Fusor progress, Finn Hammer
- Finn Hammer
- Real name: Finn Hammer
All,
I am about finished welding the fusor parts together, and today I was able to test assemble the major part of my fusor.
The diametre of the sphere is 256mm internal, close to 10". Material thickness is 3mm or 1/8"
It looks a bit flattish, but it is not. On the right side, you see the connection to the 3.5" diffusion pump, this connection widens out to mate with the 4" butterfly valve, which in turn mates to a 4" bend, which enters the sphere from the right. The bend contains halfmoon shaped baffels which overlap.
I felt I should run the diff. pump connection to the chamber keeping the cross section equal or bigger than the throat of the pump.
Another thing I am uncertain about is how fine controll I will have with the diff. pump running, and a 4" butterfly valve. I fear that the butterfly valve will let too much deuterium ply past it, even when it is only slightly open. To try to compensate for that, I am bypassing the butterfly valve with a 1" bellows valve which you see at the far right. I can close the butterfly valve completely and balance fusor pressure with the bellows valve. Or try to at least, we will see about that.
The main flanges are scrapped parts from a dairy supplyer, I turned them out and made conflat fitting on the mating surfaces, needless to say, I am anxious to see if they will hold a vacuum.
The viewport diametre is 2 1/2" and the feedtrough is a 30kV rated type, both conflat too. The arrangement of the feedtrough/viewport serves these purposes:
No parts from a melted grid will fall into any pump.
I will view the grid along its center axis, so I will get great photos in star mode
The viewport is pointed away from the operator
The high voltage connection is guarded inside the machine chassis, which is grounded, for maximum safety.
This is the state of my fusor at this time, 18-09-2017
Cheers, Finn Hammer
Cheers, Finn Hammer
- Nick Peskosky
Re: Fusor progress, Finn Hammer
Finn,
The 1" bellows bypass valve should work exactly as intended assuming you have an appropriate 'leak' type valve on the D2 input. I use a manual SS-bellows Varian 2.75" Conflat right angle valve for my gross pressure control between the chamber and the throat of my turbomolecular pump and it works great (takes a little fiddling to find the sweet spot during most runs).
Nick Peskosky
NPeskosky@gmail.com
NPeskosky@gmail.com
Nick is absolutely correct. I have used only a 2.75 CF bellows valve to control the diff pump's conductance. (virtually closed off after evacuation to 5X10e-4 torr.) I barely cock open the valve and then open the needle valve in the D2 line and, as Nick notes, a good bit of fiddling is needed to start my fusor with about 6 microns of flowing D2 pressure. As time passes, I have no problem bumping this up to 10 or more microns to approach the mega mark near 40kv.
Once a perfect fusor is assembled to a high standard, getting it to work is all about fiddling and nothing else.....Fiddling with pressure, current, voltage to, at first, just achieve operation as the neutron counter starts to click. More and more fiddling to make it click faster and faster.
What Nick calls a bit of fiddliing turns out to be my preaching about experienced operator control and gaining knowledge of your particular system. Fiddling is part of the human-fusor feedback system that is a learned function on the part of the human mechanism to make a fusor perform.
- Finn Hammer
All,
A picture of the poor mans conflat in my fusor shell main flange seam.
Something that is coming up soon, is designing the gas delivery system.
Based on this discussion:
viewtopic.php?f=24&t=2570&p=12080&hilit ... lve#p12080
I have setteled on using a mass flow controller, so that I can deliver 0-10 sccm of deuterium into the shell.
I assume that with for example 5sccm of deuterium flowing, I should be able to run the fusor for 3 hours per liter deuterium 1000cc/5ccm=200m =>~3 hours, so a 25 liter bottle should last 75 hours, this number seems very large I must have miscalculated.....
The reduction valve is a Matheson 3320, and the flowcontroller is a refurbished MKS M100B01311CS1BV
M100B => mass flow controller (with the valve)
013 => nitrogen
11C => 10 sccm (nitrogen)
S => Swagelok ¼” tube
1 => Normally Closed (Type M100B MFC only)
B => 15-pin Type “D” standard pinout
V => Viton seals
I read that people use very long capillary tubes and/or holes in the micron range to choke the deuterium supply, but can I rely on this system to work, with a 0-5V input.
I have a problem going through the calculations on page 62-65 mainly because the table on page 63 assumes that the valve delivers gas into atmospheric pressure, but the fusor sucks at ~10micron.
The manual for the Controller can be found here:
http://www.mksinst.com/docs/r/m100b-m10mbman.pdf
Any assistance will be greatly appreciated.
Cheers, Finn Hammer
013 => nitrogen
V => Viton seals
Cheers, Finn Hammer
- Real name: Bruce Meagher
From your picture above it appears there is some pitting in your weld on the inside of your chamber. I’d imagine this will limit the ultimate pressure you can achieve, but I do not have any practical experience to say what that limit might be. Fusors do not require much of a vacuum in the scheme of things so it probably doesn't matter.
Can you post a couple clearer pictures of the inside chamber welds as a data point? I’ll be keenly watching to see your results when you have the diffusion pump connected.
Bruce
Bruce
When I built fusor IV, I welded the rings on the hemisphere and put in the vacuum port and Baratron port only. I pumped the system down and checked for leaks. I had a couple of minor leaks around my welds at the rings, which I fixed.
It is only after checking out the basic chamber and large weldments that I starting adding ports one by one and pulling down to a vacuum. In this manner I could be fairly sure that any leaks once the system went together were leaks in the vacuum line and system plumbing outside of the fusor.
Currently, what leaks I do have, which are minor, are indeed in the various connections.
- Finn Hammer
Good procedure, I should have thought of doing something like that, and not rush things.
Bruce,
Not so bad an idea to take photos.
I wish it all looked like this:
Or even like this:
Even this one looks acceptable, I see only surface slag:
This shift has a big black spot, I think it is just a surface slag, but notice the micro-pores to the left of that spot. It is going to get very interesting to try to pull this chamber to a high vacuum.
But here I start to worry: It looks like craters that could go deep. and maby penetrate to the outside.
This is my first attempt at a vacuum vessel, and I am just hoping for the best. We will see soon enough.
Cheers, Finn Hammer
Bruce,
Or even like this:
Cheers, Finn Hammer
- Finn Hammer
Bruce, All,
I took some pictures off a 4" Conflat flange, produced by Kurt Lesker. The uniformity of the welding pattern reveals that this is an automated weld out of a welding robot, nevertheless it displays some of the same flaws that tarnished my own work:
However, things tend to get out of proportion when viewed trough a macro lens, that's kind of the purpose I guess, like this little critter. In real life only 6mm long (1/4") but viewed with the same macro, it becomes a monster:
Excuses for the off topic ending.
Cheers, Finn Hammer
Cheers, Finn Hammer
- Finn Hammer
Treasure!!!!
To be accepted as a customer by Sigma Aldrich is not a trivial task, but finally I passed through the eye of the needle, and the bottle arrived yesterday, I cannot tell you how happy I am. Together with this reduction valve:
The gas delivery system that I am planning will consist of a mass flow controller, and for that purpose, I have aquired this classy unit, refurbished by MKS, so as good as new, I assume:
Initially, I had some bad reservations about using a flow controller due to a misconception of mine: I assumed that since D2 is less dense than N2, then the valve would pass much more D2, but this is not really the case.
Reading the manual revealed some great news: The controller works by measuring the flow of gas by a method that relies on both the density of the gas, as well as the specific heat of the gas. The product of these two constants multiplied goes into the formula for the delivery of the gas, in the form of the conversion factor, and it so turns out that this factor is the same for N2 and D2.
N2 has specific heat: 0.2485 and density is 1.2500 multiplied = 0.3106
D2 has specific heat: 1.7720 and density is 0.1799 multiplied = 0,3187, or close enough for a conversion factor of 1.
Another great feature of the flow controller is the ability to controll a pressure:
The normal way of operation is to choose a set point between 0-5V and this will in this case correspond to 0-10sccm of D2 flow.
But there is another input, called the optional input. By feeding the output from my 50micron full scale Baratron into that input I get this functionality:
By setting the flow controller set point to the baratron output at the desired pressure, the flow controller will adjust the flow to maintain that pressure.
An example:
Scaling the 0-10V output of the baratron to the 0-5V input of the flow controller, then 5-50micron on the baratron will produce an output signal from 0.5 - 5V, with 0.1V/micron. So in the case that I want to maintain a pressure of 10 microns, the set point voltage on the flow controller should be 0.5 + (10*0,1) = 1.5V
How this is going to work out in idle mode is probably straight forward, but when the corona kicks in, things may look quite different, time will tell.
So this was a short account of how my work and understanding of things involved is coming along.
Cheers, Finn Hammer
An example:
Cheers, Finn Hammer
Congratulations! I understand - I had to set up a "business" and do the paperwork with the State in order to get mine to work (Tax number and all that.) Cost me both trouble (a number of years dealing with paper work but on the plus side, I did work with a company on an SBIR.) Good work and I know you will soon be going fusion.
- Finn Hammer
First Neutrons!!
Noooo, not produced, but measured!, I think.
It all started like this: And if you can guess what it is, then you are good. It is the first pour of paraffin into a HDPE container made from surplus pipe I found in the Water departments Dumpster. Polyethylene is getting awfully expensive these days, and this is what they got. Food grade HDPE, nothing less, doesn't get any better than that.
Outside 8 inches. hole 2, so all in all 3 good inches of moderator. Made it 450mm long for a total of 14kg.
Looks like this with both endcaps welded on, hope it doesn't explode one day:
I couldn't help myself, had to jerry rig a detector harness, and test if it is able to detect some maverick cosmic neutrons, now moderated to thermal velocities, and this is the setup. Not pretty, I admit, and a lot of humm radiated into that setup, definately room for improvements on that account, but anyway, this is what it looks like in the business end:
It cannot get much worse than this, really.
But hey! It seems to work.
I buried my best СИ-19Н tube deep in the gut of that mother of all moderators, and sure enough, before a half a minute, this is what I saw:
Arrh, sorry, nudge nudge, gotta zoom in a bit:
That's more like it, looks just like a neutron hit to me, as from what I read around the forum these days.
One more:
And another one:
100Mohm series resistor and all in all the same setup that Bob Higgins has proposed. On a 5 minutes run I counted 15 hits, but half of those were perhaps weak enough to get buried in gamma noise. I have 1900V on the hot side of those 100M.
Shouldn't be to hard to detect with a comparator, and an arduino could count these hits via an interrupt pin, display totals and even calculate averages on the fly too.
So this is it for today, I am happy, nothing beats progressing, and I have been looking forward to being able to detect neutrons for a while now.
I wish I had a strong source to help discriminate Gamma ray induced noise, but the best I can manage at the time is a piece of fiestaware, and it does not induce any change to the output of the tube, so hopefully that dial off a MIG2 oxygen indicator gauge which I've got coming will prove hot enough.
The smooth curves you see up ahead are the ones grabbed at 500ms per div. In the case I grab them real time, with 1ms per div, it looks like this:
But who cares? It is that sweet clean front edge we are going to trigger on anyway.
(But honestly, I am going to clean that PSU up real good as a first priority.)
Cheers, Finn Hammer
One more:
And another one:
Cheers, Finn Hammer
You will not see...or...should not see a neutron pulse at 100 milliseconds, (100ms/div). I hope you mean 100 microseconds/div (100us/div).
If the latter is the case then.....Yes!!....You are seeing cosmic ray based neutron events, probably neutrons surviving the plunge from 11 miles up where neutrons abound from starring cosmic events. Most are absorbed/scattered in the water in the lower amosphere. Some fast neuts are created at lower levels by starring events with cosmic rays that make it through the upper atmosphere.
I get 5-8 neturons per minute here in may lab on a regular basis with my super 3He 4 atmosphere detector. Thus, your smaller volume detector seems to be perfect and right on the money. It appears that inspite of you kludged up mess of connections you are, indeed, counting neutrons!
All the best making this real pretty and clening up the mess. Do not mess up in clenaing up. You have a working system here.
To all else reading this..........If your, supposed, electronic neutron counter, regardless of type, and, you are located at or near sea level, you had better not measure over 10 cpm neutron background. The foregoing assumes your counter system is not better and more sensitive than mine or Finn's.
If you read much more than 10 CPM you are counting noise of NORM. (Naturally Occuring Radioactive Material)
- Finn Hammer
You are right.
The division is 1mS per div, and the pulses settle in at 500µS
Cheers, Finn Hammer
You are right.
Cheers, Finn Hammer
My professional preamp gives me neutron pulse widths of about 4-20us, depending. I am not familiar with the Russian tube's time constants. I bet that nasty old 100meg resistor is the culprit! This is a function of and demand made upon the user of the Russian tube. I have commented on this before.
That resistor forces the giant pulse widths. Still, a fine and suitable neutron detection though. However, the count rate is severly limited by this fact. I have further noted that this count rate limitation might not impact the average fusioneer for a number of reasons which I have enumerated.
Again, it sounds like you have a good counter there and, based on your background report, it is working fine.
It is nice you scoped the output. This is the first report I have seen from a Russian tube, operating properly, that has forever informed me that all using such a tube will experience rather long pulse widths. For me, this is a real eye opener and important data for all who are wise enough to see its implications.
- Finn Hammer
Ok, cool. I will try to reduce the value of that resistor, along with the supply voltage to see if it makes any difference. Obviously there is a nasty time constant in there somewhere.
I was reading about pulse pile up in one of the publications that Carl Willis pointed out, and there are preamplifiers that can pick up a pulse from a whole chain of piled up pulses. I will have to dig it out and reread it. Something about current sensing amplifiers or something like that.
Cheers, Finn Hammer
Cheers, Finn Hammer
I am more than ready to believe the high value resistor is a demanded function of the Russian tube type to work as a quencher. If so, it is not a real issue as the tube seems fully functional and detecting real neutron events with it in circuit.
It is nice that you are willing to experiment with it. However the minute your count goes up, such as to 10 CPM, you might just accept the 100 meg resistor as a given to the tube type.
"Pile-up" is not a real issue in my system with it's short pulses. This is probably the difference in a $2000.00 detection tube and pre-amp and the in-expensive Russian tube's normal operational characteristics. It is just that the Russian tube might suffer plie-up at very high count rates, rates that the average fusioneer may never see or approach. I have used a rule of thumb of 10 to 1 ratio. If your pulse count rate time frame is 10 times the pulse width, pile-up will not be significant. A 500us width would allow a 5ms rate or 200 cps/12,000cpm count rate before pile-up is an issue.
You and I are currently on line and this is good as you are reponding more or less in real time.
- Finn Hammer
edit: It is late, getting units all mixed up, gotta go to bed
But my goal would not be to increase counts per minute, it would be to shorten the pulsewidth. 500µS pulsewidth would allow (edit: 12000) counts per minute, and since they probably will not come flowing like off a clock generator, fewer.
I am not at this point able to know what that means, I am only just starting to work this aspect of fusor work, and the calculations related to neutron per minute out of a fusor is still black magic. But I will get there eventually.
Cheers, Finn Hammer
Cheers, Finn Hammer
I updated, edited my last post. I do this a lot as I think. check it out. I figured on 12,000 cpm as the max count for a 500us pulse width based on my self-arrived ratio of 10 to 1.
Pile-up is a big issue with GM counters or any detection method where the pulse width approaches the width, in time, between real detection event occurances. This ties into the physical "dead time" of the device quite outside of the time constants of the counting electronics.
As an example, you can theoretically change the input capacitance and resistance to a GM tube such that a scope will show a pulse width of 20us. However, even a super well quenched GM tube has a physically determined "dead time" of 60-100us. during this tuime period a second pulse will not be detected! Thus, in this case the dead time rules and the maximun count rate is dead time limited and not pulse time limited.
I am unaware of a published dead time spec on these Russian tubes. As such, a quest for shorting the electronic pulse width might mean nothing at all
- Real name: Silviu Tamasdan
As an anecdotal fact, the pulses I see with my corona tubes setup are 30-40us.
As for moderator, yes I noticed HDPE tends to be expensive. I have cut mine from restaurant-grade cutting boards bought from Amazon (look for the 1" thick ones) as they have tended to be the best bang for the buck I found. Then I discovered that motor oil works well as a moderator, and since I always have quite a bit of it around I have added that to my moderator stack. It works because it's composed of carbon and hydrogen same as HDPE, parrafin etc.
- Finn Hammer
Richard, Silvio
Thanks for your usefull input, it helps me to focus on what is possible and desirable, and to spot it on sight.
I lowered the voltage to 1600V and suddenly the counts changed to this much more desirable profile:
Notice the setting: 2µS / division.
Much like the difference between hitting the gong with a sledge hammer instead of tapping it with a teaspoon.
The sensitivity dropped to 1-2 pulses per minute.
I am still struggeling to get the supply to remain stable and ripple free, and don't see this as the final word, so I will remain quiet for a while untill I have some conclusive data to show.
Sitting in front of the scope, counting to between 30 and 55 seconds to time the cosmic hits (will they still come with this setting, how is it going to look?) reminds me of an old Zen story:
A grain of salt wanted to know how salty the oceams were, so it jumped in, and became one with the water of the ocean. That way the grain of salt gained perfect understanding.
Cheers, Finn Hammer
Cheers, Finn Hammer
Great work Finn! with pulses like that, you might get a regular counter to run it and accumulate for 20 minutes and take the average. My ten minute averages of 5-8 cpm using a tube with about 2-3X your volume sounds about correct. Many really good frequency counters have a count mode on their range knob.
I have several HP 10-50mhz counters purchased over the years. All have a count mode and a pushbutton for start and stop. (reset) I would hate to have to count scope pulses over that period. I have counted as low as 3 cpm and as high as 12 cpm over single minute intervals. The average always comes in between 5-8 cpm. During a significant solar CME, I have seen the local count double, and during the most massive of CME's, triple! That big one brought the aurora as far south as Richmond.............36 degrees latitude.
- Real name: Peter Schmelcher
Finn I tested the same tube without any moderator (at sea level) some time ago and decided on proportional operation by using a 1000 volt tube bias.
One drawback you can see in the scope capture is that the neutron pulse output amplitude is smaller so shielding the electronics becomes more important.
The benefit I believe is the physics of proportional tube bias does not have a recovery time.
When you put a moderator (I used water) around the tube the initial kinetic energy gets stripped away before the neutrons enters the tube and the scope capture shows a more uniform tube pulse output (band) which you can use to amplitude calibrate your system. I do not have a scope capture with a moderator for this tube but you can see the band in the last scope capture.
The attached paper "Neutron flux variations near the Earth’s crust" pdf has a graph of neutron count rates verses altitude.
Have fun
-Peter
3 minutes 1800 volt bias 3 minutes 1500 volt bias 3 minutes 1000 volt bias 1 hour 1000 volt bias
Have fun
-Peter
- HE3 tube nhess-3-637-2003.pdf
- (546.74 KiB) Downloaded 374 times
- Finn Hammer
As I was walking around in the local recycling facility, also known as the scrapyard, my eyes glued themselves to a machine chassis sitting on the top of a 30 foot container, and I couldn't pass it up, because it was the perfect size. It is gross overkill, but I like that, and who can argue against a 50$ machine chassis?
Anyway, the mesh was coated with some sort of lubricant from the manufacturing process, so I washed it out with mineral spirit (turpentine, right) and baked it with my 500deg C heat gun. This created a smoke exhaust like a small vulcano for 10-15 minutes, then it faded away, and I think the filter is fine now.
Perhaps with outgassing, perhaps due to a leak, it pressure rises by 2microns per second when I isolate it from the pump, but future leak tests will tell what is the cause. The pump is a good one, it goes down to 2 microns right at inlet, and with the filter mounted, 5 microns, so no real problem here. Calculating conductance is not yet my province, (but I am following Michael Bretti's thread closely, Thank you Michael) so in case the 4 inch butterfly valve is unable to close down with sufficient precision, I have added a bypass KF25 bellows valve so that I hopefully can get good controll of the deuterium flow into the atmosphere. As you see on this picture, the metering will be taken care of, by a 50 FS Micron Baratron for fusion pressure monitoring, and a 901P for the pre fusion pressure, prior to deuterium admittance. The white stick on the picture is a bar of Macor, which I will machine down to hold the extension from feedthrough to the Grid.
Sadly enough, this is going to be the only progress for quite a while, since I am moving to a new house that needs work, and this will take all spare time for half a year at the least, but who can argue against getting this view, only 60 steps from the front door: Cheers, Finn Hammer
The presence of a chassis also prompted me to get around to performing another much needed task, the welding of a KF25 flange to the foreline of the diffusion pump.
Another hurdle was the foreline trap. This is how it turned out:
This trap is filled with knitted wire mesh, which I have in abundance. I use it to make faraday suits:
It is another story with the Faraday suit, but this one was tested at a windmill wing test facility, where they hit it with 70kA, and it stayed intact much to my own surprise, I thought it would have evaporated.Anyway, the mesh was coated with some sort of lubricant from the manufacturing process, so I washed it out with mineral spirit (turpentine, right) and baked it with my 500deg C heat gun. This created a smoke exhaust like a small vulcano for 10-15 minutes, then it faded away, and I think the filter is fine now.
Pausing fusion effort for making a livable abode in such a natural environment is a good cause. Good luck on getting things fixed up to live among nature.
Nice work, Finn. Good wishes on your move.
Rather OT for fusor, but your faraday suit image reminded me of this from the old silent movie, Metropolis.
