New idea for making a grid
Hello
Recently I have come up of an idea for making a PERFECT grid
If you have ever heard of shapeways you would no they are a 3D printing company (and are cheap)
If you can design a grid and upload it you can have it printed in steel making a perfect grid
You would however need to design it in a 3d program
- Site Admin
Re: New idea for making a grid
When I was just starting out about a year ago I thought the same thing and designed a model of a grid in 3DS and uploaded it, but it said steel was not an option for that geometry size and shape. Perhaps that has changed.
Although for higher power operation steel is a very poor grid, at a minimum stainless steel is required to avoid extreme out gassing that steel would exhibit, along with the need for higher temperature tolerance. It could work well for lower power fusors though, although for lower power there is little need for optimal grid geometry.
My bad it can be printed in stainless steel
Its not true stainless steel its stainless powder mixed with a bronze that basically brazes the powder together. And the finish is not so hot too.
- Doug Coulter
- Real name: Doug Coulter
Materials aside, and even good SS isn't truly up to snuff, a "perfect" grid has to be geometrically possible, which of course depends somewhat on one's idea of perfect. You cannot for example, design a spherical grid that has equispacing of the wires/elements at all points, forgetting for the moment that you have to connect to it someplace. With a cylinder grid, my choice, you can at least have that in the middle, but not the ends so easily, and have to tolerate end-effects, which I suppose you could call "fringing" for a fairly loose definition. But at least it can be truly right in one area, and even the end effects may not all be bad in real operation.
There are also some other tradeoffs involved, like how much interception area the conductors create, which has a lot to do with losses due to grid-ion collisions (not to mention secondary electron emission). But too small and there are implied sharp corners to generate field electron emission and also be sputtered off by ion hits during operation, changing the dynamic of how it works over fairly short operational times. And making it so weak as to be hard to handle and less able to take heat.
Some of which can be countered using techniques similar to beam power electron tubes, catching things at low energy to shadow things they would hit at high energy, taking more than one grid to accomplish. Or you could make the elements/wires so thin that direct interception became less, but then you have mechanical strength issues, particularly at high you'd probably try to run it at anyway.
Only after that does the exact design and fab begin to really matter (and then, it does matter, a lot).
Precision is pretty important, so new fabrication tech that promises this is always welcome, but frankly doesn't even have the specs available in any old design beam power tube re accuracy and relative alignment over temperature and shock variations. These had spacings between elements sometimes in the microns range, and stabilities to match -- and managed that over some pretty wide temperature swings. This tech doesn't seem to have that if more than one part has to be used and the parts match to those levels.
When I can get the equivalent of CAD/3-d printing in the material of my choice, say tungsten/rhenium and it has precision specs like frame-grid vacuum tubes did I will get pretty excited and it will be a real step forward.
I remember back in the 90's when I visited Dr. Miley at UI he and Robert Stubbers , (now Dr. Stubbers) explained to me how when they first started making Fusors thought that the grids had to be "perfect", so they would polish them for hours. After some experimentation they discovered that it did not make a difference.
- Doug Coulter
Of course, there could be a lot of other reasons for that observation -- like the grid field was so inaccurate at a macro scale that the surface finish of microns didn't matter, something else wasn't up to snuff, and so forth. If they were posting record Q's, the observation might be much more meaningful.
For what it's worth, we don't see huge differences due to surface finish here, and at any rate, sputtering tends to make the grid self polishing. We DO see enormous differences when wires are bent, unequally spaced, or other geometric errors exist in either the grid of the shape of the surrounding outer electrode. The main effect we see from surface roughness is that it becomes easier to start (light off, in the vernacular) with some roughness, probably because of some field electron emission helping with getting ionization started at the beginning. But of course that goes away quickly as sputtering makes everything smoother unless some gross error was made constructing the grid (an errant pointy wire end sticking out for example).
Many things dealing with charged particles only work a little, or very poorly, until *everything* is right.
Current Q's reported for fusors indicate that this is where we are now -- very poor operation vs power input, as many here have pointed out.
A look through the history of vacuum electron tube development would be most educational for most people here and elsewhere working with fusors. Very easy to make say, a triode with low mu and low transconductance -- with almost anything laying about the shop and sloppy hand work (I've done it myself, just for fun -- even built an oscillator with it, barely).
To get to more modern tube specifications, vastly better, it took serious precision and understanding about how charge behaves in various structures and fields, which the charge motion itself affects. We are using particles of the other polarity that are also heavier, but much of the same basic behavior (with appropriate scaling) obtains here.
Modern (relatively speaking) vacuum electron tubes use grid wire spacings down to the 100's/inch, spacing to cathodes in the sub mil range, and alignment between fine pitch grids that are marvels of mechanical design in something that changes temperature quite a bit, and has E fields strong enough to deflect weak structures. Often, fairly expensive and exotic materials were required to meet these specifications. And they didn't do all that for the fun of it in those profit-driven companies, it's how they got the performance up by factors in the 2-3 digit range from the old V or W filament and a bit of screen wire and a flat plate -- which is about where fusor development is *now*.
Or take the case of a modern quadrupole mass spectrometer, or Quistor ion trap - sure, you could hook up some rods or rings and caps to some AC and DC with arbitrary bad mechanical precision and guesses at the AC and DC fields, ratios, and AC frequency, and it would be pretty easy to say the concept was bunk, you never saw mass selectivity or very little...and that rod spacing accuracy or shape wasn't important, because you didn't have the other stuff right, and simply assumed it didn't matter. You'd be dead wrong, of course, as modern mass specs would prove, but it might seem reasonable as an observation.
So I believe the original post was relevant. Just wasn't the whole story.
Just pointing this out, as I was about to hop in this bandwagon.
"DISCLAIMER:
Please note that the materials we use for manufacturing the models make the models suitable for decorative purposes and they are not suited for any other purpose. The models are not suitable as toys to be given to children. The models should not come in contact with electricity or food & drinks and should be kept away from heat."
"DISCLAIMER:
> "DISCLAIMER:
If you'll all please excuse some chattering on a tangential topic...
Got to watch out for those disclaimers! Here's one of my favorites, from the TDK catalog of high-power ferrite cores. http://www.tdk.co.jp/tefe02/e16_2.pdf Right after the 2-kilogram UU core sets, they have core clamping straps with app notes that include:
• "Do not use the bands for purposes other than to secure ferrite cores. The bands are not edible. Keep them out of the reach of children."
> "DISCLAIMER:
- core_straps.JPG (5.89 KiB) Viewed 4770 times
reminds me of a disclaimer I saw in a microwave oven instruction book that read something along the lines of "do not use this oven as a projectile in a sling".
(I believe there was a phase when geeks thought microwave ovens were the coolest and most amusing projectile for their trebuchet projects!)
- Doug Coulter
All of which disclaimers mean something like "if you are in an insanely ligitigeous country like America, this gets us off quick when you try to sue us, we hope."
As a buyer of machine tools -- you'd not believe some of them I see. A lathe is a choking hazard, a welder might burn you, a hammer even may break things. It gets worse but I generally throw that stuff in the trash. Many users manuals (or whatever they are supposed to be, they are not useful for the stated purpose) have one page of use, and 20 pages of "don't blame us if you actually unpack this thing".
And some stuff is such crap, it's almost truth in advertising.
- Real name: David D. Speck MD
On the topic of meaningless disclaimers, my local bank branch has a sign on the door that makes me chuckle every time I visit.
It reads something to the effect of "All customers are requested to remove hoods and sunglasses before entering the bank". Yeah, right -- like the robbers are all gonna be polite and remove their disguises before hitting the place!
Dave
Dave
- Doug Coulter
As I'm a NRA lifer, and this is a small town, we had a fun discussion about that one at my local bank.
They are small enough to be more reason than policy oriented. and the upshot is, heck, they know who everyone is anyway, and are just fine if I am armed in the bank -- prefer it, actually, as does the local liquor store -- I have a lot of money there, what would I do, steal my own dough?
This guy,
http://www.schneier.com/
Runs one of the more intelligent forums around about security, and this came up there a couple years back. Go check the archives and go way back to get into some very interesting stuff. He's about the only right-side up dude in the security biz. Back when I consulted for what is now DHS, I made them buy his books, forgetting that I have to teach them to read, first.
This guy,
