COMSOL simulation of a FUSOR?
- Werner Engel
- Real name: Werner Engel
Hi!
Has anyone tried to simulate the moving/colliding ions inside a fusor using COMSOL?
BR,
Werner
PS: Please also have a look at the Invitation to the "European Fusor Meeting" viewtopic.php?f=47&t=11622
BR,
Werner
- Scott Moroch
- Real name: Scott Moroch
Re: COMSOL simulation of a FUSOR?
Werner,
Several weeks ago I did simulations of ion motion in a fusor using Simion. I have been meaning to write a post on it but have been too busy with school. I have attached some pictures of the simulations. In each of these I launched ions in a circular distribution around the grid.
The left side of the picture shows the grid orientation, and the right shows the ion motion.
Scott Moroch
Scott Moroch
-Albert Einstein
-Albert Einstein
Did you just buy SIMION,. Or did you have it from work or school?
- Scott Moroch
I am an undergrad at the University of Maryland and do research in the Radiation and Accelerator Facilities. I was given a copy of Simion for the research projects I am working on.
It is unfortunate that an indefinite license of Simion is around $800-$900.
Scott Moroch
Scott Moroch
-Albert Einstein
-Albert Einstein
Great stuff! As I do not have Simmon, what was the origin point of the ions? Can I assume the shell? Of course, this is the ideal in a fusor. Too bad the ions are born all over the volume in the common fusor with the vast majority never undergoing full acceleration, circulating in many smaller orbits.
Still, very interesting plots. Thanks for sharing.
There is at least one ion optics software package, IBS, available free from sourceforge, http://ibsimu.sourceforge.net. I have never used it, but it might be worth looking into for someone who wants to do modeling and does not have access to SIMION.
- Noah C Hoppis
- Real name: Noah C Hoppis
IBSimu is a very good option for ion source extractor and accelerator geometries. I've used it to poke around an ECR ion source extractor with good results. I'm not sure how well it would fair with spherical geometries allowing for orbitals. A "kill" function for prolonged life ions may be necessary.
I would be interested to see where and by which mechanism the bulk of ions in a fusor are produced (ion-neutral interactions, electron-neutral interactions, etc.).
"No missile ever flew before 10 pm"
I think we can go to the bank with the bulk of ions being produced by electron-neutral reactions via high field emission. The fusor is little different in operation from a fully controllable,
oddly electroded, neon glow lamp, partially functioning as a deuteron accelerator-collider for about .01% of its total modus operandi, producing only 1 billionth of its net applied energy in nuclear fusion energy. All the other 99.99% of the modus operandi taking place in the fusor simply heats the shell being given off as a net loss in waste heat, minus the microscopic amount of energy piercing the shell as 30kv+ x-radiation and flying 2.4mev fusion neutrons.
The above is a fairly good description of the functioning, average, amateur fusor.
In the long run, as a fusion reactor it is perhaps one of the most miserably wasteful sources of net applied energy to create fusion energy. Still, pound-for-pound and dollar-for-dollar spent compared to other fusion reactors, it is probably the easiest and least expensive fusion reactor to build and operate, making the production of real nuclear fusion a snap for the gifted amateur scientist.
The goings-on is a fusor are multi-modal; perhaps with 10 or 20 different modalities, (a witch's brew). Only 2 or 3 of these modalities are capable of doing fusion and these are the least functional of all the modalities. Of these least functional processes only the tinest fraction of their full function will ultimately produce fusion.
How does this compare to a simple beam-on-target or colliding-beam-quasifusor system?
Both of those are far more expensive and troulbesome to implement using the D-D process. While the best loaded target would be palladium, titanium seems to be the base material of choice due to expense.
They certainly are more complicated than a basic fusor, since an ion source is unavoidable, but the Rapp Instruments beam on target system seems *very* simple, with the only really more complex issue with it being the need for a (slightly) higher vacuum than a fusor and an auxiliary power supply (which can be a cheap NST supply).
A good ion source, deeper vacuums, and the need to either load or purchase D2 loaded targets stop virtually every amateur from beam on target systems. Only a very few have tried it. most of them did fusion first with a fusor. No one here has reported activating silver with beam on target.
Thomas Rapp claimed (on his own site) to have successfully activated indium and silver with neutrons from his beam-on-target machine; I don't know if you consider it well-substantiated, and his ion source is ultra-simple.
Here at fusor.net we have rather rigid and rigorous reporting standards, so I do not know about his system.
His beam on target reactor is here: http://www.rapp-instruments.de/Beschleu ... neugen.htm . He measured with both a scintillation counter and with activation.
Three things are notable to me: first, the extreme simplicity of the system. Second, the interesting arrangement of a "suppressor" collar around the target and the associated capacitative glow discharge based current meter, which measures currents in the microamperes while floating at +100 kV. Third, the fact that he uses an extreme-voltage (100kV plus?) but apparently low-current power supply.
I am intending to build something like this, though with a less powerful 50 kV supply.
(I am also intending to replicate some of his mass spectrometry experiments).
100kv is far beyond anything ever done here but the microamp currents seem incongruous. An interesting system if you have the voltage to pump it and can afford to buy the target or have the where with all to load your own.
Huh. I thought he loaded it by bombarding it with the same D2 as was in the accelerator, similar to how fusors get their walls coated.
Is there a reason to think that either this or a colliding-beam variant of it would not work with 50 kV?
I just came across a finite element modeling software package you can use for free: simscale.com.
Anything you do in a free account is visible to the community of users, but the price is right. If you want to keep your work confidential, you have to open a paid account.
It would be interesting to see which system would do the best per unit input power, provided each system had the same demanded, tight controls in reporting. Something that seems unlikely.
As someone who built an accelerator (deuterium) and a fusor, I only succeed generating successful fusion with the fusor. I have never actually "fired' up my accelerator (despite the fact it is essentially 100% complete - sigh) because obtaining the high voltage via a Van de Graaff was a terrible approach (built two units; one very large - fun exercise but wasted effort.) Guess I should see how they solved the high voltage issue so thanks for the link (they show only a 25 kV supply (how does that do fusion?!); I don't read German so where is the design for 100 kV?)
I have also built a successful and rather high current voltage multiplier but it tops out at 60-70 kV (no easy way to double that to what my electro-static lens would need to really function. However, that supply would likely work for a simple ion gun neutron generating system;) but back to the main point, that supply is absolutely deadly so I never tried hooking it up to the accelerator (besides not being high enough voltage for the lens, the head assembly containing the gun/gas supply/gas ionization system is far too large of an exposed area to safely energize and be around/operate with that deadly supply - just too risky since I have a working fusor, anyway.) Didn't stop to consider that issue until after I built that monster supply ...lol.
But then, I do like building these types of projects for both the fun of it and to learn the in's & out's of these devices as well as to better master the many skills needed to work in high voltage/vacuum systems.
If one has the time and interest, these types of "side projects" can be very useful if not, somewhat irrelevant to directly building a fusor. I will say that without the numerous side projects, I'd never have obtained the skills and knowledge needed to build a working fusor; yes, the information provided by the people here was absolutely critical but I really did need to build smaller, simpler projects before tackling the monster called a fusor.
- Real name: Daniel Fajardo
Hello Werner,
Its funny you asked this question just now. I'm about to finish my demo fusor and want to start working on a simulation in COMSOL.
I'm thinking about simulating the electric field and particle tracing. I'm not quite sure how to make the grid geometry, though.
Please let me know if you have worked on something. I would love to share ideas with you.
Daniel Fajardo
Daniel Fajardo
Thomas Rapp's beam-on-target machine (he actually built two) doesn't use the 20kV to do the fusion. Rather, that is just used to drive his canal-ray ion source.
He is also ballasting the living daylights out of this (100 megaohms!) so likely he isn't even getting near 20 kV in operation. Not sure why he didn't just use an NST.
In any case, the small test-tube-looking appendage is the ion source. The pipe tee is at ground potential, and the terminal on the end of the ion source is at +20 kV. D2 is piped into it and the glow discharge ionizes it. The E-field extracts D+ ions into and through the pipe tee and into the long, large glass column, which is at a much better vacuum.
His initial tests just had the resulting canal beam hitting the end of the column which cannot have been easy on the glass. Later on, he replaced the end of the column with a target holder and secondary electron suppressor, and applied -100 kV directly to this target holder, with the glass column serving as an insulator).
Why do you have your ion source at high potential?
- Samuel Low
- Real name: Samuel Low
I don't think COMSOL has a module to do particle tracing unlike SIMION. I know for sure you can definitely run an electrostatic simulation to see the spherical E-field patterns - the usefulness of it would really then be the ability to just see the E-field patterns for different CAD models of inner grids. It would be very interesting to see the effects of various inner grid geometries, I would love to see some screenshots with the colour bar scale if you ever get to doing the experiments! Good luck!
"Physicists are made of atoms." - Michio Kaku
- Real name: Andrew Seltzman
I believe comsol does have a particle tracking module, but it has to be licensed and installed separately and is not part of the basic package.
Andrew Seltzman
www.rtftechnologies.org
