updates. Typically you need to just disable it.
I like the extension method for a few reasons over the ucp edit.
After trying it on my simple test phpBB install, it seems to still work. So from 2017 when it was developed to the current phpBB version now. I realize it could break in the future. I think any update of the phpBB software would require the ucp to be edited again. That's where we are now.
Moot for me. I don't have authority to do any of this stuff on fusor.net.
thecoalman, have you seen the email Paul sent and I added a follow-on email? It was sent to a different email addy for you than I had used once in the past. This one had 'nep...' in it.
- Paul_Schatzkin
- Site Admin
I have some time to address this over the weekend, but more so next week.
Still waiting to hear from Scott (aka The Coalman).
--P
--P
Correct, for example if you look in the ACP >> Customise* >> Click the manage extension link on the left. There is already one installed for the custom header image.If I re-read it all right, there is an ‘extension’ to the base phpBB code that creates - a module - that makes it easier to revise the User Registration agreement, is that right?
There is numerous extension available: https://www.phpbb.com/customise/db/extensions-36
Don't go crazy, extensions can break with phpBB updates. When you are updating phpBB files disable all of them and then reenable one at a time to determine thy are still functional without error. Biggest mistake that is made is while updating extensions or removing them. Follow the directions carefully especially for removing them.
I uploaded the registration extension and added the text provided by Rex. You can edit under the extensions tab in the ACP.
*Customise is spelled correctly because you only have the British language pack installed.
Thanks Scott (thecoalman) for installing the extension and updating the text of the main Registration page.
Could someone with full message editing privileges edit Paul's Admin message and update "The Rules" in there with my BBCoded version for just that section. My code is in the CODE box a few messages up in this thread. Same stuff as thecoalman used for the new Reg page.
Here's an image with the section to be edited highlighted.
- Paul_Schatzkin
- Site Admin
Thank you, Coalman.
I just went into the new user routine and see that the 2015 rules and regs show up just as Rex shows them in his screenshot.
I just read the part where Coalman says he created the new rules w Rex's BBCode, so, are we done here?
--PS
--PS
Paul said, "so, are we done here? "
Sigh, No, not done in my opinion.
For the (N+1)th time, and as I said in the post just preceding yours, with another pretty picture...
Paul, could you please edit your Admin post:
to replace the "The Rules" section of the posted content (highlighted in my last post) with my BBCode pretty version, so it matches the formatted style that is now in the newly updated new user Registration page.
If no one, with full edit privileges, will do that... I give up. I'll stop trying to improve site-related issues and just fade back to being a passive user.
- Paul_Schatzkin
- Site Admin
Ah, that detail.
Done.
--P
Done.
--P
Well, a little cleaner. But you did not use any of the BBCode formatting I created and shared in this thread.
I'm tired. I know how to do it but can't. I give up.
Equus mortuus.
Equus mortuus.
- Site Admin
I just reviewed the code and the agreement and it is exactly as you have posted Rex. What else do want to have done? The agreement is clear with various text sizes, spacing and bold elements.
It looks fine and consistent with your original code window.
Frank,
-- Open it in edit mode.
-- Copy the BBCoded version of text I shared above. It's in a CODE box.
-- In the message edit window for Paul's message, select just the section of text for "The Rules"
-- Paste my BBCode to replace that section.
-- Hit the "Preview" button to see the edit results.
-- If it looks ok, hit "Submit" button.
There could be several variations on how to cut and paste my BBCode but that is my description of one basic method.
Here's the link to the message that I am talking about:Rex Allers wrote: ↑Mon Aug 15, 2022 9:49 pm Paul, could you please edit your Admin post:
- Site Admin
Rex,
I genuinely do not know what you want pasted. The only code is what was already pasted in place. I have taken YOUR code and pasted it into the bottom of the registration page. The code and the result look identical to me so I don't know what you are asking for.
Either you are not pointing to the right code or the cache is not cleared on your computer for you to see it. I just cleared the board cache so it should force a hard reload of the site for you.
Frank,
Hi.
I know your intentions for managing the site are only positive. Kudos.
I have spent hours trying to document how to edit a message for the only two admins of the site who ever monitor it, yet it yields frustration.
If one of you would trust me again, (many of us once had universal edting privileges [though Frank denies it]), and deign to grant that edit-any-message privilege again I could just do it.
Thecoalman quickly understood and used my BBCode to create the new user Registration page that we now have. (Yaay!) As I said earlier, thank you to thecoalman for doing what our admins should have been able to do without your help.
The current online version of "Paul's Message" does not contain the BBCode that I provided and was used for the new registrant page. All the words in the content is the same -- no suprise since my BBCode version is based on Paul's source.
But checking now, Paul's site message in the "Announcements and Site Administration Topics" it does not contain *my* BBCode in the visible online "The Rules" section.
It gives the rules, but not in the full format of my supplied BBCode edit.
I tried two different browsers to be sure.
Here follows another attempt at an explanation.
I now have a very simple phpBB forum installed here for testing stuff. On that I posted a simple text version of Paul's message. Then I edited the "The Rules" portion with my BBCode version of "The Rules" that I have shared here.
Here is a screen capture from my test board of the result and what I expected to see on Fusor.net.
Here is a capture of the current Fusor page with numbered notes of why it is not the version I provided.
Here is another posting of my BBCode version of the rules that I shared earlier.
Your move...
Hi.
Code: Select all
(updated 151214)
[list=1]
[i][/i]
[i][/i]
[i][/i]
[/list]
Your move...
- Site Admin
Rex,
The fact of the matter is that the code was properly placed on the first attempt. I reviewed the code and it looked identical to the first of your code that was posted. Still, I put it up so that the original plus the one that I added for you could be viewed on the same page. They look identical with the proper format showing.
Today, I have added your fresh code post exactly as you have requested. It is now the 3rd iteration on the page. They all look exactly the same and show the exact text sizes and bolds that you are requesting. Your pointing fingers that we are doing something wrong is unfounded. It was right the first time but I have done the 2nd and 3rd to be sure I was not missing something.
Here is what somebody trying to register sees from a screenshot of the page right now. All three of your coded version are there.
Geez Frank,
Current discussion is not on the new registrant page. Yes, thecoalman solved that.
The open issue is the content of Paul's sticky admin message that I think should visually be the same.
Thought on why the sticky should be the same as new registrant message...
After they register I can't point them to the original (try it, that page is only available if you are not registered).
So in my opinion the sticky admin message that we can reference should match what we wanted them to agree to when they registered.
