Tubbs Beam-on-Target Effort [Neuts/Pics/Tips]
- Werner Engel
- Real name: Werner Engel
Re: Tubbs Beam-on-Target Effort [Neuts/Pics/Tips]
Robert, here you see the inside of the tuner für impedance matching the RF source . Do you mean you removed the wire from the cap to the switch and connected the coil directly to the cap? Which cap-connection did you use? Could you send a picture? Did you do any kind of resonance calculation to design the coil? I used a Rigol DSA815 to detect any resonance – but unfortunately it did not work.
And how did you set the right values of the cap and the inductor? The manual does not say anything about a plasma-heating-coil as a load
To drive my SSPA I need at least 2W of RF-power. I’m currently working on a kind of pre-amp using a LMH6321 (2nd picture). Looks good so far!
> "Do you mean you removed the wire from the cap to the switch and connected the coil directly to the cap?"
Correct.
> "Did you do any kind of resonance calculation to design the coil?"
Negatory.
> "I used a Rigol DSA815 to detect any resonance – but unfortunately it did not work."
Those low VSWR points are in there, but your analyzer probably won't find them.
> "And how did you set the right values of the cap and the inductor?"
By hand, manually using a forward and reflected meter.
RT
Correct.
Negatory.
RT
Finally got the new ion source working after some months of fussing with it. The source has three extractor electrodes, the top plate, and a pair of extractors in the double sided 1" thick conflat. The top plate and the lower aluminum piece float at 15kV, and the brass piece sits at ground potential. Source self extracts nicely, whereas before the old source required the biased target to do the extraction.
-RT
-RT
- Steven Sesselmann
Robert,
Nice looking work as always.
Is that machinable Macor ceramic you have used to hold the extractor arrangement?
So do you have the target at negative potential?
Hi Steven,
Yeah, that's machinable ceramic in there. The stuff cuts real nice on my mini-lathe.
No target in there yet or built, hence the beam spread. The original one was pretty thoroughly destroyed. As in the past this one will also use a negatively biased target.
RT
RT
Cleaned things up somewhat, and got more beam out - going to keep dialing it in.
RT
RT
Dialded in on H mode, and am pulling proper beam now. Some pics and videos of operation:
https://youtu.be/Jx0ts2VmjHs
https://youtu.be/mu_XNZKC0aw
RT
RT
- Garrett Young
- Real name: Garrett Young
Robert,
Now this is a really cool project! I've watched this thread with great interest. Is the Northwest Nuclear Consortium open to visitors?
I'm trying to pull together a midwest conference for fusor.net members (viewtopic.php?f=47&t=11408). I know you are well outside the midwest but do you ever travel to this area? You would certainly be welcome as a guest speaker.
- Garrett
Thanks Garrett,
With regards to the invite out east, thanks also. I can't say I'm out there very often, but I'm likely to be at HEAS this year, I'll be certain to say hello if I see you there.
I haven't been affiliated with NWNC for several years, and admins haven't been responsive to my request to edit the thread of it's mention. The system resides with me now, as it should.
RT
RT
- Garrett Young
Understood. I was really interested in seeing your device first hand and discussing ideas. Hopefully I'll be at HEAS this year.
- Garrett
You're welcome to drop by Seattle sometime and see it, it's in my living room. Otherwise wait about a year and visit the Philippines as I'll be there studying abroad for a few years and my most of my hardware but for the most extreme of export restricted materials will come with. My couch there will be open to to surfing, unless I'm out surfing.
- Steven Sesselmann
Robert,
Can you elaborate more on the physics of plasma going into "H" mode?
I have seen this phenomenon myself or at least something similar while playing around with an induction coil and a neon tube, as the neon tube was held close to a high frequency induction coil the tube lights up but at some point the plasma goes from being just normal "neon tube bright" to something more like a flash bulb. The transition was rapid, and within seconds it melted the glass and vented the neon tube.
Steve- Here's a paper that works out the transition point:
http://iopscience.iop.org/article/10.10 ... 21/014/pdf
- Steven Sesselmann
Jake,
Thanks, read the abstract, but the rest of it is behind a pay wall, so it's inaccessible to me unless I pay $33.
Gave a thin film titanium coated copper target a beating last night. It puked a meganeut or so at 50kV after effectively instantly loading. Wasn't a lot left of it when I pulled it out for a look at the damage. Good stuff!
Also attaching a video, a few photos, and a cool .gif of the focal spot adjusting at lower power. First one's the gif.
https://youtu.be/jLvlHaeXsss
- Real name: Bruce Meagher
Robert,
Excellent as always! How thick was your Titanium coating, and are you currently cooling your target?
Bruce
Bruce
- Real name: Andrew Seltzman
You can really see the secondary electrons hitting the viewport, a magnet might work to deflect them.
What's the x-ray dose rate at the viewport?
Andrew Seltzman
www.rtftechnologies.org
- Werner Engel
I just finised work on my new SSPA with 1kW to drive my plasma heating.
Attached you see the numbers (going up to 850W) and a nice picture of the device.
The short video shows the very first test without adjusting the tuner - so you see almost the same power reflected as going out. The sound gives you an idea of the powersupply needed for this!! Unfortunatly the file was not uploaded due to a mp4-restriction.
@Robert: I did not see any RF-discharges in the tuner - as you did. What power levels did you reach when these issues occured?
BR,
Werner
BR,
Werner
- Amp Test for plasma heating.pdf
- (340.44 KiB) Downloaded 382 times
Werner
Nice to see you using the W6PQL kits for the SSPA.
You can see my build on https://www.qrz.com/db/ZL2TUD
- Werner Engel
I just read that you are very good in designing RF devices: I still do not know how to design the antenna for the plasma. My first idea was just trying to use a copper pipe with 14 turns and give it a try - using the tuner. I also thought about calculating a kind of resonance frequency resulting out of the geometry – but did not succeed. Next try was to use a spectrum analyzer with a VSWR bridge to measure the resonance frequency - did not work. What do you think will be the right way to focus on – from your experience?
BR,
Werner
Werner
we should transfer this to a new post so as to not dilute the good work of Robert Tubbs
I'll start a new post under ion sources to answer this
- Real name: Roberto Ferrari
Hi Robert,
Please, comment about the RF power on your Ion Source Inductively Coupled as well as the Proton/Deuteron current.
Could you provide some diagram of your source? I am curious about the three extractors electrodes.
Thanks!
Roberto
Thanks!
Roberto
