starts with vacuum theroy, am i looking at it wrong, or just a unique veiw.
Hey everyone,
First off I want to admit I'm not huge on reading. However I have read most of the frequently asked questions and although I may have missed the answer, I still seem to be visualizing and thinking that
The vacuum ..
Shouldn't be so important , until after all the deuterium electrons are no longer a problem and the protons are held in the absolute centre. Only after the protons have produced a mass bigger then the inner grid.
Should we need to crank up the vacuum to original space vacuum?
Also why deuterium, sorry but I do not see a deuterium sun. I do see a hydrogen sun with the promise of the photoelectric effect.
Please don't tell me I need to move to another forum. It's hard when you spend your entire life pulling things apart.
The vacuum ..
Re: starts with vacuum theroy, am i looking at it wrong, or just a unique veiw.
A low pressure (vacuum) is needed in the Farnsworth Fusor in order that the nuclei destined for fusion will reach high velocities before colliding. The distance the particles can travel between collisions is characterized by the mean free path between collisions, depending on pressure, temperature, and gas species. In typical fusors, it is on the order of centimeters. In high pressure conditions (like atmospheric pressure) the accelerating voltage cannot be maintained across dimensions small enough that the ions could accelerate significantly--you would just get an arc discharge. On the other extreme, a vacuum like that in outer space has generally not a single atom in a volume the size of a typical fusor. Clearly you need to have a usable supply of atoms to fuse.
Your consideration of the protons being a mass in the center of the fusors makes me think you are thinking along the lines of gravity, with fusion being an 'event horizon' type threshold. If, so , your concept is completely wrong. Fusion is all about two nuclei hitting with enough speed and on target to such an extent, that the electromagnetic repulsion is overcome and the stronger but much shorter range strong force can fuse them together, with the release of kinetic energy in many situations where the nuclei are lighter than iron. Pressure or density does not effect this in normal conditions, except that with higher densities the chances of these head on collisions occurring goes up. There are all sorts of complications, but that is the basic idea.
As for Deuterium fusion, it also occurs in stars, or at least protostars. D-D fusion is much easier than proton- proton fusion. When a star forms, deuteriun fusion starts up well before hydrogen fusion (hydrogen = proton), and proceeds much faster (by a factor of up to ~ a billion trillion times). Even though the deuterium in the gas of the young star is only ~ 1/6,000th that of the hydrogen, it burns up very quickly (perhaps a few thousand years) and is only a blip on the protostars condensation towards main sequence hydrogen burning. The same occurs with several other light elements in the stellar nebula, like several isotopes of lithium.
In very small stars fusion tends to proceed much more slowly, and in the tiniest stars or Brown Dwarfs, the deuteriun and lithium burning may last billions or even 100s of billions of years, and hydrogen burning may be essentially non existent. It is all dependent on the density/ concentration of the various fuels and the heat they produce which stabilizes the star against further gravitational collapse. The gravitational collapse provides the initial heat that leads to fusion, while the fusion keeps the gas hot enough that the gas pressure prevents further gravitational collapse. In a fusor the gravitation effects of the gas is so ridiculously small that it is completely irrelevant.
Along with the density and temperature, the likelyhood of the reaction is represented by the fusion cross section curve for the reaction. Deuterium - tritium is about 100 times easier than D-D fusion, that is why it is used in the relatively low temperature Tokamaks. Fusors have no problem fusing D-D, at least at interesting tiny quantities. Deuterium- helium3 or He3-He3 can also be used but it is more challenging. Even hydrogen Boron (P-B11) can be done with increasing difficulty. But all of these are ~10^20 times easier to fuse than hydrogen. The very best Fusor might succeed in fusing two hydrogen once every trillion years or so- not very entertaining.
Stars can fuse hydrogen in significant amounts despite the dismal cross sections because their cores are extremely dense and stupendously large. And they have stupendous amounts of mass that does result in a lot of gravity. This gravity provides the original heat and the confinement of the gas, but it is not directly driving the fusion. Things change when the gravity becomes even greater or the fusion peters out, but that is a whole different set of books. If you wonder why gravitational collapse generates heat, consider the Gas laws, or why compreeing air causes it to heat up.
Fusion rate is basically determined by the Fusion Cross Section * temperature *density squared * volume.
Dan Tibbets
Dan Tibbets
Thanks for the reply Carl and Dan. Although after reading each reply I really felt like we really were not on the same page when it came to some of the questions and comments I made.
So how about I simplify things and perhaps try and explain myself a bit better.
Ok , so forgetting everything.
Let's say I had a group of deuterium protons fairly close together.
( how this was achieved is not important).
What I want to do is crush or fuse-crush the protons together with the force of vacuum.
Eg. An example would be my hand ( the vacuum) crushing the plum ( protons).
P.s. Thanks Dan so much for the info on deuterium reactions. But without being big headed wouldn't you choose a harder reaction with the ability to use the photoelectric affect over neutrons heating a oil of some description.
James.
James.
- Doug Coulter
- Real name: Doug Coulter
You were right about not being a big reader.
Carl and Dan just wrote you the most succinct and correct summaries of how this works I've ever read, and they are dead on. There's a lot more complexity behind their descriptions, but those should get you started on understanding.
Vacuum doesn't crush anything - it's a lack of pressure. Deuterium ions are very repulsive (like charges) and need to be accelerated at one another (which is why we ionize them, we don't have a way to put speed on neutral atoms anywhere near as easily as an E-field).
We use D because it is the easiest to fuse there is (high cross section) and because we get this signature signal - the neutrons - that doesn't otherwise appear in nature, thus it's the ideal way to measure how well you are doing. Could you learn to sing or play guitar if you were deaf?
We are lucky the sun isn't mostly D, as it would then simply explode. Richard has mentioned here the power output of the sun per CC, and all our fusors exceed that by many, many, orders of magnitude.
And of course, if you think we're all wrong, the obvious and highly encouraged solution to that is to get yourself into the lab and prove it - we're all ears when it comes to actual data, not so much so for theories from people who don't seem to get the basics that are well known and replicated throughout all science.
Again three folks have tried to explain fusion to someone who seems as if they are trying to understand. If you find their expositions difficult or abstract, as Doug notes, there is much more detail far beyond what they posted.
The plum example is a very poor choice. The proton in and of itself doesn't respond in any way to a vacuum or intense pressure, as noted. The plumb is not crushed by a vacuum at all. The plum is mostly water probably 99.9% by weight. Water can only exist in a deep vacuum as a molecular gas. Thus, when a plum is placed in a vacuum chamber and it is pumped down, all the water evaporates into a gas phase leaving behind a tiny shriveled up shell. Your vacuum pump oil is treated to a lot of free water vapor, demanding a change of oil.
You haven't crushed a plum with the vacuum. You have removed most of its mass and sent it into the increasing vacuum as water vapor. The bulk of the plum's mass is now moved into the oil and on all the surfaces of the vacuum system.
The proton itself is not squeezed or made smaller under 1 million atmospheres of pressure nor is it expanded in the intergalactic vacuum of space. It just doesn't see such mechanical things.
Ok so using vacuum to crush the protons together isnt the smartest idea ever.
Just don't forget the fusor is 98 % insufficient so I don't see why trying another way of fusing is such a bad thing. I understand I'm new here but it doesn't mean I don't understand the basic approach.
Perhaps I could use a magnetic field instead of vacuum.!
Either way I still struggle to see how you are going to fuse at break even especially when all your doing is accelerating protons together. You have the barrier and tunneling plus the inner grid all preventing this.
Not to mention all the failed attempts.
It's has been nice taking to you guys though.
Ill do more reading. Ok.
I don't want to sound harsh, but I am afraid that, in this case, it does mean you do not understand the basic approach.
Work needs to be done on the deuterons to raise their energy to fusible levels. An enclosed vessel does no net work on the gas inside it. Nor can a static magnetic field perform work on charged particles.
Work must be done on the particles in a fusor, and that only comes from an electric field.
James any approach you can think of has pretty much been wrung out. The novel approaches you have already suggested are just flat out impossible based on the simple physics of it all.
It sounds like you think we are here to break even or get nuclear power or just improve the fusor. You used the term 98 percent insufficient. I assume you mean 98% inefficient. Well, its worse than that! We are about 99.99999% inefficient. We waste about 10 million times the electric power into the machine as to the amount of fusion energy that comes out. If we got 2 percent efficient, as you noted, the fusor would have probably killed a bunch of us here from lethal neutron radiation. Oh, but that the fusor wasted only 98% of its input energy! Wow!.... That would be roughly 10 million times better than we are doing now.
Every living breathing entity here knows the fusor will never approach 2% efficiency wasting 98% of its input power. That is a wonderful dream, but it will never happen.
Even the most hopeful here know the fusor will never produce any usable energy.....Ever! We are just not on that quest.
So hobby fusion is not on track to "break even." Not exactly news.
Is that sad? Perhaps--in the same way that the finiteness of the human lifespan is sad. But we all know that just because you won't live forever doesn't mean you can't have a rewarding and contributory existence. Hobby fusion is educational, helping people understand the problems of fusion energy and become experienced with the techniques of research in this area. It leads young people into careers where they will get to work on the massive, international projects that are realistically aimed at "breaking even." And fusion is certainly not just about energy; it's behind electronic neutron generators and some isotope production schemes.
Reality has handed us a world in which fusion is harder than rubbing two sticks together. Let's not bewail the sadness of that against fantasy alternatives. Instead, we just need to calibrate our sense of what is possible and what is interesting to do with what we have.
Vacuum crushing something? As described, vacuum does not do this. If you are thinking of a can being 'crushed' as a vacuum is applied, what is really happening is air pressure outside the can isdoing the crushing.
As for placing two deuterons close together, that is the right idea, but it does not revel how you got them there. Once close enough two deuterium nuclei will fuse together due to the Strong force, but they need to be very very close together. As they approach this range they are increasing repelled away from each other due to the positive charges on the protons. The only way to get them to come close to each other is to throw them- accelerate them to some high speed.
Consider two magnets. Once close enough together they will stick. Imagine one glued to the ceiling(a very high ceiling), the other on the floor. Nothing happens. This could be considered as the normal separation of protons in everyday things. You have to throw the floor magnet hard enough that gravity does not cause it to fall back to the floor, but instead reaches the other magnet and sticks. A certain speed had to be added to the floor magnet for the reaction to reach completion. The electromagnetic repulsion of two positively charged nuclei is the same principle. They do not want to get together until some threshold is passed. It is a balance between competing forces, and in nature protons that are not already bound up in a common nucleus will not approach each other unless some externally applied force changes things. The amounts of force needed are well know and it is considerable. You could squeeze the protons together, but how? No press is strong enough by a huge factor. It is far easier to just throw one proton towards another with sufficient speed so that it doesn't completely stop despite the repulsion till the sticking can occur. The speeds needed for deuterium fusion is over about 100 KM per second. That would be about 240,000 miles per hour.
If you want to consider some of the physics of massive objects like Neutron stars the crushing idea becomes relevant, but for us and normal stars, it is all about speed, speed, speed. (speed = temperature).
It is lucky that fusion is so difficult, otherwise we would not be here. Stars would burn up in a matter of days, or more likely never form as we know them. The Universe would be a far different place .
Dan Tibbets
Dan Tibbets
Hey chris,
Can u take the time to sort out and answer some puzzling questions!
First question, wouldn't the negative dc inner grid produce a magnetic field?
I guess the same would apply to the outer grid- it too would produce a magnetic field?
I'm asking cause I'm confused.
A example of my frustration would be if a negative electron was under acceleration , I say it would produce a magnetic field and wouldn't that magnetic feild be affected be the inner grids magnetic field.?
I under the impression a stationary electron has a negative electric field and no magnetic field.
James...
James...
The electron does have a magnetic moment and responds to a magnetic field.
A grid has no appreciable magnetic field even though it is a current carrier and has current flowing through it.
Again, read up on and know your physics. Current drives a magnetic field in any conductor via "amp-turns" simple fusors have only a few thousandths of one amp flowing in them and are acting as a single turn only. So the net field around the grid wire would be on the order of .01 gauss or so. Actually the magnetic field at any wire in the grid would be far less than this as the current carriers are arriving all over the grid and traveling through a complex network of interconnected wires. Only the grid stalk wire to the insulator would have the full current and .01 gauss field No electron turning magnetic energy here.
Also, you are not to change a thread's title in its flow, even if it is you own thread. So, I have changed them back. If you get a wild hair to change a thread's title in mid-stream, create your own totally new thread.
- Real name: Michael R Cole
What I was reading somewhere was that in a practical fusor ( for a power plant ) the confinement grid would be on the order of 20 to 100 feet in diameter.
A lot of you have only done a fusor grid the size of a golf ball. I dare somebody to build a fusor grid say the size of a basketball inside of a 10 foot diameter chamber or even a grid the size of a softball inside a 2 foot diameter chamber. The volume of the plasma goes up by the cube of the size and the surface area only goes up by the power of 2.
Compare the ration of surface area to volume of a golf ball and then a softball and then a basketball. I don't have the money to build it unless I win nthe lottery or meet somebody who is building one anyways and needs an industrial electrician/EE to help make it work.
This is similar to how smaller mammals and birds have problems retaining body heat and large animals have problems getting rid of body heat.
With such a clear reference to an authoritative archival work as this, who could doubt it? :facepalm:Michael R Cole wrote:What I was reading somewhere
On the contrary, making a fusor bigger could only aggravate the losses and reduce the achievable acceleration voltage.Michael R Cole wrote:was that in a practical fusor ( for a power plant ) the confinement grid would be on the order of 20 to 100 feet in diameter.
The concept of a fusor as a power source is ludicrous beyond any hope of redemption to a meaningful discussion. Any fusion device, as currently produced, if made bigger, has no scintific basis for assuming it will be better. It would just be bigger and cost more and still be an epic fail.
Pity electron can not read the rules and at least get his log on name as a real person
yes you may have given it in a post but the username is still blank
and I do not know many people with the only name of electron
this should be fixed before more posting
I am at a loss here, too - why answers questions to someone who grossly ignores post after post to have their real name displayed? This person joined in 2012 and they have no real name displayed? Maybe answer a question to a true newbie with a warning to add their real name but someone who has been here well over a year?
Policies are irrelevant if not followed by those who are primary posters here. I'd think people would follow the rule if it was enforced better (again, true newbies should get some slack, for a post or two.)
- Werner Engel
- Real name: Werner Engel
James, don't be sad - it took me at least two years of reading plasma physic books, publications (to be found for free in arxiv.org) and handbooks (like pfeiffer vacuum handbook) to get an idea of the knowhow needed to build anything close to a fusion device.
After talking to a researcher from the Tokamak device in Garching and following the theory behind ITER - I almost stopped my interest. It seemed waaayyy to complex for me.
But people like the ones in this forum make me think that I should go on with this very strange Hobby
Good luck,
Werner
Good luck,
Werner
- Paul_Schatzkin
- Site Admin
Who is "electron" ?
It looks like this thread started a while back... was it before we upgraded the board to phpBBS with the rule "Full and Real Names Only."
Maybe that explains why "electron" snuck by?''
In which case when was the last time we heard from him?
Looks like his last visit was over a year ago...
I guess he got tired of people telling him to do his homework?
--PS
--PS
As always, those with the wierdest ideas and the least knowledge don't think the rules apply to them. Electron is either gone or lurking or moribund.
