Institutional Quackery
Joe Gayo
Real name: Joe Gayo
Post by Joe Gayo »
Author claims to have produced 49.8 Watts of fusion power and breed appreciable levels of tritium ...
https://ieeexplore.ieee.org/document/5234046
It would be funny, except it's a published paper in a journal with actual science.
Bakhoum.pdf
(315.41 KiB) Downloaded 544 times
Cai Arcos
Real name: Cai Arcos
Re: Institutional Quackery
Post by Cai Arcos »
¿Is this for serious?
I mean, it's the IEEE.
¿Could it really be fake, and still be published in such a presigious institution?
Dan Knapp
Real name: Dan Knapp
Post by Dan Knapp »
I read this paper several years ago and noticed things that suggest this is a proposed fusion reactor and the data shown are only calculated simulations. I think the author failed to clearly point out that he hadn't actually built the reactor and demonstrated its function. Some flags are: 1. It is a single author publication. One would have to question whether a faculty member, particularly at a relatively small undergraduate institution, likely with a high teaching load would have the time to build and operate a revolutionary new type of fusion reactor single handed. 2. The paper is very thin on experimental detail. 3. The paper discusses D-T fusion. The few laboratories that have done fusion with tritium have spent years and millions in preparation for handling tritium.
I too was surprised that an IEEE journal would have published this in the form presented, but I think the title of this thread is inappropriate; I see no reason to impugn the institution. In the author's defense, perhaps he thought it was clear that his paper described a proposed reactor. I think the primary culprit here is the editor who handled this paper submission and failed to require revisions that clarified the question.
Joe Gayo
Real name: Joe Gayo
Post by Joe Gayo »
Dan,
Under different circumstances I would suggest you read the paper again, but I don't want to waste your time. The author very clearly claims that he made neutron measurements with a LND model 2801 detector (Section IV C) and, in multiple places, that the experimental results correlate with his theoretical work. (And just for good measure he adds the Debye length equation and then fundamentally misunderstands it. Glad he had the NRL Plasma Formulary handy - https://www.nrl.navy.mil/ppd/content/nr ... -formulary - it's free).
I was using the term "institutional" to refer to journals and professional science and the pressure to publish. Whether or not the peer review system is broken has been debated by the scientific community but, in my opinion, this paper demonstrates that extraordinary proof isn't required of all outrageous claims.
Joe
Another attempt at saying real soon now. Interesting, but it doesn't feed the bulldog. Lots of computation, yet little idea about the capability of the reliability of the neutron measurements in burst mode where RF might be an issue.
A few important issues: The author states: "A basic calculation will show that the fusion triple product
has a value of approximately 1.5 × 1019 s · m−3 · keV." Without giving the volume that this 'density/energy' value was determined for, this is an extremely mis-leading statement. In fact, without providing any obviously required value for the achieved volume for the device, the author states: "Of course, the regions shown in the figure where the break-even condition is exceeded are very small regions ...". All I'll say here for my part is 'duh.' Essentially worthless experimental result here making a totally imaginary claim for a real experimental setup! One needs actual data to support both claims - volumes are essential. Many devices can achieve those levels of ions/energy/density in ultra tiny volumes.
In fact, without that actual volume information, getting such a value in that setup is trivial and very misleading. As for his simulation that he achieved criteria that far exceeds tokamak values, I'll just leave that as total B.S.
The following statement is just wrong when used out of content to the reference: "Theoretically, a deuteron or a triton inside the confinement zone will remain indefinitely confined until one of the following two conditions occur: 1) fusion or 2) scattering by means of a 4He nucleus (alpha particle)" If this was true, fusors would be massive nuclear fusion devices. In any vacuum that is not perfect, scattering occurs for many, many reasons and this usage in his calculation is so idealized as to be a extremely misleading statement. This makes me wonder if this person understands any real fusion system at all.
The author talks a great deal about simulations for data values he produces; ok, not very good idea for an experimental paper and very misleading for me to believe some of his claims but that is another matter.
Here is a key error and invalidates most of the paper: "The energy produced by the apparatus, as well as its efficiency, can be calculated in a straightforward manner from the fundamental theory developed by Lawson [7]. We shall assume that the gas mixture is heated to a temperature T ..." (bold and italics are mine)
Ok, I'll assume all my fusor ions are at the same fusion level 'temperature' and I too will get amazing results ...lol.
Here is the most glaring error and completely invalidates his fusion results via heating.
The author claims he calculated the net energy created by his power supply but says:
" ... it should be first mentioned that the current injected through the electrodes was approximately 0.1 A. "
(again, I added the bold and italics)
A current to only one decimal place and worse still, is said by the author to be "approximate"! Really! Then this is multiplied by his 10^+6 volts. Talk about propagation of errors! Uh, that means his error bars far, far exceed his energy calculations for any fusion! This error completely invalidates his claim for fusion energy alone.
If anyone wants to read the rest of the paper - especially determine how he made neutron measurements - do feel free. I have better things to do after that one.
Last edited by Dennis P Brown on Mon Jan 21, 2019 6:11 pm, edited 6 times in total.
Patrick Lindecker
Real name: Patrick Lindecker
Post by Patrick Lindecker »
Hello,
I read this paper and found it very interesting even if it is a quackery, because it is suggesting, at least, ideas (but questions).
For example, it is suggested that negative ions and positive ions be generated by field effect (as GFIS ions sources), at least to minimize the space charge problem.
Implicitely, I suppose that for the negative ions (left part), a part of the provided electrons will attach to Deuterium atoms (and molecules) to provide D- or D2-. However, the efficiency will be low and consequently the number of negative ions will be very inferior to the positive ions generated by the right part.
Moreover, as far as i know, the current provided by GFIS is very low (10 nA max). However, the paper speaks of 100 mA, which seems very important compared with 10 nA.
As I am not a specialist of ions sources, can someone explain how works such ions sources system (supposing that it could work).
Patrick Lindecker
Patrick Lindecker
I answer to my question (☺): probably the author was thinking of an arc discharge. Among the ions, positive ones will certainly be created in an enormous majority and negative ions (generated by attachment at the negative tip, due to the very big field effect ) in a weak number.
Dan Knapp
Post by Dan Knapp »
This discussion prompted me to read the paper again. I also contacted the author to inform him that his paper was under discussion, and that he might want to weigh in to defend it. In his reply, he stated that he did actually build and test the device, but not at his present university. He said the work was done in a earlier position in a research organization. I still have a lot of questions about the report, and I hope he will join the discussion.
One thing is clear, however. Fusor.net has more rigorous requirements for documenting successful fusion than the IEEE journal.
I replied to this thread yesterday but it dissappeared down the dark hole
field emmission as you have pointed out is limited by the munber of emmiters per square area you have to satisfy the Fowler Norheim conditions for it to happen you are doing well a few mA per sq cm emmiter surface.
Negative ion sources are difficult at best with the best using hot filaments to heat LaB6 crystals to get an extremely intense free electron cloud that may produce a few negative ions.
So the paper is a word salad made up from some real science that is not being used correctly
Joe Gayo
Real name: Joe Gayo
Post by Joe Gayo »
I also contacted the editor and chief of IEEE and he said:
" If you have any formal comments you would like to send us, we would review and possibly publish them, giving the original author a chance to reply."
I think I might ...
Dan Knapp
Post by Dan Knapp »
Joe
I would encourage you to write a letter to the editor listing your concerns with the paper. I think that would be a better forum than debating it here. In my experience, IEEE Transactions on Plasma Science has been a reputable source, but it appears in this case that they didn't demand adequate rigor in documenting results. At risk of offending the engineering community, it has been my experience that even the best engineering journals demand much less documentation of results than journals in physics and other sciences. Indeed, I have often been frustrated that engineers often publish a result only as a meeting report and never follow up with a full paper. There seems to be a different publishing culture in this community probably driven by proprietary considerations. Publications often seem more for bragging rights than to truly share research results with the scientific community in sufficient detail to reproduce the work (which I firmly believe should be the universal standard).
I will now put on my helmet for the anticipated response by the engineers. (I am really of fan of engineers; I have a joint appointment in an engineering department.)
Dan
Late to reply here....Sorry 'bout that. Dan is right in that engineers, I was one, and engineering is all about making extant working things better, more efficient or to put forward new paths in practical engineering.
If the fusion process is ever made practical, it is the engineers and bean counters that will put the electricity at the outlet that the power companies and the consumers can afford to invest in and pay for. Physicists and engineers do their own thing. Specialist engineers can and do work with physicists in all areas of physics as the average physicist might have only a broad idea of how to make his theory or concept work into a physical embodiment. Hopefully, his engineer has risen to a level of understanding within physics to grasp a possible physical path to implement an experiment. They work in concert to get a viable proof via physical embodiment. Once the physicists and their assisting engineers have a working idea that is proven and "out there", clever engineers can really get to work to reduce the cost, size and increase the versatility to push it into the public domain.
Engineers must have a working model and proof of concept if they dare to publish new science in a Physics Journal and should not slip under the covers and publish physics in an engineering journal, perhaps relying on engineer readers not to ask questions at the advanced physics level of his paper.
As an old engineer, amateur scientist and with 20 years of reading physics and looking at what has been done and what is being done related to fusion, I have no real ideas of how to proceed to usable fusion, no pet theories, etc. I know that this is ostensibly the realm of the physicists, but I'm enough of a practiced engineer and fusioneer to come to my reluctant view regarding its being done, for value in the near future. As being attempted now, fusion efforts seem very wrong headed to me.
