Measuring Voltage on a Computer
- Real name: Aidan Cookson
I was wondering if anyone has any tips on measuring continuous voltage and or current through a computer to collect and graph? For the time being, I am planning on going up to 40 Kv at 10mA. I was thinking of using a standard 1:10000 voltage divider then hooking it up to a multimeter(set to 40 DC V max) with an RS232 serial port to USB adapter.
Here is the device I was thinking of purchasing: http://www.multimeterwarehouse.com/MS8226Tf.htm
Would this work or is there a better/cheaper device I could use? I want to measure as many things as I can as this is for a school project, so it will be used for research.
I have also heard that 20mA is the minimum current, but you can get by with less if you have a good enough vacuum. Is this true, or am I confusing two separate factors?
- Real name: Ross Moffett
Re: Measuring Voltage on a Computer
That can be made to work easily for a single data point, and with a bit more effort, for two.
There are better/cheaper devices for data logging in my opinion, but in order to use those you'd need the kind of knowledge far beyond knowing only what they are. I turn to Arduino for most temporary breadboarding and make a permanent circuit later if it's necessary, when the debugging is finished. There are also devices 10x more expensive that do basically the same thing as that multimeter, but feed into some proprietary system (National Instruments, here's looking at you).
A cheap option is a Teensy 3.0. It has a much higher useful analog resolution, 13bits. You just need to scale down lower, no big deal. It is programmable with the arduino software kit too. And only $19.
Ok thanks, I'll look into those. Do you know the maximum voltage I can input into the Teensy 3.0 board? Im trying to figure out what scale it needs to be.
The teensy is a 3.3v chip, so I think that is the limit. No big deal, just change the values of your voltage divider. Make sure you use high value resistors so you dont load down the little output you have,crabcookies wrote:Ok thanks, I'll look into those. Do you know the maximum voltage I can input into the Teensy 3.0 board? Im trying to figure out what scale it needs to be.
I recommend a $29 USB DATAQ device. You get 10 bit resolution from -10 to +10 volts with a Visual Basic interface.
see http://www.dataq.com/products/startkit/di145.html
For the high school students out here, they give them away free...
Thanks, i'll check that out too.AllenWallace wrote:I recommend a $29 USB DATAQ device. You get 10 bit resolution from -10 to +10 volts with a Visual Basic interface.
