Archived - EXP: A New Year's treat; Crimzon doughnuts.
SUMMARY:
Type of Experiment: Penning-type fast-ion toroid, proof-of-principle trial.
Drive voltage: 1000V
Drive current: 14uA
Ion energy: Presumed possibly up to 1keV
Ion current: Inferred to be 1mA
Conditions: 0.15T. air background; controlled to 1 to 20 microns by a bleed valve to atm
Outcome: Imaging of a toroid lacking any apparent electron-recombination irradiance
Diagnostics: Only visual imaging, to date. Subjective analyses only.
Prognosis: Ongoing experimentation required, initially with various e-field regimes and further subjective visual interpretation.
Specifications:
magnetic head = 150mm x 150mm x 52mm, 6mm mild steel plate
working space = 40mm gap, max. 65mm operational radius, kapton tape for e-field modification
outer electrodes = 4 x [approx 80mm x 25mm], copper, mounted to bakelite supports and aperture moderated by teflon wrap
inner electrode = 4 x coupled 1mm SS rods
magnets = 4 corners x [3 pairs x (22mm diameter/20mm high 'discs', N42)] = 24 magnets, total, wrapped in 0.5mm teflon sheet.
______________________________________
I have been contemplating when might be a good time to feed in some initial work from my experiments and have concluded that the forum could do with a fresh injection of something new right now. Also, to me personally this new year and decade feels like it has promise of things to come and I would like to invite and incite you all to the same degree of excitement and expectation as I have!
So, I will introduce an outcome of my work and see what you think of it. (I especially dedicate it to Carl who has been hanging on so loyally to this forum, through some tortuous exchanges of late, just to see some new experiments.)
Now, please take on board that there is much I don't yet know about my own experiment. The work is ongoing. So whatever I might say about what I intended the experiment to do, what I think it does, &c., all of that might be wrong, and for now you will have to make up your own minds on what you're actually looking at. I will therefore be trying to say, and reply with, as little as possible so as not to bias your opinions of it.
The first picture shows the assembly that I have installed in my 'bakelite' chamber (as per viewtopic.php?f=15&t=7222#p49094 )
It is designed according to the principles of my assembly; viewtopic.php?f=15&t=7189#p49061
..but that there is now a central electrode and 4 outer electrodes, each with an independent connection. The actual design intent is to have transparent grid-like electrodes so that scattered ions might be recovered back into the working volume, which also means those permanent magnets wouldn't be there. So this is just 'demo' kit to explore proof-of-principle. The design intent is that the inner electrode and chassis are +ve and the outers are -ve so that, if you like, the intention is that there will be 4 'little fusors' within a magnetic field with planar cathodes but that the recirculating ions get caught in orbits in the magnetic field whilst they are inside the magnetic field.
To put it another way, it is a Penning trap with the end electrodes having been pulled into the central axis. And, whereas a Penning trap tends to accumulate ions at its centre, because I've stuck an electrode in the middle then they can't accumulate there and instead orbit further out.
Or... to put it a third way, it is an 'ion magnetron'.
The second picture shows a closer view inside the device between two of the magnet/electrode 'corners'. The reason I put that particular image in is because the last image may be difficult to orient yourself to, without having the day-light view to compare it with.
The second and third images are exactly the same view but that the third has 1000V applied and is drawing 14uA. That is a total indicated input of 14mW! (and of course, it is in the dark! The image was a 15s exposure and I still had to push it 3 stops [effectively a 2min exposure – my camera doesn't do more than 15s!]). Pressure was around 10 microns, but I wasn't watching that closely and I can't vouch for the accuracy of my gauge.
My interpretation is that there are no visual electron recombinations going on at all. The light is purely what is being generated by fast-ion stimulation of background neutrals, implying both that there *are* fast-ions and that they have a concentrated density in an orbital track where they are colliding with the backgrounds, as was the design intent.
Now you may say, “what's the good of 14uA! That won't get a fusor going!”. That would be to misunderstand that this isn't a discharge plasma, as in a normal fusor. The electrons are all but arrested in this magnetic field and so there is essentially no conduction, save for a small dribble of orbit-hopping electrons and scattered ions. (you might like to note another previous post of mine; viewtopic.php?f=6&t=2854#p12364)
Instead we can look to the physics of the Penning trap and note that the Brillouin limit would suggest a density limit for protons of 4e14/m^3 in a 0.15T field (which it has been measured as). In turn, the rotation frequency of 1keV protons [just an example species that might be in there] would be 1MHz which, presuming there to be 30cc's of torus there (because I have noted that the vertical extent of the torus is that of the electrodes, and I have restricted that to 1cm here, and that the radius is ~4cm) then the ion current might therefore be calculated as 1mA past any given point in the device.
You might still think that is still little, compared with what gets a fusor buzzing, but now consider that the ion current in a fusor is, at best (according to my analysis), 1/240 of the applied current due to the way the electrons run around in the fusor's discharge. (see my previous post; viewtopic.php?f=14&t=6831#p42514) So I would hazard a guess that, e.g., a 5mA fusor is pushing no more than 20uA of fast-ions around at any one time.
The comparison with a fusor, then, is that the image below may depict the input of a 14uA current for a 1mA ion current, whereas a fusor puts in a 5mA current for a 20uA current – a potential improvement of around 5 orders of magnitude if these interpretations bear up.
Now bear in mind that Brillouin teaches the confinement is proportional to B^2, so if someone were to build a x100 factor = 15T version of this device, (which seems plausible, given the small volumes possible) then presumably the improvement might be x100^2, or 9 orders of magnitude in total... ..fine promises, indeed!!
As mentioned above, I may not be particularly forthcoming on discussing this as I might usually be, until such time as I have progressed experiments, so please do make your speculations and don't expect me to know or be able to correct you, because they are probably nearly as good as mine!
Happy New Year!!!!....
Drive current: 14uA
Specifications:
Re: EXP: A New Year's treat; Crimzon doughnuts.
Chris, great experiment, nice pictures.
I wonder if the apparent "volume" of the torus, may be due to the time exposure in combination with the radial instability of the ions as shown by the simulation by dave cooper ?
download_thread.php?site=fusor&bn=fusor ... 1219430899
Best Regards:
Kevin.
Best Regards:
Kevin.
Absolutely possible! Though just to clarify, I have already re-built this experiment a few times and in the first instance, those electrodes are an inch high, and the torus was an inch thick. So I figured that the e-fields were directed in such a way that ions could, without stepping against any energy gradients, move anywhere within that height. So, naturally, I reduced the electrode width (all I did was roll teflon tape over top and bottom, which you can see) and the torus shrank accordingly.
Perhaps I might just replace it with a horizontal wire at some stage, though I suspect the e-field strength will begin to drop off so much that containment will be lost and nothing will be seen. But, yes, it suggests further possible experiments and ions would be free to execute epitrochoidal orbits. That's pretty much why I was thinking I might calling it an 'epitrokotron', if I was in need of a particular name for it.
The Teflon tape result is interesting given that the static permittivity is about 2* the vaccum permittivity, and should not have eliminated the electric field, only the electron conductance in the insulated region, unless I have misunderstood what's going on (quite possible at this stage).
Regards:
Kevin
Regards:
Kevin
Hi Chris,
This is a cute piece of equipment, and yes, I'm pleased that there is physical substance here to talk about. I think "ion magnetron" adequately summarizes the operative idea. Thanks for the photos.
It looks like the central anode is comprised of four or maybe more parallel wires. What did you have in mind with that?
The discharge appears very red in the photo. Just looking at it by eye, does it appear this color? I would not expect that color from a gas discharge, but sometimes solids placed in an environment with a lot of particles and radiation produce these vivid colors by fluorescence. Just another thought.
As might be expected, I do take issue with your suggestions about trapped ion density, current, and energy in your device and the comparison with a fusor on some of the same quantities. I think all that is pretty much as close to totally made up as one can get, to the point of being worthless or misleading even for illustrative purposes. As you admit, even the first assumption--that the major species might be protons--is a big stretch. That they might be present in the magnetron at something close to the Brillouin limit is another big stretch. Then there's the 1-keV assertion. And so on about numbers for the fusor. I just don't see value in all the speculation.
Consider this experiment: If you are trapping protons in quantities like your supposed number, the stored charge in the trap is ballpark on the order of the capacitively-stored charge on the magnetron electrodes and the trap filling current will be noticeable (relative to the capacitance charging). Although crude, such an observation would probably be accessible to your budget and apparatus, and would be something concrete to hang your assumptions on. You'd know in one fell swoop that (A) the trap is actually trapping something, and (B) you'd have some bounds on how much charge is there. With some better experimental control, you could probably make the convincing argument that the background gas is mostly hydrogen and the trapped species mostly protons. There may be other creative and effective methods for getting a handle on ion density without going broke, but this is what popped up in my head. With amateur fusors we have gone on a long time without much of a handle on these numbers because they're hard to measure, and consequently there hasn't been much to say about them.
Not sure I follow. It is non-conductive and therefore will 'hold' an electric field. The fact that it works (and appears to work very well, without complication), might suggest that there is only ever imbalanced local charge there (ions only?) and not a neutral plasma that can interact with it.
But.. as said, your guesses are good at this stage...
Yeah, don't worry about that in this particular experiment. I fitted this in the last cycle of testing in preparation for some further studies. Basically, one of my ideas is to form extra ions at the centre by appying a smaller differential potential across the different wires (they are each independently connected - but currently are tied together at the same potential). That way I might anticipate that ions formed at the centre can be accelerated to the full outer potential and are therefore likely to 'enter orbit' at 'full speed' to the applied potential. But that is not operating in this pic. All ions begin generated are being generated by the self-maintained ionisation of fast particles within it.
Yes. It looks almost exactly like this to the unaided eye. With a little more power being fed in, perhaps I might say slightly more 'orange', but it is a very low intensity colouration and I have no reason to tell you this isn't a true representation of the colour.
I tried to get a video of this yesterday, but the camera I've got just isn't sensitive enough. I get a 'usual' purply glow at, say, 0.1 microns then as I bleed gas in it changes to this deep red colour.
I do not consider it a gas discharge. I regard it as pure excitation of the backgrounds, and, thus, no 'purple' colouration from electron recombinations. Unlike a gas discharge, I would suggest you're looking at an image free of visible electron activity.
Sorry, I mis-directed you there. I was merely trying to indicate the range of rotational speeds for the different species, protons being the most extreme.
What I would say is this; if you run through Bq=mw (or Bqr=mv, if you like) then the only things you find that would fit for B=0.15T, an r of around 4 to 5 cm, and E=1kV are particles of m/q=2. So my best suggestion at this time is 2H+, seeing as I am using only air as the background medium so at this pressure it'd be mostly water. What I can say is that it takes a short pause for it to form up, and if I made a presumption that it is doing a m/q selection, then it is hardly beyond the realms of possbility, given the setup.
If there was a focussing accumulation of ions at the given radius, then I would expect it to run up to the Brillouin limit, then self-limit itself. This is the design intent. Again, of course I cannot say this is so, but that's what the 'theory' is aiming to do.
This is exactly what I designed the thing to do, so I have no reason to 'self-doubt' what I've done just yet. If I designed it to accumulate ions in a toroidal focus... and it appears to do exactly that in an experimental trial... then I will keep an open mind that I just "got lucky" but I'm not going to presume in teh outset that my design intent is the least likely thing to happen!!! I'm now looking for indications that it *is not* working as I intended it to, and so far I have no reason to think other than it is working as designed.
It's driven by a 1kV potential. How fast do +1 ions get in a 1kV field? And what else would orbit at 4cm radius in a B=0.15T field?
Not sure how I would measure that. The issue is that it is not yet design intent and I would expect a continuous stream of losses into the electrode as they are solid and as there is not yet the design-intent recirculation (like 4 little fusors). When I power it off, the torus dies almost instantly, so the energy confinement time is too short to take any such measures just yet. Is there some other way of doing the measurement you envisage?
For now, I am just exploring the e-field configurations to see if I can come up with an outcome so blindingly clear that further diagnostics would be merely a cursory exercise.
In return, I ask a simple question of you: How else do you explain the ring of emissions in a B=0.15T field, as you see here, if there isn't circular ion entrapment going on? What other explanations fit the photo? If it's easy to say there may be other explanations, other than mine (and for which this specific design was created to perform), then I guess it'd be easy for you to say what they are? And they are...?
OK, got it now I think!.
The surface of the Teflon exposed to the ions, will take on a positive charge effectively becoming another anode region.
- Kevin
- Kevin
As mentioned, at slightly higher powers then the colour appears to shift a little towards orange. I guess that some electron recombination begins to creep in. Anyhows, I did sellotape a cheap diffraction filter onto the camera lens and I obtained the following spectrum (that is to say, for slightly higher power/voltage inputs).
Looks much like water and nitrogen would, I think?
I've dug up another photo for you to eyeball.
So this is the slightly higher power that I took that spectrum off of.
All 0.1W of input!!! (2000V and 50uA, or so)
These higher voltages seemed to generate electron emissions around the outer electrodes themselves. And, in fact in this image you can see a little trail of electrons that has punctured the teflon around the magnets and has created some sort of discharge channel there. (and maybe this will show that the 'blues' are actually being represented in the image).
The image is looking along (parallel) to one of the electrodes. You can see another electrode directly facing you, and we're peeking from just beind one. The toroid becomes more 'square' as it closes up on the electrodes (the e-fields are less axi-uniform than towards the middle) so that we're looking 'along' a somewhat straighter section of the toroid.
If the voltage is ramped, the containment edge reaches the electrode and 'tick' - we get regular gas discharge fireworks and the current and power will 'shoot through the roof' (if not limited).
Hi Chris,
The ions might reach 1 keV if they were formed at the center and made it to the cathode. If they are not found at the cathode radius, and did not originate at the center, then there's no reason to assume they are 1-keV ions. I was pointing out that this number is an assumption. As such, I do discourage putting too much credence in it.
I suggest setting this up with an oscilloscope that looks at the voltage drop across an appropriately-sized resistor in the power supply lead. Under voltage / pressure conditions where no steady-state discharge current flows, the transient current in the resistor is due electrode and wire capacitance when the sauce is turned on. Under conditions where the discharge forms, the current in the resistor would be the sum of the capacitive current previously measured, leakage current from the discharge, and current corresponding to the buildup of charge in the trap. The time integral of the trap-charging component would be a ballpark measure of trapped charge.
I can't be a backseat driver on such an experiment, I can't troubleshoot it, I can't guarantee it is easy or doable, I can only make the suggestion in general terms. The take-home message is simply that if you come up with a method of measuring trapped charge, that number would be infinitely preferable to assuming your design value by default.
I like the photos. It's a pretty discharge, and the magnetron is a fresh departure from the more-usual fusors and ion sources that fill the annals of this forum.
Indeed I agree not to make that assumption, but I hope, in due course, I will sufficiently explain to your satisfaction why ions formed anywhere in the device may attain that drive potential. And I repeat and reaffirm my caveats above - don't let me bias what you think at this stage.
Though - I would still be interested to hear your answer to this question; what else would orbit at 4cm radius in a B=0.15T field? Also, why else might we see such a structure?
I am currently looking to find a way [within my means] to disprove that it is so. It is not yet disproved.
I can do that. Not sure I quite understand why that is so definitive, but I will try to reconcile these measurements with this suggestion.
I'm glad, and I hope it's made your day (in particular!).
Again, to reaffirm my previous comments, I am not stating all that I could about this experiment just yet as I am unsure about much of it myself. This was [hopefully] just a 'spoiler' for things to come, and to get the year off on the right footing for the forum.
- Steven Sesselmann
Chris,
Congratulations on some fine work, nice to see some new ideas.
The picture in the above post, looks amazing, are the boundaries of the toroid as sharp as they look?
I can see a sharp red boundary, giving the impression that it is tube like.
yes, generally this is what you see, but in the case of this last photo, you are looking down through a very straight part of this thing and so it is a little misleading. I took the pic just to show it wasn't a discharge in direct contact with the electrode, and at this particular point it followed the (flat) electrode, so you're looking through, as you say, a tube-like section of a few cm of the stuff.
I've just run what I thought was your suggestion but I'm not sure I really follow the applicability (now that I've done it).
At the highest pressures this thing appears at, around 20 microns, (above which you get both regular and 'odd' gas discharges, in my particular setup at the moment) the maximum current to which there is no visible thing happening, as measured by a DVM across a 470ohm load, is 6.8uA. The minimum current for which there is something visible is 7.7uA. Above that, the current will ramp up as much as you want unto >200uA when you start getting discharge modes again.
At the lower pressures of operation (around 1 micron), there is much the same delta but higher currents - with 9.7uA max current for nothing to appear and 11uA for the minimum current for something.
As I say, not sure this quite applies because (forgot to mention, amongst many other details) it appears you can set both voltage and limit current independently. A given voltage doesn't necessarily draw a given current, unless you permit it to, so it appears, which is again why I say it is not a discharge plasma. Not sure if that is a characteristic of my power supply, but basically you can dial in the voltage you want (within the range for which it works) then you can independently set the current limit, and it is quite happy and steady state is possible for a wide range of V and I settings. All that changes is the position, and the visible intensity, of the emissions. Whether there is some high frequency current switching going on unseen, I do not know, but it doesn't look like there is.
I don't want to be a "heavy" - here, but Chris - What is it that we are looking at? The pictures are very pretty.... I think from your discussion that you've built something that has a single central rod electrode ( that we can't really see) with four other electrodes arranged around the central axis, at some relatively small distance out from the central electrode. The space around all this is filled with a magnetic field established by permanent magnets (presumably) creating an axial magnetic field(?) of how strong, how uniform? The magnets are at ground potential (?) making some kind of radial electric field, which bumps around the rod cage.
Your explanation suggests that ions are produced by the four plus one central electrode assembly, which then circulate in the axial magnetic field. The ions do not recombine, per your explanation, but essentially produce molecular ionization (or excitation) of other neutrals, whose relaxation from their excited state is the source of the deep red glow we see???
Am I even close to understanding the experiment, you're doing?
A simple circuit and hardware diagram would go nicely here, to help appreciate all that's happening.
Did you say what the gas was? Deuterium, Oxygen, Hydrogen...or ???
Sorry to be a bit sluggish here.
- Steven Sesselmann
Dave,
Chris has already answered many of the questions you ask in his prevoius posts. If you follow the links in the first post in this thread. Chris gives specific information about the magnetic field, and the assembly of the apparatus.
Steven,
I think a lot of the confusion here arises from Chris's explanation of a design that originally consisted of magnets for confinement, then had five electrodes added, and is 'operating; in 'demo mode'(?), with magnets and electrodes, but will not have magnets in it's final form, so will consist of five electrodes.
Chris has often talked of combined magnetic/electrostatic confinement in the past, as being the key to improved efficiency in a fusor.
I think what Dave is asking for, and what would help a lot of people to follow this experiment, is a simple, brief explanation, with a 'diagram', of the method and objectives, rather than having to search through endless links to 'pick out' the relevant information.
In short, a 'brief summary',
No, you're not close - you're bang on! Clearly I have said enough for you to comprehend it!
In regards the details of the conditions, as Steven says I have said all of this but will re-iterate these points so as to confirm them, and also add them to the extant 'summary' at the top:
Mag field = 0.15T, variation across device <5%, background; air, 1 to 20 microns controlled by a metered leak whilst running the turbo unthrottled (i.e. high through-put flow rates).
I guess I'm just concerned that the 'summary' might end up getting too long and someone will then want me to summarise the summary! This isn't a trivial experiment and has taken two years for me to get it all together (partly because I didn't know what it was supposed to look like!! - I have no plans to build to, I'm out on a limb here and 'winging it' as I go...).
You might begin to note that I have scattered the background to this amongst my posts over my 20 months of posting (yes, it's only been that long since I appeared here!). I guess about 30% of my posts directly or indirectly relate to this device, and I will create an anthology of those posts with some text to gel them together at some later stage, if it turns out to be worthwhile to do so. I was essentially aiming to provide background and build up understanding of my plans here these last 20mths before springing this on you, hence you will have to go rummage around if you want the fullest insight ahead of me creating a 'compiled works'!
On the matter of what I've set up for the e-fields: basically, I'm gonna flat out dodge the question! This is because I don't really know. I could say all that I am doing, but then that'd be another long post of speculated theory, and this was just to be some pretty pictures in Images du Jour. So please treat the subject of this thread as just that - mainly pretty pictures.
I've given a taster for where I think the theory sits just to give it sufficient context that they aren't abstract images, but as and when I have some level of ability to say with greater knowledge and insight than you, *then* I will discuss it further. For now, you may well guess better than me.
The reason that I'm not yet going to discuss what the e-fields are up to is because there are many many dielectric surfaces in this, some of which regularly break down (!) and therefore presumably many might be running in dark discharges without me noticiing. There is also plenty of electrode surface. So, taken altogether, I anticipate there are multiple sheath interactions and discharge processes going on which may dominate the e-field behaviour. I am therefore making many multiple alterations to the experiment to see what makes a difference and what those differences are. I don't think it is appropriate to speculate, then, beyond the most cursory 'working-explanation' of what we might be seeing in these photos.
I hope that properly gives the right level of 'caveat' coverage for now!
Hi Chris,
Well, the applicability would be to establish (A) that your magnetron does in fact trap some charge, (B) that it traps a particular quantity of charge, and (C) ultimately it would motivate scientific conclusions about particle density and circulating current along the lines of the numbers you came up with earlier by a daisy-chain of questionable assumptions.
What did your experiment entail, and what were the results? Are you able to capture a 'scope trace of the inrush current and post it?
For reference, attached is a figure from Greaves R., Phys. Rev. Letters 74, p. 90-93 (1995). The experiment has something to do with argon ions in a Penning trap, and they measure the trap filling by looking at the power supply current. The inset in the figure is a raw 'scope trace. The main figure is stored charge versus trap potential. For them, the kind of experiment I mentioned yielded useful data (though it has a lot of uncertainty as the error bars show). Your mileage may vary. This approach may not be useful in your situation.
Sure. That looks easily do-able.
So, is it the integration from baseline to peak, or to the knee of where it settles back down to the steady state loss.
Thanks for the suggestion. I'll get onto it.
Chris -
Thanks for your confirmation. A detailed description of electric fields under plasma conditions is indeed difficult.
I have something to add in case it prompts anyone to pitch any new ideas on what is going on here (or alternative set-ups).
In the case of this experiment, and also of the images in download_thread.php?site=fusor&bn=fusor ... 1263249888 , I can say that I feel I chose wisely to construct a chamber that was fully lined by dielectrics. My latest round of experiments has been looking at holding various parts of the device at a fixed potential wrt ground. It turns out that if I do this then these plasma structures don't appear.
I've tried holding various parts at the external ground potential - tieing the +ve electrodes, the -ve, and even tieing the mid-points of parts, by a couple of multiMohm resistors. No substitute seems to permit these structures to develop.
This wasn't really my expectation...
What might this tell us? I guess it merely confuses the picture somewhat with additional complexity but perhaps some form of self-organisation is going on where the potential of the whole device, and thus the plasma in it, 'adjusts' itself wrt the potentials on the chamber surfaces. So I'm guessing here that the accumulation of charge might only occur if there is some surface charging going on around the assembly that finely balances the increasing potentials inside... or..?
In the event that anyone looks at the above image and thinks 'hmm - that looks a bit vauge and blobby and I'm not sure it's circular', then I attach this image to show interesting discolouration patterns on the upper (and same on the lower) electrode after a number of various runs (and during a refit for a change of outer electrode topology).
Again, no specific observations but a few guesses might include electron irradiation from electrons being accelerated straight into the +ve plates (which would be parallel to mag field, so no consequent trapping and pretty much the only direction they can take) from the small background ionisation that would, presumably, be going on locally around the visible 'confinement' region.
I treated myself to a new DSLR today, particularly choosing one with a long 'bulb' capability on it to help image this work. (It is an Olympus e-600 which apparently has a bulb capability of 30 minutes! Me thinks I might out some astronomical imaging with it!!...)
I've added this image to the top post so that it can be compared directly to the first image. I allowed a little light into the room during the exposure to help make out some of the structures in the vessel. It differs slightly in that this configuration has a solid central electrode and I have replaced the outer electrodes with wire electrodes in this particular set up (they are the horizontal wires, which you can just make out in the background - there are two parallel horizontal wires at each electrode position where previously there were flat copper pieces).
