Testing Monazite using high resolution scintillators
Sean-Wiseman
Real name: Sean Wiseman
Post by Sean-Wiseman » Tue Dec 04, 2018 3:55 am
monazite-(Ce), (Ce, La, Nd, Th)PO4 (the most common member)
who need LaBr?
viewtopic.php?f=20&t=12537
Re: Testing Monazite using high resolution scintillators
Post by John Futter » Tue Dec 04, 2018 9:33 am
Sean
deadtime!!!!
or are you using "FAST" ADC's
Sean-Wiseman
Post by Sean-Wiseman » Tue Dec 04, 2018 9:36 am
Sean
deadtime!!!!
sorry
what is your means?
I do not understand ^_^
Post by John Futter » Thu Dec 06, 2018 6:04 am
Sean
The slewing of the spectra for the NaTl seem to be either too much dead time ie MCA not ready for next pulse or a damaged NaTl scintillator
I check sometime next week on the one i use (ortec 2"x2" Natl with a similar spectra
Sean-Wiseman
Post by Sean-Wiseman » Sat Dec 08, 2018 12:44 pm
Sean
John
NaI's decay time ~250ns
presume dead time~250x5=1250ns
it can get 80,000 pulses every second.
80000cps is very big. so dead time is not a big problem if your MCA is fast enough.
My LaBr decay time about 20~25ns. ^_^
I also can sell it.
Post by John Futter » Wed Dec 12, 2018 6:46 am
80,000 pulaes per sec could incurr 10% deadtime or more with NaTl which will slew spectra and seriously widen FHHW response hiding the rest of the spectra
as for FAST ADC's this is what I use
https://www.fastcomtec.com/?id=409
Sean-Wiseman
Post by Sean-Wiseman » Wed Dec 12, 2018 11:02 am
so you need LaBr.
and 80000cps is very dangerous for man.
CZT will be better.
vince_Darmancier
Real name: Vince Darmancier
Post by vince_Darmancier » Wed Jan 02, 2019 7:04 pm
I have used a 3" X 3" standart NaI scintillation probe for almost 10 years with decent resolution...I dont feel the need for a LaBr
calibration with Co60,
Monazite
Uranium ore
Ba133
Sean-Wiseman
Post by Sean-Wiseman » Mon Jan 14, 2019 4:58 pm
Monazite
Uranium ore
Ba133
LaBr have Higher resolution and P/C than NEW Saint-Gobain NaI Crystals.
Whether this is needed is a comprehensive result. ^_^
