questions about vacume tech
seamus sullivan
Real name: seamus
Post by seamus sullivan »
for a demo fusor do i need to buy a vacume chamber, or should i just use a vacume pump to sustain a vacume in a sealed container.
this is for ma demofusor, meaning i won't put duterium into this one. for duterium amature fusion, i know i should use a vacume chamber, but what aout demo.
thanks
Re: questions about vacume tech
The FAQs contain full information on making a demo fusor chamber or vessel. Their have been many forms used in the past. Check out the Images du jour forum.
ian_krase
Real name: Ian Krase
Post by ian_krase »
But that's exactly what a vacuum chamber is: a sealed container in which a vacuum is pulled using a vacuum pump.
