Paper on neutron counting using ZnS(Ag) phosphors
Members may post files they wish to share here.
Jon Rosenstiel
Real name: Jon Rosenstiel
Post by Jon Rosenstiel » Fri Sep 14, 2018 9:01 pm
Phosphor mixtures for neutron scintillation counting.
ZnS(Ag) for neutron detection.pdf
(660.25 KiB) Downloaded 381 times
Jon Rosenstiel
Roberto Ferrari
Real name: Roberto Ferrari
Re: Paper on neutron counting using ZnS(Ag) phosphors
Post by Roberto Ferrari » Sat Sep 15, 2018 8:29 pm
Jon,
It is an interesting paper but nothing is said about neutron fluxes.
The only neutron parameter reported is energy.
Do you think ZnS:Ag may be sensitive enough for the typical fusor production?
Roberto
Post by John Futter » Mon Sep 17, 2018 9:31 am
roberto /Jon
I made a neutron scintillator setup a few yago and posted it here to how i did it. It used Zns Ag etc and worked well all but for the few seconds delay. So its not prompt but i tested it in our magnet room @ work while a 900kV deuteron beam was in use. Quite a few neuts run around the magnet / slits in the magnet room which is well shielded from the outside. I seem to remember copper and lead shielding to suppress gammas.
edit found the reference
did I really do this that long ago!!!1!!!!
viewtopic.php?f=13&t=6064
Roberto Ferrari
Post by Roberto Ferrari » Mon Sep 17, 2018 1:42 pm
Hi John
Glad to know about your experiment.
I will give a try as soon as I get some ZnS:Ag film.
My neutron source will be an old vial with Ra paint (from old watch shop) and a small Be window from a damaged X-ray tube, just placing the Be in front of the open vial. The efficiency will be low but I don't want to mix the Ra paint with Be powder.
It is a rare piece in my collection of NORM and TENORM objects.
Jon Rosenstiel
Post by Jon Rosenstiel » Tue Sep 18, 2018 5:05 pm
Roberto,
ZnS(Ag) neutron detectors are notoriously poor performers (as I recall,efficiency is around 1%) so for the budding fusioneer this avenue is pretty-much a non-starter. But for someone that already has a neutron producing fusor and is looking for something to do with those neutrons this may make for an interesting project.
Jon Rosenstiel
Roberto Ferrari
Post by Roberto Ferrari » Tue Sep 18, 2018 6:27 pm
Hi Jon
Understood!
Let's have enough neutrons and then...
Roberto
Jim Kovalchick
Post by Jim Kovalchick » Wed Sep 19, 2018 1:40 am
I've had this paper in my pdf collection for years. Lot's of valuable info. I built the device and even used the same model Dumont pmt. I managed to find a source of boron powder highly enriched in B10. You dont need much. I got my phosphor from United Nuclear. Use the Ag doped kind, not Cu.
You need to wait a while for the phosphor to settle when you first get it light sealed.
You need to fiddle to distinguish between gammas and neutrons. I suspect using a Ra Be source will make it hard. Enough radium to produce neutrons makes tons of gamma. Better to use Am Be or proven fusor.
Post by Richard Hull » Wed Sep 19, 2018 3:46 am
All of these issues came to the fore in 1999 on songs.com and later, the intranet fusor site. There were hornyak detectors, and I used the Bicron model with target rings of ZnS:Ag. I tried a 2" with PMT and found the .75% efficiency nearly worthless in my first fusion efforts. (It did work, but...). I then spent $450 of the Bicron 5" "target" neutron scintillator and used a large Dumont PMT with it. It was my first really useful neutron detector. Same efficiency but larger capture area. I quickly moved to a snoopy and then a PNC-1 using BF3..... Much better, but not by much.
Once I got my 3He tube, it was "The solution for fusor detection". I also bought 2 BTI bubble units a year and a half apart, but by this time I was doing well over 500K n/s, isotropic. The BTI's served over a year to gather data so that I could calibrate and obtain a "K" constant adjustment factor related to isotropic emission and counts on my 3He system.
The NE and most BC scintillators are indeed difficult to set up for neutron vs. gamma detection. The expensive Bicron scintillators had no such issues as they were tooled in a manner to effectively not respond to gammas, but again that efficiency was under 1%.
In general, outside of an expert hand with impressive instrumentation, equipped with a good source of neutrons, in hand, no scintillator will function for a newbie fusor working in the doldrums.
Been there....Done that...
Roberto Ferrari
Post by Roberto Ferrari » Wed Sep 19, 2018 2:45 pm
Hi Richard
Thanks for the comments.
I will rely most in Ag activation and the russian corona tubes.
Roberto
