Anode layer ion source. Operation pictures
- Finn Hammer
- Real name: Finn Hammer
Re: Anode layer ion source. Operation pictures
Andrew,
Please excuse my presence in this very advanced thread, but I have been looking for an opportunity, for a while, to ask why the anode was supported by only 3 screws, leaving the 4th. hole vacant.
I guess this post answers that.
Cheers, Finn Hammer
Cheers, Finn Hammer
- Real name: Andrew Seltzman
Finn,
The original reason for the vacant hole was to allow a gas feed to come in through the back of the ion source, also the first ion source prototypes were hand machined, so the looser tolerances made the fasteners more likely to bind with the lower machining tolerances; only having three mounts reduced this probability. The original anode ring was also welded to threaded rods, so this would have been one less weld.
Andrew Seltzman
www.rtftechnologies.org
A patent has been granted on the use of a keep alive electrode to decrease startup time:
http://pdfpiw.uspto.gov/.piw?PageNum=0& ... LRPgD8lPts
Andrew Seltzman
I have a mass-producible base-plate design for the anode layer ion source using an aluminum cutout from Front Panel Express
2.75" blank conflat flange outline for Front Panel Express if anyone wants to make their own custom feedthrough flanges
http://www.frontpanelexpress.com
A hermeticallly sealed Pasternack PE4077 BNC connector is used as the HV feedthrough. It's rated to 500v with a dielectric withstanding voltage of 1500v, however I have run it for extended time at 1000v and shortly to 1700v without problems
Ion source mounted on testbed
ion source running with baseplate
Andrew Seltzman
Interesting that those Pasternack connectors work as high vacuum feedthroughs.
Can one realistically run one of these types of sources off an NST?
The pasternack BNC connectors are hermetically sealed and will hold a vacuum, though not UHV since they use an elastomer o-ring to seal to the base plate; not a real issue in the vacuum ranges that fusors/shuttering/deposition runs at though.
If rectified to DC then yes an NST would work, though make sure not to drive it with too much current.
I would not recommend an NST though since they tpically can supply much more current than the ion source can handle and can drive arcs that could damage the source.
I would recommend using an EMCO F40 high voltage DC-DC converter, it has an HV output proportional to the DC input voltage and can be controlled with a DC-DC buck converter
https://www.ebay.com/itm/EMCO-F40-High- ... xycmBSrONF
Andrew Seltzman
I once found a fist full o' these little gems at a hamfest on small old surplus circuit boards in a giant box for a buck a board. I sold a lot of them once I removed and tested them. Most went with the huge lot of EMI PMTs I sold years ago here in our trading post. These are perfect little bias supplies as long as you need only microamps as in PMT work.
Where did I get the PMTs? At Ed Wingate's N.Y. Teslathon! (no longer held) A guy had a giant gamma camera head with about 40 or more EMI PMTs still attached with sockets wiring and preamps to a 2 foot diameter NaI:tl crystal. It think he was asking for $100 but I got it for about $80. I finally got rid of the crystal at one of my HEAS fleamarket events a few years back.
Hang around enough hamfests over the years and you find stuff like this. This will be my 41st year of hamfesting. I used to hit 13 fests a year. Alas, now it is only about 6 plus HEAS. Some of the best goodies are at HEAS as relates to my needs. (vacuum, HV, bizarre cool stuff)
I sold a bunch of these types of small bias supplies that were 0-3000v negative output at this just completed HEAS fleamarket. They all went fast. I forgot to give the schematics out. If who ever got them contacts me I will try and scan the info sheet and e-mail it to them. Just PM me.
OK.
What would be the mechanism of failure? Heating the magnets to demagnetization?
I would imagine, like many such magnets that ferrite or Alnico would be used as opposed to rare earth where heating is an issue. Samarium cobalt can take a little bit of heat. Of course, rare earth NeFeB can be used if their energy product is high enough to put the needed field strength in the working gap where air cooling at stand-off distances can be maintained. On a commercial production basis, custom shapes can be made that would take advantage of the lowest cost type that would do the job. Ferrite tends to win out in most cases of custom formed magnets where moderate fields are demanded around hot environments to avoid additional cooling systems.
Amateurs are at the mercy of extant shapes and types of permanent magnets for experiment which are usually kludged affairs such that the resultant field shape and strength is less that optimum to just plain terrible. Still, we tend to persevere. Externally powered electromagnetic structures can, with some forethought, be fashioned to produce a good field if one doesn't mind throwing that energy away to get a good field.
i'm sure that i posted a pic of our NW25 that has the required BNC thread to test on our helium leak tester
I'm talking about the Pasternak hermetic BNC's
Out of 20 BNC's we accepted 17 to go into stock leak rates less than 10^-14 litres per sec
viton o-ring a must with the slightest wipe of grease to aid seal
