Two fitting questions
Luca Aldridge
Real name: Luca Aldridge
Post by Luca Aldridge »
Hi,
I’ve got an odd sized fitting on a valve and cannot find it anywhere on the internet. It’s not ANSI, ASA, or ISO-F.
Drawing:
Also, does anyone know what these are called? It says ISO 25 on it.
Luca Aldridge
Re: Two fitting questions
lucas
second pic is early foreline stuff from multiple vendors. i'm conversant with these from Edwards. very simple with standard O-rings on the removeable short piece of pipe. Most of the foreline valves using this system will now have had the rubber gasket / operating piece go hard
Luca Aldridge
Hi John
Thanks, none of my O rings are hard at the moment.
Do you know what they are called? I need to get an adapter from KF to that.
Luca Aldridge
I think they were called speedivac fittings
Luca Aldridge
Thanks for that, I can save $60 on an inlet adapter now.
Luca Aldridge
