Voltage level for static E-feild
Andrew Haynes
Real name: Andrew Haynes
Post by Andrew Haynes »
Hi, I'm trying to make a ion gun, and was wondering at what voltage level would a 0.5mm needle emit electrons. Was planning to run it in a vacuum of about 0.1-0.5psi with a gap to target of 0.5-1mm.
I can get access to a 250nm UV lamp and was wondering if that would lower the threshold, and if the gas would effect the operation(if they become positive and get attached to the anode).
Cheers
Andrew Haynes
Re: Voltage level for static E-feild
You would only need a kilovolt or so off a needle at that pressure, but your ions would not go far, unfortunately, as the mean free path would be only a couple of millimeters.
Steven Sesselmann
Real name: Steven Sesselmann
Post by Steven Sesselmann »
Andy,
If you can rig up a system with differential pressure, so the gas pressure around the needle is higher, then you can generate ions at relatively low voltage and extract them into a chamber of lower pressure.
You place the needle cathode above an anode disc with a small hole, leading into a chamber of lower pressure.
Source
Source
Andrew Haynes
Thanks you two for the info.
S_Sesselmann would that arrangement work without the difference in pressure?, what voltage level could it be with the right pressure variables?
I've added the idea to the drawing its a easy voltage doubler, and plan on useing a Rocker 300, 220V/50Hz oil free vacuum pump if the 300 means something....,
Andrew Haynes
Steven Sesselmann
Sorry Andy, I don't quite understand your diagram, but in regards to the vacuum , you are going to need something better than a rotary pump, if you are going to experiment with ion optics. As Richard already explained, you need a high enough vacuum for the ion to have a sufficient mean free path.
Andrew Haynes
The path doesn't need to be long, from one end cap to the anode will be 1mm or less, or just don't want a arc discharge.
Thanks
Andrew Haynes
Steven Sesselmann
Andy,
Well in that case you will get an arc discharge of high current and low potential.
Not sure what you are trying to achieve with this experiment...
Andrew Haynes
S_Sesselmann
I'm trying to make electron get accelerated from the anode to the end cap, but still not have a conductive path between the two. I thought that if the vacuum was good enough a electron won't start a averlance (spelling).
If I run this connected to a 15kv nst the voltages should add up , once the ac is reciftered, it should be easier than high frequency or having caps and diodes handle the full voltage
If not I can use salt water, but the efficiency will be lower.
Thanks
Andrew Haynes
