The Nature of Charge
Re: The Nature of Charge
I’m trying to tie in relativity into this.
A charge creates two fields.
The first field is an electrostatic field, which is static in magnitude, and extends radialy outward from the charge.
The second field is the magnetic field. It has a variable magnitude which is proportional to the Inertial frame of the observer relative to the inertial frame of the charge.
Its field also has the direction of circling the axis of this relative direction.
Here’s what’s weird about this theory. For the magnetic field, its magnitude, and direction depends entirely on who the observer is, and can only be established if there is an observer. Where the observer is in a different inertial frame as to the charge (i.e. the charge is moving relative to the observer).
Is this correct???
Any thoughts
Is this correct???
Any thoughts
Is the general idea correct? I would say "Yes", more or less.
A stationary charge does no work. The detection of its "field" -the force between the charge and a small test charge - is assumed to be an arbitrarily small energy process, so as not to perturb the field of stationary charge. Reasonable enough.
If the charge is in motion relative to the observer, its motion constitutes a current which will have an associated magnetic field circling the charge's path in one direction or the other, depending on direction and charge polarity.
This perceivable (detectable Magnetic field) does no work either, until and unless it interacts with something conductive or magnetic. When an interaction happens, then energy is exchanged and the moving charge changes velocity and possibly direction. Conservation of energy seems to work, as does conservation of momentum.
So the establishment of a magnetic field which does nothing but depends on the presence of an observer, while seemingly a bit odd, is actually quite reasonable, and consistent.
- Real name: Todd Massure
This has been something I've pondered before.
Take an electron beam traveling at let's say approximately the speed of the beam in a CRT display ~ 30kev. The beam stays columnated because of the magnetic field it produces due to it's motion (pinch effect), BUT, what if the observer is traveling along side at the same speed - would there still be a magnetic field to keep the beam columnated? What if there are two observers, one stationary and one moving along side? Hmmm...
Todd
Todd
- Donald McKinley
- Real name: Donald McKinley
Roger,
Greetings.
I'm sure I'll get clubbed about the ears for this, but here goes. This is based on the presumption of the electromagnetic force being the only fundamental force.
If you hope to ever understand this topic on a low level you have to think in low-level terms. When you speak of measuring magnetic fields, you are already on a higher level that deals with matter and charge and reactive forces.
If you will forgive just a teenie weenie little bit of handwaving, IMHO The lowest level manifestation of the electromagnetic force consists of three components which sustain each other and cannot exist without each other. Those three are the electric effect, the magnetic effect and the accelerative effect. Even the name electromagnetic force suffers from an embarrassing lack of respect for the accelerative force.
There are those here who think that magnetic effects are a relativistic phenomena. That is the understanding presented in Richard Feynmans 3 Volume lectures on physics. (Forgive my narrow reading) If you are talking about a high level in the realm of charges and matter, that may be true in a sense, but I believe that the components of the EM force are the cause of relativity and not the effect. Need to be very careful in the attribution of causality.
On a low level, measurements cannot be made. Reality must be inferred. Making some simplifications (which is a dangerous thing), Electromagnetic effects are propagated spherically unless there are impediments. If this is true this means that the magnetic force is also propagated spherically. If it isn't then you are saying that electrical effects can exist without magnetic effects. This cannot possibly be true.
When you think on a low level, its imperative to always keep in mind the right hand rule and all three components. Try not to use compound applications of the right hand rule. Keep in mind that in the case of an object that is moving there will be an equal magnetic field and electric field associated with the motion. If the object is charged, then you have compound fields that rapidly become confusing because each portion has its own 1 to 1 to 1 relationships and if one component of the three happen to coincide and not cancel it is easy to start ignoring things.
I strongly doubt whether on a low level, (before particles) there are any internal reactive forces at all because of the 1 to 1 to 1 relationship of the components of the electromagnetic force. I seems that the 1/1/1 internal relationship must be instantaneous. This is definitely in contrast to reactive EM forces where there are hysteresis delays and the acceleration is not intrinsic but is supplied from outside. I believe that the quantisization of physics results from the non changeable nature of the 1/1/1 relationship.
I have never met anyone who had a good understanding of the low level EM force (I should call it EMA with the A standing for acceleration)
Anyone who understands the EM force well should be able to explain the origin of hysteresis as well as thermodynamics from an electromagnetic point of view. Also the origin of mass must be explained. I draw a blank even though I believe that it is probably true.
If you want to make progress you have to work through a lot of seemingly flaky ideas. Most of them will, of course, not pan out.
Don
Greetings.
Don
An electron beam in a CRT WILL NOT self-focus due to pinch forces! Whether you are at rest observing the beam or riding along with it, ALL the electrons will repell from one another at all times! The beam will be observed to fan out. This is regardless of whether you are part of the beam or watching it from the outside.
In a CRT, the beam is, initially, electrostatically focused, (electron gun). It is EXTERNALLY, magnetically held intact and guided by a coaxial mag field, (deflection yoke). The electrons are accelerated to hit hit the screen by the anode.
The electrons want to scatter to the four winds the instant it leaves the gun! Only the externally generated magnetic field of the yoke keeps those puppies from leaving the crowd. The energy expended in the average deflection yoke is significant!
Electrostatic forces never rest, they never letup, they never go away. They are primal! Only a heaping helping of outside energy, properly applied, will offset these natural urgings, keeping them together and on a collision course with the TV screen.
The pich effect is an effect of extreme current as there is no significant current in a CRT electron beam, the magnetic field presented by the electron stream in a CRT is close to ZERO, as is the pinch effect!
Richard is correct here, of course.
The electron's charge exerts a mutually repulsive force on all other electrons in the beam. The beam focuses because there is an inward momentum (radial direction) imparted by either the electrostatic force from the focus lens or the external magnetic force on the moving charges. Most CRTs use electrostatic focus these days.
So electron beam focus is the result of an external force for LOW current e beams.
At very high current densities, the e-beam can become self focusing. Don't have that current density at my fingertips, but it's far beyond normal CRT current densities, - I'm thinking kilo amps per sq mm, - and quite probably beyond the emission capabilities of the standard tri-oxide cathode materials.
That's a fun calc.... I'll take a stab at it later today.
I can't see how it's possible for a beam of electrons to ever be self focusing. At least with the special relativity trick of putting yourself in the viewpoint of the electrons, you can see there is no way for the charge density to reach zero, and definatly not become positive since there aren't any positive charge there to begine with.
Carter - From the hitchhiker's viewpoint it DOES seem a bit mysterious. From the stationary observer's vantage point the moving charges produce a magnetic field, that can easily be detected, with either a compass, an inductive link (current transformer or Pearson coil) so something is there.
I think the field is perceived by the hitchhiker, whenever there is a tendency for the charge density to change.That dQ/dt makes a corresponding dE/dt which generates a local magnetic field B. Conservation of energy (Lenz's law in other garb) sets the B field to oppose the charge density change, thus tending to keep it constant. This is part of the self focusing effect.
The rest comes about when the charge is initially accelerated, which generates a focusing B field.
The part that is intriguing here is whether there can be a "field" that your meters (the hitchhiker's ) can't measure. Sort of like the tree falling in the forest, question.
I'm guessing that the self focussing effect (if it in fact exists) is do to the magnetic field.
As the electrons move they produce a magnetic field, and with more then one electron these fields combine, and create a force in the direction of pulling the electrons in closer.
If my guess (above) is correct, then wouldn't this effect become more pronounced with increasing electron velocities (i.e. higher voltages)?
Rog
Rog
Rog
Rog
I see that some other messages have been posted since I started writing, so excuse the partial redundancy.
The self focusing effect would not come from the charge density going away or any of the charge becoming positive, It would come from the magnetic field being produced by the current of the beam which would continually deflect the electrons back in on themselves. The electrons both produce the magnetic field and are affected by it obeying the right hand rule in both cases.
Actually it seems that the only way that the scenario can agree with relativity would be if it were in fact impossible to have a self focusing beam. If the current density required for for a self focusing beam approaches infinity then only a beam traveling at light speed would not spread out (theoretically impossible) and an observer travelling at light speed would not percieve the passing of time. I probably won't attempt to calc it out tonight, but this is one that's puzzled me for a while.
Another property, which has puzzled me, is the idea of an electron perfectly (very near to) orbiting a proton (nucleus).
The analogies of comparing the orbit of a satellite around the earth, I find to be in adequate, as much effort is put into placing it there. Where as an electron seems to find this stable orbit all by itself. Why doesn't it just spiral into the proton? What forces guide these electrons in to these orbits?
Rog
Rog
Roger, physics can answer your question with a riddle and the need for faith. (read this as they don't know really). The important thing is that the electron doesn't classically orbit as you might imagine in a simple planetary model fashion. This Bohr-Sommerfield atom sorta' died for the high end physicists in the 1920's.
We are told the electron doesn't radiate yet to orbit in the classical sense, it would have to be in constant acceleration and thus radiate. Instead, it just comes to a dead stop in a kinda' orbit or energy band just shy of killing itself smashing into the proton.
I find solice in that it doesn't obliterate the proton charge due to the ultimate law of physics. Charge can neither be created or destroyed. Nature does what it does by whatever process to prevent this by finding the closest observed approach of a proton and electron in the neutron, (atomically), and in the hydrogen atom, (molecularly).
Many mysteries with no solution in hand that truly satisfies the mind.
Quantum mechanics makes a number of ridiculous suggestions and assumptions to make it go both mathematically and physically. This is all due to experiments that gave whacky results about 100 years ago that they had to 'splain away to their mathematical satisfaction.
It is probably best to just take things on faith for the moment until more understanding is at hand. Follow what the quantumists say, but don, t really believe a word of it.
I know a few annointed physicists who follow the dogma in lock step but chuckle to each other in private. wink, wink, nudge, nudge.
Hi Roger:
Richard and Dave are both correct.
Relativity relates matter in motion and energy at rest E=mc^2
But what they won't tell you spitttz come into the back alley.
Look in my truck.
When you wind a spring the energy you put into deforming that spring using hooks law is actually relativistic. HUH? Just what I said. Any system that uses conservation of energy rules is relativistic. The spring actually gains mass equal to the input energy..so tiny that no one can measure it with normal means.
Leave it to Tricky Dick (Richard Feinman) to actually measure it at Cal Tech. He proved it by hanging a dry cell battery on a balance and used an inferometer at the balance pan to measure it. Well the pan balance didn't show anything. Dick almost lost a 1000 dollar bet to NBS but the inferometer showed the weight gain when that dry cell was charged the energy the dry cell used to charge with was plugged into e=mc^2 and blamo the mass checked.
Charge is mass independent no matter how you slice it ...can't change it. Ex. Fission a U235 nucleus the charge balance on the electric side never changes at all all the pieces (fission fragments) and all the original electrons in the unsplit U235 are equal despite the fact 200 mev of mass just vanished. Therefore charge does NOT behave relativistically. The electrons with the destroyed mass fraction still remain the same. unchanged. What is a charge? Tell me where God is and I'll get right back to ya!
Happy Fusoring!
Larry Leins
Fusor Tech
Look in my truck.
Happy Fusoring!
Larry Leins
Fusor Tech
Todd is actually much closer to the money. I came up with the same question a few years ago after playing with rareified gas tubes and magnets. A few ma will collapse from a diffuse plasma against the scattering effects of the gas ions due to the magnetic field produced by the beam. A weak magnet would send the thing into loops, so that suggested magnetism was indeed strong enough to be responsible.
At first glance the passage of electrons does apear to be different in different frames of reference, and there is no need to invoke einstein, this is newtonian relativity.
The solution to the basic quandry is actually rather simple, the universe is neutral. So if you have static electrons, with no current in one frame of reference, then you also have counterbalencing positive charges (ions, nuclei, positrons doesnt matter). The electrons do not move relative to the positive charges, and so there is no magnetic field in the stationary frame of reference. Change to a moving frame of reference and the positive charges and negative charges move in the same direction at the same speed. Still no current, and still no magnetic field. Whatever frame of reference you choose the relative speed between the positive charges and electrons remains the same, so the current is the same and the magnetic field does not depend on the frame of reference.
There are relativistic solutions to the problem of a single electron, they are beyond me.
- Donald McKinley
Larry,
Could you amplify on your last post in this thread? There are one or two details I found ambiguous.
Don
Don
Marvin's discussion of how easily an electron stream of a few ma is deflected and coiled with a weak magnet. To his view this meant the electron stream had a pretty decent mag field around it.
Quite the contrary is the case. The electron beam coiled and twisted in the "intense field" of the "weak" magnet due to the electron's ultra low mass and thus kinetic energy. A magnetic field strength is related to amp turns a 20 ma beam of electrons would have a tiny magnetic field. Even a klutz kids magnet would have a 500 gauss field! The turning of the beam is a function of the velocity of the charges and the KE of the individual particles in any given field.
So, even a 40kev electron beam of a few ma is easily turned not by the BEAMS magnetic field's reaction to an externally applied field so much as a function of the indivdual micro massed, charged particle's reaction while in motion within the exeternally applied field. One needs to just forget a beam's magnetic field strength unless it is an arc of many amps.
Current makes magnetic fields This is related solely to the number of charged particles moving past a point. The more charges moving past that point, then there more little micro magnetic fields add to the net magnetic field at that point.
Not quite, though I admit standards of proof are somewhat lower for high school than would get into Nature.
Firstly my beam was not a pure electron beam, it was an arc in a low pressure gas. They do collapse into a single stream fairly easily, but at very low currents fill the whole tube.
This is distinct from an electron beam in a TV in that is it microscopically as well as macroscopically neutral. So for a TV the counterbalencing positive charges are a long way from the beam, and thus the magnetic field is spread over a wide area and not concentrated. For an arc, being neutral, the magnetic field is most concentrated around a very thin filiment of conductive gas/electrons. The actual field strength at surface could easily be in the gauss range for a 20ma discharge and it only has to be enough to counteract diffusion in the tube, this does not require very strong forces.
From my limited experience it takes a significant field to deflect an electron beam even slightly, the neutral plasma current was much more dramatic, the fairly weak magnet made it do some spectacular cork screws, but it shows from the magnetude of the response that a gauss range magnetic field could be responsable for the collapse.
In a TV tube the magnetic field is spread out and weak but also the high energy of the electrons makes them much harder to steer. This fits what we know, TV beams do not self focus, to any extent we can see.
For a discharge in a gas there is a magnetic field concentrated around the filiment that forms, and this is in a direction that causes the filiment to self confine. Two wires with current flowing in the same direction attract eachother. The electron energy is also many orders of magnetude smaller than in the TV tube. This also fits what we know, diffuse discharges in a gas above a certain current collapse into an arc.
Its also worth remebering just as a sense of perspective, that in a wire with flowing current the energy is contained mainly, not in the kinetics of the electrons, but in the magnetic field surrounding it.
The specific question I asked is why the beam confinement does not lead to a paradox, as the magnetic field produced by individual electrons would seem to seem to overlap in our frame of reference to produce a force that keeps them together, but in their frame of reference nothing is moving, so the like charges should force them to seperate. Its quite plausable in post einstein relativity you could argue that a magnetic field strength may or may not change in certain frames of reference and noone would know any different, its rather harder to accept that in one frame the physics dictates things collapse and in another expand.
The answer that from the electrons perspective its the field created by the moving positive charges that keeps them in line is good for this observation in a gas tube, and the apparent paradox of 'just electrons' in TV tubes. The paradox itself arises from nothing more than the assumption that you can have a closed system that is not neutral.
For this topic you may enjoy seeing this paper:
http://www.commonsensescience.org/pdf/electron.pdf
However, this model is inconsistent with experimental data showing the electron to be a purely point particle. Neither do any models include the role neutrinos play. All the electron models I have seen are inconsistent with observations. The correct electron model has yet to be formulated.
Hold it! Common sense science is very anti Quatum. They completely reject the point particle theories and posit that the electron has a real and full extent in space with a specific volume and size.
I am not saying their model is spot on or that they are correct, I do say that they hate the idea or even the mathematical treatment of the electron as a point particle. Quite the opposite is the case for them.
They are currently dealing extensively with the Neutron and fully realize its significance in the grand scheme of atom building.
I like their thrust and follow their work closely. Right or wrong, they are rooting around in the right patch.
What I meant by point particle is that as the energy of the electron is increased in collision experiments the size keeps getting smaller. This would imply a type of singularity at r=0 which the rotating ring of charge model lacks.
I think the issue of an electron's "size" is not trivial. The problem with banging particles together, to determine their size is this: It looks for something resembling a hard sphere construction. Which assumes that the particles cannot inter-penetrate, or essentially overlap. (Actually the scattering statistics DO provide information about the density/energy distribution within the collision sphere.)
While the old saw from elementary physics says "Two objects cannot occupy the same space at the same time", what we call an "object" determines if that is actually a true principle. Tunnelling processes stretch the mind in this regard.
Take a cloud of charge for example. From a long distance, it can be considered a point of charge. Up close, it can be considered a collection of smaller charges which have open space between them. Therefore one would expect two "clouds of charge" to be able to overlap the same physical space, without violating any common sense physical principles.
It has been pointed out, that the size of the electron appears to shrink as the collision energy increases. This appears to create a paradox. The "size" of the electron is estimated to be less than 0.01 Fermis - a Fermi is 1.0E-15 meters.. so electron "size" is < 1.0E-17 m, The paradox arises that the observed mass energy of the electron is 0.511 MEV, while the calculated self energy of the electron's charge is many times larger than this - something like 300MEV. The self energy is calculated from assembling small amounts of charge dQ from infinity to the apparent radius. Obviously the exact value would depend on whether one assumed any space between the charge elements. I have never heard how these two figures are reconciled, or if they can be. The easy answere is - That's not the way the electron is put together.
One explanation offered is that electrons are probably "soft". As they collides at higher and higher energies, they deform before deflecting. The standard coulomb's law explanation actually has that exact flavor. The particle appears harder and harder the closer one gets with the test charge.
I cannot vouch for or against the explanation. You can do the math for yourself. It was offered to illustrate the experimental challenges of particle physics.
From my perspective, I am inclined to attribute many of the mysteries, as artifacts of our primitive instrumentation level. When we can directly "measure" with a fineness that makes the planck constant action look large, say to 1E-40m, one would expect a lot more sense to emerge from the sub atomic structure.
Probably at that time, particle collisions to determine particle structure will be seen to make as much sense, as colliding vehicles together to see how big they are, and where the engine was placed!!
Till then, we play math games, using statistics to avoid saying we just don't know.
Nice post Dave!
I see all the particle pronouncements of science as hardly whole cloth especially as it is all basically a mathimatical viel that makes the pros happy.
As the executive editor of ESJ, I have to read a lot of stuff that is pretty much out there....I mean way left of science, but worth a pass...... for you never know. Most of this stuff, I usually trash as not Journal worthy.
I just read a great piece today from a Russian fellow who addresses us as Prof. Kanarev. What his bonifdes are, I am unaware.
Regardless, he obviously is not convinced we are all on the right path. I do not know what his book is touting for I have not had time to delve into it. (There are always a lot of voices willing to tell us just how it REALLY is)
With this in mind, and realizing one can be crazy, but still be habile enough to smell something that stinks and say so, I will submit to the group his thoughts, many of which are sage, inspite of no solution offered. His english is a bit stilted, but his meaning shines through.
- KanarevAppeal-1.doc
- (27 KiB) Downloaded 305 times
There is the classic e/m experimental apparatus that is good enough to demonstrate the ratio of cahrge to mass for an electron with a narrow low voltage beam of electrons in a very slight amount of mercury vapor. The beam ionizes the mercury atoms in its path making the path visible. Using a pair of Helmholtz coils one can produce a weak and reasonably uniform magnetic field that can be aligned to pass through the bulb with the electron beam. When all is in proper orientation, the magnetic field can increased until the beam circles and then the interplay between the magnetic field strength and beam energy or velocity can be explored. Nice Sr High School Physics demonstration.
Out of this comes the basic non-relativistic relation:
Radius of Path = (Mass x Velocity)/ (Charge x Magnetic field)
or R = mV/qB.
So with the tiniest of beam currents, one can essentially ignore the self magnetic field and measure the bending radius. Then boosting the beam current to the max, observe that, other than getting fatter, the beam circles essentially at the same radius of curvature.
Kind of proves conclusively that the bend comes from the external magnetic field.
Now if the beam current were a few kA, not mA, there would be some differences, but the basic properties and relation would still hold. I've done the mA experiment, but not the kA one.
Dave cooper
or R = mV/qB.
Dave cooper
